New Reply
Why does the graph of x^x undefined for x is less than or equal to 0?
Share Thread Thread Tools
Nov7-12, 12:40 PM   #1
Let f(x)=(x)^(x)
f(-1)=(-1)^(-1)
=1/-1
=-1
But according to wolframalpha, f(-1) does not exist.
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Nov7-12, 01:16 PM   #2
The function works only in integer point. For each non integer point the function goes in Complex Set, and so isn't defined on real. Easilly, to avoid the calculator have problem on any other point lesser then 0, the programmer block each of that point with "does not exist" message.
Fruthermore I can rewrite the f(x) in this way:
f(x)=exp(x*ln(x)).
And ln(x<0) is undefined.
Nov7-12, 07:56 PM   #3
http://www.wolframalpha.com/input/?i=f%28x%29+%3D+x%5Ex
If you look at the graph of the function itself (without plugging anything in) you will see that it shows that at x=-1 it is imaginary.
Nov7-12, 10:25 PM   #4
Quote by G.I. View Post
f(x)=exp(x*ln(x)).
ln (-x) = ln(x) + [itex]i \pi[/itex]
Quote by tahayassen View Post
Let f(x)=(x)^(x)
http://www.wolframalpha.com/input/?i=%28-1%29^%28-1%29
It says "negative 1". :)
Nov7-12, 11:29 PM   #5
Recognitions:
Quote by Best Pokemon View Post
That graph show that the imaginary part of f(-1) is 0 and that the real part is -1. That is, f(-1) = -1 + 0i.
It's as the first reply said, f(x)=x^x is not (in general) a real valued function for x<0, though it is real for the negative integers.
Nov8-12, 07:56 AM   #6
So it's a matter of limitations of computers/programming that x<0 doesn't exist for the real-valued plot? Why does the real part for x<0 exist on the complex-valued plot?
Nov9-12, 12:16 AM   #7
Remember x^x = (e^(log(x)))^x = e^(x*log(x))
log (-x) = log(x) + [itex]i\pi[/itex]
This means that you'll have the magnitude x^(-x), and the angle x*i*pi.
With the angle you'll have:
cos (x*pi) * x^(-x) for the real portion and
sin (x*pi) *x^(-x) for the imaginary portion.
Correct this if I made a mistake.. tired. :)
Nov10-12, 04:53 AM   #8
Knowing that [itex]z=r\exp(i\theta + 2ki\pi)[/itex] where [itex]r=|z|=\sqrt{\Re^2(z)+\Im^2(z)}[/itex], [itex]\theta=\mathrm{arg}(z)=\mathrm{atan2}(\Im(z),\Re(z))[/itex] and k is an arbitrary integer, one has [itex]\log(z)=\log(r) + i\theta + 2ki\pi = \log|z| + i\mathrm{arg}(z) + 2ki\pi[/itex]. Now, we consider our function for an arbitrary negative integer, with the principal branch of the complex logarithm (k=0):
[tex](-x)^(-x) = \exp((-x)\log(-x)) = \frac{1}{\exp(x\log(-x))} = \frac{1}{\exp(\log(x)+xi\pi)}=
\frac{1}{x(\cos(x\pi)+i\sin(x\pi))}[/tex]
Now, note that if x was not an integer, we would be stuck here. However, we know for integer x, [itex]\cos(x\pi) = (-1)^x[/itex] and [itex]\sin(x\pi) = 0[/itex], which leaves us with our final answer:
[tex] = \frac{1}{x(-1)^x}[/tex]
So why did I go through this? I wanted to show why Wolfram does not display the graph for [itex]x \leq 0[/itex]. The function is defined as a real value only in the positive reals and the negative integers. For negative reals, we get the ugly-looking answer [itex]\displaystyle \frac{1}{x(\cos(x\pi)+i\sin(x\pi))} = \frac{\cos(\pi x)-i\sin(\pi x)}{x}[/itex], which can't be simplified further.
Nov10-12, 05:11 PM   #9
Recognitions:
Let f(x)=(x)^(x)
f(-1)=(-1)^(-1)
=1/-1
=-1
this answer is correct
Nov10-12, 09:55 PM   #10
Quote by Millennial View Post
I saw the graph on Wolfram Alpha. Really nice pretty one if you constrain the x variable:
http://www.wolframalpha.com/input/?i...tupperrange---
Note... I am a fan of the Alpha. I also think the borderline ASD having character in Alphas is pretty awesome... and hilarious. Do you like strange tangents? :p
It's actually (so you don't confuse people- look at the first post):
[tex]\dfrac{\cos(\pi x)-i\sin(\pi x)}{x^x}[/tex]
or (rewritten version of my post above your post):
[tex]{x^{-x}}\times \left({\cos(\pi x)-i\sin(\pi x)}\right)[/tex]
New Reply
Thread Tools
Similar Threads for: Why does the graph of x^x undefined for x is less than or equal to 0?
Thread Forum Replies
Pythagorean Triangles with one side equal s and hypothenuse equal 2 s+1 Linear & Abstract Algebra 7
Does one raised to an undefined power "equal" anything? General Math 21
Why does the slope of a PT Graph equal the VT graph? Introductory Physics Homework 4
In two equal complex numbers, what parts are equal to each other? Calculus 17
Equal areas in equal times Calculus & Beyond Homework 3
