Can Momentum Transfer Exceed Double the Initial Value in Elastic Collisions?
  • Context: Graduate
  • Thread starter Thread starter greswd
    Momentum
The discussion revolves around the question of whether the momentum transfer in a perfectly elastic collision can exceed double the initial momentum of one of the colliding bodies. The scenario is set in one dimension, involving two balls, where one is initially at rest.
  • Some participants propose that the ratio of the momentum of Ball B after the collision to the initial momentum of Ball A must be less than 2, expressed as |\frac{p_b}{p_a}|<2.
  • Momentum conservation is cited, leading to the equation {p_a} = {p_a}' + {p_b}, which some participants use to derive relationships between the momenta.
  • Energy conservation is also discussed, with participants noting that the initial kinetic energy of Ball B is zero, which implies that the speed of Ball A cannot increase after the collision.
  • One participant combines momentum and energy conservation equations to show that \frac{p_b}{p_a}=\frac{2m_b}{m_a+m_b}<2, suggesting a dependency on the masses of the balls involved.
  • Another participant emphasizes the need to combine the results from momentum and energy conservation to arrive at the conclusion that 0 < \frac{p_b}{p_a} < 2.
Participants generally agree on the mathematical relationships derived from momentum and energy conservation, but there is no consensus on the implications or the completeness of the arguments presented.
Some assumptions regarding the masses of the balls and the conditions of the collision are not explicitly stated, which may affect the derived conclusions.
greswd
Here's an interesting puzzle:
The whole scenario takes place in one dimension of space.
Ball B is at rest. Ball A moves with momentum [tex]p_a[/tex]
Ball A makes a perfectly elastic head-on collision with Ball B. Ball B moves off with momentum [tex]p_b[/tex]
Prove that [tex]|\frac{p_b}{p_a}|<2[/tex]
Ball A makes a perfectly elastic head-on collision with Ball B. Ball B moves off with momentum [tex]p_b[/tex]Prove that [tex]|\frac{p_b}{p_a}|<2[/tex]
Momentum conservation :
[tex]{p_a} = {p_a}' + {p_b}[/tex]
[tex]1- \frac{{p_a}'}{p_a} = \frac{p_b}{p_a}[/tex]Energy conservation (Ball B had intially no KE, so speed of ball A cannot increase):
[tex]|\frac{{p_a}'}{p_a}| < 1[/tex]
All true, but I don't see how that gets you to the answer required.
Using energy conservation more completely:
[tex]\frac{{p_a}'^2}{m_a}+\frac{{p_b}^2}{m_b}=\frac{{p_a}^2}{m_a}[/tex]
Combining with momentum eqn. we get
[tex]\frac{p_b}{p_a}=\frac{2m_b}{m_a+m_b}<2[/tex]
You have to combine the two of course:
This leads to:
[tex]0 < \frac{p_b}{p_a} < 2[/tex]
Yes, the clean & complete way is to derive the ratio as function of the masses. Mine was just showing that the ratio is < 2.
  • · Replies 25 ·
13K
  • · Replies 19 ·
  • · Replies 34 ·
