| New Reply |
The uniqueness of a magnet? Let me tell you why. |
Share Thread | Thread Tools |
| Nov24-12, 04:47 PM | #1 |
In all of the things that we've discovered have you ever found something as amazing like a magnet? An object that can attract/repel (by using force!) on its own similar other magnets or metals. The only object present to withhold a significant amount (depending on type,size,etc...) of force! Without applying anything to it. Many of you would say that its similar to a spring, well it is in someways but in reality completely different, the reason why most of you compare the two is to show a few facts about energy.
When you bring to of those objects and look at them, CLEARLY a magnet has the full capability to attract any metal/magnet near by and applying force BY its own(forget the point of "you" putting the magnet/metal there) It also repels by its own, now how can you compare it to a spring? A spring on the other hand stays there doing nothing... ONLY when you apply force to it directly and leave it be... It acts by its own. but only then you'd find an act from the spring! However, again I remind you that a magnet has a force of its own mind you, why can't aren't we amazed significantly at this feature? And when you say that it has no energy, in fact it does(potential energy). It attracts/repels a magnet, that is force applied to a magnet within a distance = W = Fd , and when attracted by a magnet or repeled or even attracts a metal, let me remind you of its "potential" state converted into "kinetic". (Simplest way to describe it without going into detail.) Im a man fascinated by electromagnetism specifically: Magnets, and their wonderful feature of having a force packed inside that some of them can lift 10x or 100x or 1000x of its own weight. HOW REMARKABLE IS THAT! Let the discussion begin! Miyz, |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov24-12, 05:55 PM | #2 |
Is magnetism more remarkable than the electric forces that keep solids together - even the magnet to which you refer? A simple wall plug can support a million times its own weight when installed correctly. (Ancient Rawlplug advert I read once.)
| Nov25-12, 04:08 AM | #3 |
If you leave a Neo.magnet for example, on a table with no interference, good cool temperature, its force could last to 100 years... A wall plug will need that electric force to stay flowing supported by an energy source that requires its input to be fed continuously. Thats just mind blowing to me right there... |
| Nov25-12, 04:40 AM | #4 |
The uniqueness of a magnet? Let me tell you why.It's a rawlplug with the electrical forces that hold the wall together and the plug.No electrical input needed. |
| Nov25-12, 05:46 AM | #5 |
Recognitions:
It's the UK/US English problem. I got confused myself, had to look it up. In US, wall plugs are known as screw anchors.
| Nov25-12, 05:54 AM | #6 |
| Nov25-12, 05:55 AM | #7 |
K2, what do you have to add? Do you find anything interesting about "magnets"?
| Nov25-12, 05:57 AM | #8 |
Recognitions:
Not really, no. It just tells me what an enormous amount of potential electrostatic force there is entombed in matter due to positive and negative charges canceling out, if a tiny "leak" due to relativistic corrections can result in quite a significant amount of force between magnets. It's not really something special about magnets themselves, as it is about matter overall.
| Nov25-12, 06:13 AM | #9 |
True that its something in matter. However, isn't this phenomenon present and obviously shown in magnets? Doesn't that indicate something "special". I always remind you all the "permanent" feature they have, that causes that "force" to be present over a long period of time is very remarkable. |
| Nov25-12, 06:24 AM | #10 |
| Nov25-12, 06:26 AM | #11 |
Ouch! a major failure of understanding... Ow well hope you all understood my point though! |
| Nov25-12, 06:29 AM | #12 |
I think permanent magnets are so attractive (pun not intended so I'll leave it in there) to us because of their 'Novelty Value'. They are 'exceptions' to what we normally observe around us and the force they can produce is much greater than the electrostatic forces that you get by rubbing plastic etc..
Those new Neo magnets are unbelievable to us old codgers but the new generation will just take them for granted - as we all take colour TV and TByte hard drives for granted these days. |
| Nov25-12, 06:37 AM | #13 |
Do you know that when I heard of magnets my reactions was like this: Meh. So? Back then I loved physics but never really considered to pursue it as a career and a major tool in life. But when I did, studied electromagnetism, magnets, energy many things and just stood their mind blown at this amazing small little shiny disc. |
| Nov25-12, 06:41 AM | #14 |
I find magnets fascinating too, but more so by the magnetic field. Interaction between magnets is basically two magnetic fields attracting/repeling each other.
I have always wondered if "something" exists within the space of the magnetic/electric field. |
| Nov25-12, 06:42 AM | #15 |
Knowing that two of these bad boys alone can lift a CAR! That alone just left me saying: Whaaaaaaaat!
And yet people would tell me to not bother because they aren't "that" significant. |
| Nov25-12, 06:51 AM | #16 |
| Nov25-12, 07:08 AM | #17 |
There is a story that, when asked which was the greater, the Sun or the Moon, a Greek philosopher said that the Moon was far greater because it shone at night, when it was dark. The Sun was far less impressive because it shone in the day, when it was light anyway. Familiarity can breed contempt. |
| New Reply |
| Thread Tools | |
Similar Threads for: The uniqueness of a magnet? Let me tell you why.
| Thread | Forum | Replies | ||
| Can a magnet's magnetic field perform work on another magnet? | Classical Physics | 269 | ||
| Can the force exerted by a perm magnet be equated to electro magnet watts? | General Physics | 3 | ||
| Why is the permament magnet not completely attracted to the superconducting magnet? | General Physics | 2 | ||
| How to prove uniqueness (or non-uniqueness) of solution | Differential Equations | 1 | ||
| Would running an electrical current through a magnet destroy the magnet? | General Physics | 4 | ||
