Magnet in a Pipe: Meisner Effect?
  • Context: Graduate
  • Thread starter Thread starter cragar
    Magnet Pipe
The discussion centers on the behavior of a magnet placed in an infinitely long superconducting pipe, specifically examining the Meissner effect and its implications in a constant gravitational field. It is established that the magnet will initially drop slightly until the superconductor generates a magnetic field strong enough to counteract gravity. The conversation also explores the effects of holding the magnet stationary and the potential movement of the magnet when a marble is shot off it, concluding that the magnet will eventually come to rest. The possibility of using a stronger magnet to induce the same current without movement is also considered.
  • Understanding of the Meissner effect in superconductors
  • Familiarity with Lorentz force and its implications
  • Basic knowledge of gravitational fields and their effects on objects
  • Concept of magnetic field generation in superconductors
  • Research the Meissner effect in detail and its applications in superconductivity
  • Study the principles of Lorentz force and its role in electromagnetic systems
  • Explore the behavior of superconductors under varying gravitational conditions
  • Investigate the effects of different magnet strengths on superconducting materials
Physicists, electrical engineers, and students studying superconductivity and magnetism, particularly those interested in the practical applications of the Meissner effect and electromagnetic theory.
cragar
Lets say I have a superconducting pipe that is infinitely long.
Now I place a magnet in the pipe, will the magnet stay placed in the pipe due to the meisner effect? And the magnet is in a Constant gravitational field.
And the pipe is vertical in the G field.
I'm pretty sure it will drop slightly, until it causes the superconductor to produce a sufficiently strong magnetic field on the inside to support the magnet against gravity.
Even if the magnet is light it will need to move a little bit so the Lorentz force can push the electrons and create a strong enough current. What If I hold the magnet there fore a little
bit and then let go, will it move a little bit.
And ok let's assume the magnet is stationary in the pipe, now I shoot a marble off of it,
will the magnet move a little bit and then come back to a stationary position or will it continue down the tube. It seems like it will eventually come to rest.
It seems like it might not need to move down the pipe to be held up.
What If I had a stronger magnet that weighed the same and just the presence of the magnet created that same current in the pipe as the weaker one did with the movement, it seems like it would be held up right away without any movement?
  • · Replies 59 ·
15K
  • · Replies 16 ·
