Proving the Inclusion: A0\cupB0 in (A\cupB)0
  • Thread starter Thread starter STEMucator
The problem involves proving that the union of the interior points of two subsets A and B of ℝn, denoted as A0 ∪ B0, is a subset of the interior of their union, (A ∪ B)0. Participants are also asked to provide an example where this inclusion is strict.
  • Participants discuss the necessity of assuming a point in A0 ∪ B0 and proving its inclusion in (A ∪ B)0. There is exploration of the definition of interior points and the implications of neighborhoods contained within sets.
There is an ongoing exploration of the proof structure, with participants questioning the clarity of their reasoning and the definitions involved. Some guidance has been offered regarding the use of neighborhoods and the relationship between the sets A and B.
Participants note the need for a specific example to demonstrate strict inclusion, with suggestions for defining sets A and B to illustrate this point.
STEMucator
Homework Helper
Let A and B be subsets of ℝn with A0, B0 denoting the sets of interior points for A and B respectively. Prove that A0[itex]\cup[/itex]B0 is a subset of the interior of A[itex]\cup[/itex]B. Give an example where the inclusion is strict.
I know a point Q[itex]\in[/itex]S is an interior point of S if [itex]\exists N_δ(Q)[/itex] which is a subset of S.
I've never actually attempted a problem like this, I'm wondering where to start really. Do I assume the existence of a point in A0[itex]\cup[/itex]B0 and then prove it is also contained within (A[itex]\cup[/itex]B)0 ? Any nudge in the right direction would be very helpful.
Yes, that's exactly what you need to do.
So, suppose [itex]x \in A^o \cup B^o[/itex]. Then either [itex]x \in A^o[/itex] or [itex]x \in B^o[/itex]. If [itex]x \in A^o[/itex], can you prove that [itex]x \in (A \cup B)^o[/itex]?
EDIT : I thought about it a bit, is this better?
Suppose we pick x[itex]\in[/itex]A0. WAIT NOW... We know that A0 is the set of interior points for A so since x[itex]\in[/itex]A0 we can also say that x[itex]\in[/itex]A since x is contained within the interior of A. If x[itex]\in[/itex]A, then it follows that x[itex]\in[/itex](A[itex]\cup[/itex]B) and will be contained within the interior of A[itex]\cup[/itex]B that is x[itex]\in[/itex](A[itex]\cup[/itex]B)0?
I know this is wrong, but maybe its a step in the right direction?
Use the definition of interior point. If x is an interior point of A then there is a neighborhood of x that is contained in A. Is that neighborhood contained in AUB?
It seems trivial in saying that. Showing it is a different story though.
So since x[itex]\in[/itex]A0, [itex]\exists δ>0 | N_δ(x) \subseteq A[/itex]
This is obvious to me ^, but how would I use this notion to show that x[itex]\in[/itex](A[itex]\cup[/itex]B) or does it go without saying?
Goes through without much said. If x is in the interior of A then x is in A. x is in the neighborhood. If x is in A then x is in AUB. Now what about the neighborhood of x?
Since x is contained within the interior of A, we know x is contained within A itself. The neighborhood of x is therefore contained within A.
Since x is in A, we know that x is in A[itex]\cup[/itex]B
So would it follow that the neighborhood of x is contained ( is a subset of ) within A[itex]\cup[/itex]B? If this were the case then since we know the neighborhood is inside A[itex]\cup[/itex]B, we know it would be contained within the interior of A[itex]\cup[/itex]B?
You are making this seem harder than it is. If the neighborhood of x is contained in A (by definition of x being an interior point), then it must be contained in AUB, right? A is contained in AUB.
My apologies, it's been a long day so my brain isn't registering like it usually does.
Yes i understand that the neighborhood of x being contained in A tells us that the neighborhood is also contained within A[itex]\cup[/itex]B.
So if A [itex]\subseteq[/itex] A[itex]\cup[/itex]B that tells me that A0 [itex]\subseteq[/itex] (A[itex]\cup[/itex]B)0? Is it actually that straightforward?
Yes, it is. Now you have to find the example where the inclusion is strict. You can find one by thinking about closed intervals on the real line.
So ill just clean up everything that's been said into one post here :
Suppose x[itex]\in[/itex](A0[itex]\cup[/itex]B0). Then x[itex]\in[/itex]A0 or x[itex]\in[/itex]B0.
Suppose x[itex]\in[/itex]A0. Then x is an interior point of A and [itex]\exists δ>0|N_δ(Q) \subseteq A[/itex]
Since the neighborhood of x is contained within A, it follows that it is also contained within A[itex]\cup[/itex]B.
Now since A[itex]\subseteq[/itex]A[itex]\cup[/itex]B, it follows that A0[itex]\subseteq[/itex](A[itex]\cup[/itex]B)0. If we had chosen x[itex]\in[/itex]B0 we would have come to the conclusion that B0[itex]\subseteq[/itex](A[itex]\cup[/itex]B)0 through the exact same logic. So it follows that A0B0[itex]\subseteq[/itex](A[itex]\cup[/itex]B)0 as desired.
Now as for the example where the inclusion is strict would I need something like :
A = {x[itex]\in[/itex]ℝ | 0 ≤ x ≤ 1} so A0 = {x[itex]\in[/itex]ℝ | 0 < x < 1}
Seems ok for the proof. To show the inclusion may be strict, you need to define B as well, yes?
I would be careful with how you've worded this.
Indeed, "since A[itex]\subseteq[/itex]A[itex]\cup[/itex]B, it follows that A0[itex]\subseteq[/itex](A[itex]\cup[/itex]B)0" is very close to the statement of what you have been asked to prove, without the proof.
You have a neighborhood N of x such that [itex]x \subset N \subset A[/itex]. Furthermore, [itex]A \subset A \cup B[/itex], so it follows that [itex]x \subset N \subset A \cup B[/itex]. Therefore...
Yes yes, just ensuring I needed something of that sort. Okay hmm, strict inclusion means there should be at least one element not included so would ...
A = {x[itex]\in[/itex]ℝ | 0 ≤ x ≤ 5}
B = {x[itex]\in[/itex]ℝ | 5 ≤ x ≤ 10}
Work?
Therefore the neighborhood of x is also contained within the interior of the union of A and B? Also I believe what I said is sufficiently far enough from the original question, but how would I rephrase this portion.
Work?
Works. Why does it work? Spell out the reason.
Well
So
A0 = {x[itex]\in[/itex]ℝ | 0 < x < 5}
B0 = {x[itex]\in[/itex]ℝ | 5 < x < 10}
So we have : A0UB0 = {x[itex]\in[/itex]ℝ | 0 < x < 10, x≠5}
And also : (AUB)0 = {x[itex]\in[/itex]ℝ | 0 < x < 10}
Thus : A0UB0[itex]\subset[/itex](AUB)0
Zondrina said:
Well
So
That's exactly what I wanted to hear. Thanks!
Oh man thanks so much for your patience, really though. I just wanted to understand this so badly.
Also my final concern, is what jbuni said true? Am I too close? Or was my proof sufficient?
What you said convinces me you understand it. jbunnii's rephrasing is a better version for the proof.
You have a neighborhood N of x such that x⊂N⊂A. Furthermore, A⊂A∪B, so it follows that x⊂N⊂A∪B. Therefore..
Therefore since A is contained within AUB, it follows that A0 is contained within (AUB)0.
I believe that's what he meant to say. If so then I do agree it's a better way to phrase this.
Yes, if the neighborhood N of x is in A, then it's certainly in AUB.
Perfect, thanks again for all your help man. Though I wish my professor didn't dive right into topology as soon as the class started... ( Its only calc II lol ).
Just to follow up on my earlier post...
You have a neighborhood N of x such that [itex]x \subset N \subset A[/itex]. Furthermore, [itex]A \subset A \cup B[/itex], so it follows that [itex]x \subset N \subset A \cup B[/itex]. Therefore x is an interior point of [itex]A \cup B[/itex], i.e. [itex]x \in (A \cup B)^o[/itex]. Since [itex]x[/itex] was an arbitrary point of [itex]A^o[/itex], this shows that [itex]A^o \subset (A \cup B)^o[/itex].
(Then argue similarly for [itex]x \in B^o[/itex] and wrap up the proof.)
That's the level of detail I would like to see if I were grading this problem, so I could be confident that you understood why every step was true.
19K
