New Reply
Net acceleration of the Earth
Share Thread
Aug22-12, 03:25 PM   #1
I'm trying to explain to someone why I think the net acceleration of the earth (due to the sun) is non-zero.
My reasoning is that the velocity of the earth is constantly changing. As the sun pulls the earth's orbit into an ellipse, the direction component of velocity is being changed. Therefore velocity is changing.
It's easy to work out the centripetal acceleration from classical mechanics, but I'm trying to explain it intuitively.
Their reasoning is as follows:
-The direction component of all the infinitude of velocity vectors during the earth's orbit cancel out. (for every one pointing in direction X, there's another one, half a year later, pointing in direction X + pi, etc.)
-Since the direction components all cancel out, the velocity is reduced to the constant speed.
-Since the speed is constant, the acceleration is zero.
I need a little help explaining why that reasoning is flawed. I'm pretty much at my limit of ability to explain things.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Aug22-12, 03:29 PM   #2
Mentor
You are arguing--correctly--that the instantaneous acceleration of the Earth is non-zero. They are just making the point that the average acceleration (over a year, say) is zero. Two different issues.
Aug22-12, 03:32 PM   #3
I see.
What about the "net acceleration" though?
This is the term they keep using.
I say the net acceleration is non-zero since there is velocity changing work being done to keep the earth in orbit. (as opposed to having a constant velocity)
Aug22-12, 03:35 PM   #4
Quote by Doc Al View Post
And they are making that point in a needlessly complicated way. If the Earth arrives at the same velocity it had a year ago, then the average acceleration since then was zero.
Aug22-12, 03:35 PM   #5
Quote by sharpnova View Post
I see.
That is not a term that means anything to me. How do they feel that it differs from "acceleration"? What would "gross acceleration" mean?
If one is playing tennis on a calm day, does that mean that the net acceleration is zero?
Aug22-12, 03:37 PM   #6
Recognitions:
Gold Membership Gold Member
I see.
Have them define "net acceleration" and you will likely have your answer.
Aug22-12, 03:38 PM   #7
No work is being done on an object in a circular orbit. In a elliptic orbit the net work done over a year is also zero.
Aug22-12, 03:41 PM   #8
Recognitions:
Quote by jbriggs444 View Post
An excellent definition
Aug22-12, 03:52 PM   #9
Quote by A.T. View Post
I don't think I understand that. Without the sun, the earth goes in a straight line. The sun comes along and gravitationally pulls the earth into an ellipse. Does it not take energy to continually yank the earth into orbit?
Aug22-12, 04:31 PM   #10
When calculating work, you only include the component of force in the direction of velocity. In a circular orbit, the force is always perfectly perpendicular to velocity, and thus no work is done.
If you want to think about it in terms of energy, think about the earth's gravitational potential with the sun. The further away the earth is from the sun, the more gravitational potential it has, so it would take an input of energy in order for the earth to move further away from the sun.
Aug22-12, 04:35 PM   #11
Ahh gotcha. Yeah I was thinking of that completely wrong.
Aug22-12, 04:48 PM   #12
Ok so they said when they say "net acceleration" they are referring to the sum of all the vectors in a rotational period.
Aug22-12, 04:56 PM   #13
Once you normalize that sum so that it is not infinite, it is the same thing as "average acceleration"
If the average taken to be is over time then that is the same thing as change in velocity divided by elapsed time.
By inspection, the velocity of the earth on January 1 is the same as it was on January 1 of the previous year [modulo various finicky caveats]. It follows that the change in velocity is zero and the average acceleration is zero.
Aug23-12, 11:47 AM   #14
"net acceleration" usually refers to an instantaneous acceleration which results from multiple simultaneous acceleration vectors. They're referring to the average acceleration over a year; I wouldn't call that "net acceleration."
Sep30-12, 03:48 AM   #15
"without the sun the earth goes in a straight line" is a false statement. Both sides of the argument are flawed. The answer may be hidden in a question, the why of an elliptical orbit. the star that is the central point to our solar system has a trajectory and also a velocity dictated by? at times this star is pulling us and at other times is on a collision course with us. Theoretically the farther away a planetary body, the more elliptical the orbit (considering mass). Is there a fixed point upon this star,as it travels in a circular path that defines one revolution?
Sep30-12, 09:05 AM   #16
mfb
Mentor
@slayerwulfe: Your post does not make sense at all.
Sep30-12, 10:27 AM   #17
Quote by mfb View Post
according to ? and this probably doesn't make sense either, Schrodinger's cat: Why the box, strap it to the cats neck. Is it now both dead and alive at the same time. Theory vs. reality where theory becomes what you want it to be. Thank you for your detailed analysis of no sense at all.
New Reply
Similar discussions for: Net acceleration of the Earth
Thread Forum Replies
What is acceleration due to gravity of earth? Introductory Physics Homework 1
What causes the centripetal acceleration of the earth? Classical Physics 4
Centripetal acceleration on Earth Introductory Physics Homework 26
radial acceleration with earth Introductory Physics Homework 4
Centripetal acceleration of Earth around Sun? Introductory Physics Homework 6
