New Reply
Linear System Transformations
Share Thread Thread Tools
Nov21-12, 08:02 PM   #1
Hi there,
I have a linear algebra question relating actually to control systems (applied differential equations)
for the linear system
[itex]
{\dot{\vec{{x}}} = {\bf{A}}{\vec{{x}}} + {\bf{B}}}{\vec{{u}}}\\
A \in \mathbb{R}^{ nxn }\\
B \in \mathbb{R}^{ nx1 }\\
[/itex]
In class, we formed a transformation matrix P using the controllability matrix [itex] M_c [/itex] as a basis (assuming it is full rank).
[itex]
M_c = [ {\bf{B \;AB \;A^2B\;....\;A^{n-1}B}}]
[/itex]
and there is a second matrix with a less established name. Given that the characteristic equation of the system is [itex] |I\lambda -A| = \lambda^n + \alpha_1 \lambda^{n-1} +... + \alpha_{n-1}\lambda + \alpha_n= 0 [/itex], we then construct a second matrix, call it M_2, which is given below.
[itex]
{\bf{M}}_2 =
\begin{bmatrix}
\alpha_{n-1} & \alpha_{n-2} & \cdots & \alpha_1 & 1 \\
\alpha_{n-2} & \cdots & \alpha_1 & 1 & 0 \\
\vdots & \alpha_1 & 1 & 0 & 0\\
\alpha_1 & 1 & 0 & \cdots & 0\\
1 & 0 & 0& \cdots & 0 \\
\end{bmatrix}
[/itex]
then the transformation matrix is then given by
[itex]
P^{-1} = M_c M_2
[/itex]
and then applying the transformation always gives.. and this is what I don't understand....
[itex]
{\overline{\bf{A}}} = {\bf{PAP}}^{-1} =
\begin{bmatrix}
0 & 1 & 0 & \cdots & 0 \\
0 & 0 & 1 & \cdots & \vdots \\
\vdots & \vdots & 0 & 1 & 0\\
0 & 0 & \cdots &0& 1\\
-\alpha_{1} & -\alpha_{2} & \cdots & -\alpha_{n-1}& -\alpha_{n}\\
\end{bmatrix}
[/itex]
Now I'm just looking for intuition is to why this is true. I know that this only works if the controllability matrix is full rank, which can the be used as a basis for the new transformation, but I don't get how exactly the M_2 matrix is using it to transform into the canonical form.... Can someone explain this to me? thanks...
Disclaimer: I posted this in another PF subforum, but I think I might do better in this section.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Tags
control systems, linear algebra, odes
Thread Tools
Similar Threads for: Linear System Transformations
Thread Forum Replies
Linear Algebra question regarding Matrices of Linear Transformations Calculus & Beyond Homework 2
Linear Functionals, Dual Spaces & Linear Transformations Between Them Linear & Abstract Algebra 8
Another linear algebra problem, basis and linear transformations. Calculus & Beyond Homework 7
Linear Algebra - Linear Transformations, Change of Basis Calculus & Beyond Homework 3
Linear Algebra (Vector spaces, linear independent subsets, transformations) Calculus & Beyond Homework 12
