How can we determine the biggest magnetic force on a wire?
The discussion revolves around determining which wire experiences the greatest magnetic force when subjected to a magnetic field. The problem involves analyzing the forces acting on different wire configurations and understanding the application of the magnetic force formula, F = BIL sin θ, particularly in the context of non-straight wires.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the application of the magnetic force formula to non-straight wires and suggest dividing the wires into small straight segments for analysis. There are discussions about the cancellation of horizontal components of force in different wire configurations and how to compare forces on various segments.
The discussion is ongoing, with participants providing insights on how to approach the problem mathematically. Some guidance has been offered regarding the analysis of wire segments, but there is no consensus on the final outcome or the best approach yet.
Participants note that the formula for magnetic force applies to straight segments only, raising questions about how to handle wires with curves or bends. There is also uncertainty regarding the symmetry and cancellation of force components in different wire configurations.
songoku
Which wire will experience the biggest force?
a. 1
b. 2
c. 3
d. all wires experience the same force
e. can't be determined without additional information
F = BIL sin θ
Can the above formula be applied to a non-straight wire? I only know that the formula is used for straight conductor.
My guess: the answer is wire 2 because for wire 1 and 3, there will be vertical and horizontal components of magnetic force and some of the horizontal components will eliminate each other. The sin or cos term of the force will reduce its magnitude hence the biggest force will be experienced by wire 2.
Am I correct? Thanks
try to divide each wire into small straight segments and analyze the force on each and add them up?
You can still use it for each small segment of wire. Replace L with dL. As bigerst suggested, analyze the force on each segment and add them up.
If you look at all the segments of the wire, it is true that they will have various vertical and horizontal components. But exactly which components add and which cancel? Think it over again.
So I cannot just change the "L" with length of the circular wire, which is its circumference?
For wire 1, all the horizontal components will cancel each other.
For wire 3, maybe not all the horizontal components cancel. But how to can we compare the magnitude of force on wire 3 and 2?
Thanks
indeed, F=BL (sin(θ)) works for straight segments only
however if u divide it up into several segments, for each segment
F= B sin(θ) ΔL since B is constant, then u can sum this up
Thanks
what makes you think that? do a detailed mathematical analysis of the wires (split it into tiny, essentially straight segments and add the force contributions to each segment) and see what happens. it might be useful to separate each ΔL into vertical and horizontal components, rearrange which ones you add first, and see what happens.
No, since the force on each segment acts in a different direction.
Sorry I don't know how to do a detailed mathematical analysis. But I am pretty sure that for wire 1, all the horizontal components will cancel each other because the direction of force at each segment will be like "radially outward".
For wire 3, I divide it to 4 segments:
segment 1 --> from (a) until the letter "i"
segment 2 --> the "lower curve"
segment 3 --> the straight part until number "3"
segment 4 --> from "3" to "b"
Assume segment 1 and 4 are symmetry, the horizontal components will cancel out each other, as the case of wire 1
Assuming segment 2 has a smooth and symmetry curve, the horizontal components will also cancel out each other, as the case of wire 1
Assuming segment 3 is straight line, there will be force directed upwards.
But I think my analysis is very weak...
since i have yet to figure out how to draw on physics forums i will use texts and hope it doesn't get too confusing. (you may find it helpful to draw on a piece of paper)
let us establish a 3d cartesian plane, with x-axis points to the right., y-axis points up, and the z axis points out of the page. let us suppose the magnetic field B, points along the z axis, out of the page, and the wires solely lie in the xy plane. suppose a wire goes from (0,0,0) to (1,1,0) and carries current I. since this is a straight wire F=BlIsin(θ) applies. find the force on the wire along with its direction, name this F1 (bold denoting it a vector)
now consider a wire that goes from O(0,0,0) to A(1,0,0) then to B(1,1,0) which also carries current I. use F=IBLsin θ on the two segments OA and OB separately (since each segment is straight the formula applies) to find the net force F2, yup another vector. you should be able to show F1=F2 in both magnitude and direction.
now comes the fruit of the argument, you should be able to reason that any small straight wire could be separate into x and y components with the net force on the segment unchanged.
also notice that once you divide the wires into components the order at which the compoenents appear doesn't matter since the field is uniform.
apply the above argument to the 3 wires in the problem by dividing each wire into infinitisimal (so essentially straight) segments, and separate each into x,y compoenents, by rearranging you should be able to see clearly which components cancel and which dont. (you don't have to do very sophisticated math, just an argument)
  • · Replies 23 ·
