New Reply
Ionic Compounds
Share Thread Thread Tools
Aug7-12, 01:35 PM   #1
Ionic Compounds
Why are ionic compounds hard and brittle ?
For instance, an alloy is a mixture of 2 or more elements and thus does not break easily relative to original elements. Shouldn't the ionic compounds also be like the alloys ?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> RNA capable of catalyzing electron transfer on early earth with iron's help, study says
>> Attacking MRSA with metals from antibacterial clays
>> Femtosecond 'snapshots' reveal a dramatic bond tightening in photo-excited gold complexes
Aug9-12, 04:18 AM   #2
Quote by Jadaav View Post
An alloy usually involves metallic elements and metallic bonding, very different from ionic bonding. I think ionic compounds are hard and brittle, because its component atoms are very strongly bound to each other and form a crystal structure, which means atoms don't have much leeway to move. In mettallic compounds, on the other hand, atoms are as if swimming in a sea of their (and other atom's) electrons, meaning they can slide and move morea easily.
Aug11-12, 05:36 AM   #3
imagine a crystal of alternating Na+ and Cl- ions. You take a hammer and hit it. The Na+ and Cl- ions move around their equilibrium points, as you expect, and return to equilibrium after vibrating. However if you hit the crystal hard enough, you'll dislocate a section of it that happens to align Na+ on one face to Na+, and you get electrostatic repulsion that breaks the crystal apart very quickly. This is the rough reason for why cracks propagate extremely quickly in ionic crystals.
Aug13-12, 11:15 AM   #4
Ionic Compounds
Thanks to both of you :) I now understand how it works.
Concerning the dislocation of the lattice structure, What did you meant by " align Na+ on one face to Na+ " ?
Isn't the Na+ surrounded by 6 Cl- ions ?
Aug16-12, 02:27 AM   #5
Maybe in the depths of the lattice, yes, but what about on the edges / faces?
Aug21-12, 12:59 PM   #6
So I presume each lattice isn't connected to each other by ionic bonding, am I right ?
One lattice has a layer on it ( inside which are the ions ) and which is could be cracked by hitting and then the whole object dislocating with electrostatic repulsion.
That's what I could imagine.
New Reply
Thread Tools
Similar Threads for: Ionic Compounds
Thread Forum Replies
Predicting solubility of ionic compounds in ionic liquids Chemistry 2
differentiate an ionic from a covalent compounds Chemistry 6
Classifying Ionic Compounds Biology, Chemistry & Other Homework 5
Net ionic compounds Biology, Chemistry & Other Homework 2
Naming Ionic Compounds Biology, Chemistry & Other Homework 9
