| New Reply |
A few questions about gravity, space, and reality in general |
Share Thread | Thread Tools |
| Sep9-12, 04:52 AM | #1 |
I'm just curious and like thinking about how reality works. I don't now where or if I could find the answers to these questions already written.
From what I've seen and read, gravity is cause by space being bent by mass the same way a person standing on a trampoline bends the trampoline. 1. Would enough mass packed into a single point be able to bend space to the point of tearing? 2. Is a black hole a point in space that was torn like in the above question? 3. If space is bent like a person bends a trampoline down, where is the mass pushing space to bend it? I have read about antimatter being made and have a few questions about that too. 4. Would an anti hydrogen used to make a bomb like hydrogen was, would it actually work? 4b. Would it have the same or greater power? 5. If you annihilated antimatter and matter in a vacuum and somehow stopped it immediately when the two are destroyed, what would be left? |
| Sep9-12, 07:02 AM | #2 |
Mentor
| Sep9-12, 02:01 PM | #3 |
If the trampoline analogy is too simple to accurately explain how space bends, exactly how does mass bend space?
With that antimatter bombs idea, I was thinking if you used fusion to disperse the antimatter before annihilation. Would the fusion reduce the overall power of the annihilation, or just spread it out a little? Let me rephrase my last question. Is there a stage between annihilation and photons or pions? |
| Sep9-12, 04:40 PM | #4 |
Mentor
| Sep9-12, 06:09 PM | #5 |
If you could make a device that bends space, would it be possible to bend two points until they become the same point, or close to it?
Different dimensions 1. If we could travel in four dimensions, could the multiverse be arranged like a hallway and each universe is like a different room? 2. Could the big bang have been another universe forming a bubble that is now our universe? 3.Could the multiverse be arranged like groups of bubbles inside of bubbles, inside of even larger bubbles? Thanks for answering the questions of someone that knows almost nothing about physics and the math behind it. |
| Sep10-12, 08:01 AM | #6 |
Mentor
Otherwise, the question is meaningless. |
| Sep10-12, 01:48 PM | #7 |
1. In this question, I mean the fourth dimension is perpendicular with our three dimensions. I'm trying to ask if the fourth could be the way to parallel universes, while those universes are three dimensional.
3. Wouldn't there have to be something between the universes to keep them from interfering or destroying each other(some kind of wall or membrane?)? I am assuming that other universes exist, and that they are not separated just by being on a different frequency. New question: Do you know about sacred geometry? If so, do you think it is relevant to the study of the universe? I apologize for putting something a bit religious on here, but it is primarily geometry. Assuming we will end up typing more, I always assume there to be many more dimensions than the three, and that time is not one of them. |
| Sep10-12, 02:59 PM | #8 |
Mentor
| Sep10-12, 08:15 PM | #9 |
1. I guess the way I think about dimensions differs from most people.
Sacred Geometry isn't just how they build religious buildings and such. It's a geometry that uses structures and patterns found in nature. http://www.geometrycode.com/sacred-geometry/ This explains it better than I can. Just try to ignore the religious bits and view it as geometry. It basically says that life follows a few set rules of geometry, and so does the rest of the universe. I just don't see time as a dimension, because if someone goes back in time and does something, that makes the world branch off onto it's own path. Like on a computer game, if you load a save from before where you just were, you either make a new save, or you overwrite the previous one, destroying it. If it doesn't do that, then if time travel ever becomes possible, it has already happened. Viewing the past without actually affecting it, using math or technology that follows matter going backwards in the same way it's used to predict where something is going... Can that be done? |
| Sep10-12, 11:24 PM | #10 |
Recognitions:
You might have better luck asking about them (preferably by name, and omitting the speculative stuff) in another forum (beyond the standard model would be the PF forum I think) or just doing some research. Wiki has the following to say (it seems reasonable to me, but remember, I don't know much about brane theory): http://en.wikipedia.org/w/index.php?...ldid=496954697 I could try and get into it a bit more, but it can get somewhat involved. I'll just say that the most primitive concepts of dimension can be defined in topology, and that the only thing you need to use these primitive concepts is the concept of "neighborhood" , sometimes called "open sets" or "open balls". This leads to the idea of "covering dimension" - there's a bunch more as well, "dimension" is a term used to describe a group of related concepts. It's generally more productive if you adapt your personal definitions to the ones used in the field, if you insist that the field adopts your own personal ones, it's probably not going to cooperate :-). |
| Sep11-12, 01:02 AM | #11 |
| Sep11-12, 01:27 AM | #12 |
I'm not unwilling to adapt my definitions, I've just never read about physics. All my knowledge and ideas come from using common knowledge, ideas from many religions, and never being able to stop thinking about how the universe really works. I have no education after highschool, besides culinary arts, so I still have much to learn.
The way I learn and understand things is to construct models in my mind using what I already know and applying it to the new information. My brain doesn't like math, so it will take a while to understand all this new information. I love learning these new things though. Time being a dimension; I always pictured it to be like a movie. That we'd be the characters in the story. If there were some sort of being outside our spacetime, they'd be watching, and no matter how many times they went back, we'd never know because to us, nothing had happened. We'd just go on repeating until it's destroyed. Now I see it more like we are in a game and even if there were a being outside our spacetime, they couldn't rewind or anything, but they could view the log of what has happened. Are either of these views even remotely accurate when you see time as a dimension? |
| Sep11-12, 01:36 AM | #13 |
| Sep11-12, 01:56 AM | #14 |
But I think most would agree that if you 'played back' the universe exactly then no-one in it would notice. Though the if in that statement is an impossible if :) |
| Sep11-12, 04:39 AM | #15 |
Mentor
| Sep11-12, 02:16 PM | #16 |
Has anyone attempted to use all the known laws of physics to generate a world inside a computer?
Is there even a computer powerful enough to to generate and keep a world the size of a solar system, or maybe a single galaxy going while obeying all the laws of physics? Would such a thing be helpful in finding any gaps in the current understanding of how the universe works? |
| Sep11-12, 02:21 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: A few questions about gravity, space, and reality in general
| Thread | Forum | Replies | ||
| The reality of Configuration space | Quantum Physics | 94 | ||
| Will laser-powered space elevator become a reality soon? | Materials & Chemical Engineering | 0 | ||
| Questions about gravity and curved space | Special & General Relativity | 13 | ||
| Flat-space picture of gravity vs. General Relativity | Special & General Relativity | 5 | ||
| Anti-Gravity Propulsion Reality | General Discussion | 4 | ||
