| New Reply |
Partial derivatives after a transformation |
Share Thread | Thread Tools |
| Nov25-12, 04:27 AM | #1 |
Suppose I have a transformation
[tex](x'_1,x'_2)=(f(x_1,x_2), g(x_1,x_2))[/tex] and I wish to find [tex]\partial x'_1\over \partial x'_2[/tex] how do I do it? If it is difficult to find a general expression for this, what if we suppose [itex]f,g[/itex] are simply linear combinations of [itex]x_1,x_2[/itex] so something like [itex]ax_1+bx_2[/itex] where [itex]a,b[/itex] are constants? |
| Nov25-12, 05:39 AM | #2 |
[tex]x'_1=f(x_1,x_2)[/tex] [tex]x'_2=g(x_1,x_2)[/tex] [tex]x_1=F(x'_1,x'_2)[/tex] [tex]x_2=G(x'_1,x'_2)[/tex] Then, we clearly have, for example the identity: [tex]x'_1=f(F(x'_1,x'_2),G(x'_1,x'_2))[/tex] Since the pair of marked variables (and the unmarked) are independent from each other, we have the requirement on the functional relationship: [tex]\frac{\partial{x}_{1}^{'}}{\partial{x}_{2}^{'}}=0=\frac{\partial{f}}{\p artial{x}_{1}}\frac{\partial{F}}{\partial{x}_{2}^{'}}+\frac{\partial{f} }{\partial{x}_{2}}\frac{\partial{G}}{\partial{x}_{2}^{'}}[/tex] |
| Nov25-12, 06:44 AM | #3 |
Suppose you have, say:
x=u^2-v^2 y=u+v How can you utilize those implied requirements in the previous post to derive the the correct representations of u and v in terms of x and y? Note that in this case, it is fairly trivial to find it by algrebrac means; dividing the first relationship by the second, we have x/y=u-v, and thus: u=1/2(x/y+y), v=1/2(y-x/y) However, using instead the four identities gained from the above requirements, we have [tex]\frac{\partial{x}}{\partial{x}}=1=2u\frac{\partial{u}}{\partial{x}}-2v\frac{\partial{v}}{\partial{x}}[/tex] [tex]\frac{\partial{x}}{\partial{y}}=0=2u\frac{\partial{u}}{\partial{y}}-2v\frac{\partial{v}}{\partial{y}}[/tex] [tex]\frac{\partial{y}}{\partial{y}}=1=\frac{\partial{u}}{\partial{y}}+\frac {\partial{v}}{\partial{y}}[/tex] [tex]\frac{\partial{y}}{\partial{x}}=0=\frac{\partial{u}}{\partial{x}}+\frac {\partial{v}}{\partial{x}}[/tex] from these, you should be able to derive the above relations. Note, for example, that by combining the first and fourth and the known relation y=u+v, you get: [tex]\frac{\partial{u}}{\partial{x}}=\frac{1}{2y}[/tex] meaning that we must have u(x,y)=x/2y+h(y), where h(y) is some function of y. Applying the fourth, you get v(x,y)=b(y)-x/2y, for some b(y) By using known and gained information, you will be able to determine h(y) and b(y) from the second and third relationships. |
| Nov25-12, 11:38 AM | #4 |
Thank you, arildno.
| New Reply |
| Tags |
| pde |
| Thread Tools | |
Similar Threads for: Partial derivatives after a transformation
| Thread | Forum | Replies | ||
| ODE now made me think about derivatives and partial derivatives | Calculus & Beyond Homework | 6 | ||
| Relating 2nd order partial derivatives in a coordinate transformation. | Calculus & Beyond Homework | 3 | ||
| derivatives / partial derivatives rule | Calculus & Beyond Homework | 7 | ||
| Chain rule: partial derivatives transformation | Calculus & Beyond Homework | 3 | ||
| estimating partial derivatives/directional derivatives | Calculus & Beyond Homework | 1 | ||
