New Reply
Closed loop drive system
Share Thread Thread Tools
Sep30-12, 05:55 AM   #1
Recognitions:
Gold Membership Gold Member
Hello, I have a few questions regarding machine tool drive and feed back system.
Say I have a 1 meter long guide way and a carriage that is driven by DC motor. This carriage glides on air bearings.
The drive mechanism has pinch rollers that pinch a drive rod and these rollers are driven by the dc motor.
I have linear positioning scales attached for precise linear positioning.
I have a mechanical switch that will trigger once it makes contact with a fixed mechanical stop at the end of the meter travel.
This signal goes to a dedicated PC where software provides feed back to the drive motor.
How is the processed linear position going to vary versus the true linear position?
Is there has to be a certain signal lag time due to linear position signal being processed ?
Will heat effect the true signal accuracy of the scales?
Will motor drive noise add to error of the system?
If a software program is written to slow the motor prior to contacting the mechanical stop, would this increase signal lag time?
How can I get the most accurate and precise 1000 mm distance movement with this system?
I appreciate any reply as I am not well versed in this discipline.
Thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
New Reply
Thread Tools
Similar Threads for: Closed loop drive system
Thread Forum Replies
Open-loop & Close-loop system Engineering, Comp Sci, & Technology Homework 2
Designing a closed loop fluid system Engineering, Comp Sci, & Technology Homework 3
Closed loop vs open loop resistance magnet drop demo Electrical Engineering 2
Calculating pipe size for closed loop watering system Introductory Physics Homework 2
Closed Loop Pulley System, which scenario is better? General Engineering 3
