Register to reply
Simply Supported Beams Loads and S/BMD's
by nobodyuknow
Tags: beams, loads, s or bmd, simply, supported
Share this thread:
nobodyuknow
#1
Nov9-12, 10:07 PM
P: 64
1. The problem statement, all variables and given/known data
Here is the Simply Supported Beam with a uniform and triangular load.
http://prntscr.com/jd6b2
2. Relevant equations
3. The attempt at a solution
Newest attempt: http://prntscr.com/jdu7d
Current Step: Shear Force and Bending Moment Diagrams.
Phys.Org News Partner Science news on Phys.org
Wildfires and other burns play bigger role in climate change, professor finds
SR Labs research to expose BadUSB next week in Vegas
New study advances 'DNA revolution,' tells butterflies' evolutionary history
PhanthomJay
#2
Nov9-12, 10:49 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 6,035
Quote Quote by nobodyuknow View Post
http://prntscr.com/jd6my
RAy + RBy = 900 + 225 = 1125kN
ƩMA = 4.5(225) + 12(900) - 18(RBy) = 0
RBy = 656.25kN
RAy = 568.75kN
Is what I've done right so far? (Finding Reactions at A and B)
How are you arriving at these numbers? And what happened to the 200 kN concentrated point load? The UDL of 50 kN per m acts over 9 feet, not 18 feet, and its resultant lies at its cg. The triangular distribution has a resultant of 225 kN, yes, but you show it acting in the wrong location. It too acts at the cg of the triangle.
nobodyuknow
#3
Nov10-12, 12:51 AM
P: 64
Hmm, I think I have actually interpreted this question wrong.
Is this image showing one 50kN load being distributed uniformly THEN being triangularly distributed. AND a 200kN point load? (I've been viewing it as two separate loads.
I got 225 by (50kN * 9m)/2 (Uniformly distributed load)
PhanthomJay
#4
Nov10-12, 05:42 AM
Sci Advisor
HW Helper
PF Gold
P: 6,035
The problem is showing a uniformly distributed load of 50 kN/m acting over the first 9 meters of the beam. It's total load (resultant of the distributted load, which is the 'area' of the rectangle, or (50)9 = 450 kN) acts at its cg 4.5 m from the left end. Thus, when determining reactions, it can be treated as a single concentrated point load of 450 kN acting 4.5 m from the left end. You incorrectly divided that total load by 2, but showed its location correctly.
Then the problem shows a separate 200 kN concentrated point load acting at the center of the beam 9 m from the left. Don't ignore it.
Finally, the problem shows a separate triangularly distributed load that varies from 50 kN/m to 0 kN/m acting over the right half of the beam. It's resultant equivalent concentrated load is found by calculating the 'area' of that triangle and placing that load at the cg of the triangle. You correctly located that load as 12 m from the left end, but its value is wrong.
nobodyuknow
#5
Nov10-12, 05:58 AM
P: 64
Alright I've redone it, http://prntscr.com/jdu7d
The next step is to draw bending moment and shear force diagrams. I'll post when I've got them.
nobodyuknow
#6
Nov10-12, 08:20 PM
P: 64
I've done the shear force diagram, is this right?
Some reason I can't edit previous posts or the thread.
PhanthomJay
#7
Nov10-12, 09:17 PM
Sci Advisor
HW Helper
PF Gold
P: 6,035
No attachment. You can't edit threads after a certain time has passed..
nobodyuknow
#8
Nov10-12, 09:54 PM
P: 64
Oops, here it is: http://prntscr.com/jg37y
SteamKing
#9
Nov11-12, 12:36 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,334
Your shear force diagram is incorrect. You have not included the concentrated load of 200 kN.
PhanthomJay
#10
Nov11-12, 04:45 PM
Sci Advisor
HW Helper
PF Gold
P: 6,035
When you try this again, be sure to show the distributed loads in your loading diagram. Do not represent them as concentrated point loads...that only works when you are calculating end reactions. And remember that the slope of the shear diagram at any point is equal to the negative of the load intensity at that point. You have kinks and valleys where there should be none.
Register to reply
Related Discussions
Have i done this right? Simply Supported Beams Engineering, Comp Sci, & Technology Homework 3
Simply supported beams bending moment Introductory Physics Homework 8
Simply Supported Beams - Stuck On A Question Engineering, Comp Sci, & Technology Homework 3
Finding Reactions In Simply Supported Beams Engineering, Comp Sci, & Technology Homework 4
Simply supported beams? Introductory Physics Homework 20
