Confused about Taylor Expansion Strategy
The discussion revolves around the use of Taylor expansions, specifically comparing the expansions of the functions (1-x)-2 and e-Ax2. Participants explore the differences in approach and reasoning when applying Taylor series to these functions, particularly around the point x=0.
  • One participant expresses confusion about the different treatments of the functions (1-x)-2 and e-Ax2 when expanding them using Taylor series.
  • It is noted that for (1-x)-2, the derivatives can be taken directly, while for e-Ax2, there seems to be a substitution of Ax2 for x in the expansion process.
  • Another participant explains that the Maclaurin series for eu can be derived by substituting values into the series, suggesting a straightforward substitution method.
  • A question is raised about the application of the chain rule when differentiating functions like e3x and why it appears unnecessary in the context of Taylor series expansions.
  • One participant emphasizes the importance of ensuring that all terms of a given order are included when composing series for nested functions.
Participants express varying levels of understanding regarding the application of Taylor expansions, with some agreeing on the substitution method while others question its consistency with differentiation rules. The discussion remains unresolved regarding the treatment of derivatives and substitutions in Taylor series.
There are unresolved questions about the application of the chain rule in the context of Taylor series and how substitutions affect the differentiation process. Participants highlight the need for clarity on these points without reaching a consensus.
The Head
In many of my physics classes we have been using Taylor Expansions, and sometimes I get a bit confused. For example, I feel like different things are going on when one expands (1-x)^-2 vs. e^(-Ax^2), where I just have some constant in front of x^2 to help make my point. To keep things simple, I will expand around x=0.
In the first case, it seems pretty simple to me. You just take the derivatives of (1-x)^2, plug in 0 for x, and multiply each term by (x^n)/n! to get 1+x^2+(x^4)/2 +...
In the second case, Wolfman says the answer is 1 - (Ax^2) + ((Ax^2)^2)/2 - ...
What I am confused about is why you essentially are replacing x with the entire value of Ax^2. To me, strictly using the formula, it seems like the second term should be the first derivative (-2x)*e^(-Ax^2), all evaluated at x=0, and then multiply by x. It seems as if instead we are sort of setting Ax^2 to x and then saying the derivative evaluated at 0 of our function is =1*e^(0), and then multiplying by the whole -Ax^2.
I could probably figure out the pattern of problems like this, but I really don't get why these problems are different and why you are allowed to treat them (what appears to me, but probably isn't) differently. I am guessing it has something to do with the fact that there are two terms in the first case, together raised to the second power, whereas this isn't the case in the second situation, but it is all rather nebulous to me.
I appreciate any input-- thank you!
The Maclaurin series (a Taylor series at a = 0) for eu is 1 + u + (1/2!)u2 + ... + (1/n!)un + ...
If you want the Maclaurin series for e3x, just substitute 3x for u in the series above. That's all they're doing. IOW,
e3x = 1 + 3x + (1/2!)(3x)2 + ... + (1/n!)(3x)n + ...
Thanks for the reply. One thing to clarify, in the e^(3x) case, you have f(u)*u^0 + 1*f'(u)*u^1 +0.5*f''(u)*u^2...
All the derivatives are evaluated at u=0 in the case we are discussing, but could be non-zero. But if u=3x, and you are taking some derivative of u, why don't you have to use the chain rule (df/du)*(du/dx)? If you try to differentiate e^3x, you can make the substitution u=3x so you have e^u, but in this case, you can't just say du is 1, you have to use the chain rule.
Why is it different with Taylor & Maclaurin series?
Equal things must be equal. If the series is to be valid we must have
if h=f(g(x))
and F,G,H are the series for f,g,h respectively
H(x)=F(G(x))
Then if we require the series we can compute the side of the equation that is more convenient. This holds for the series and for truncations if we make sure that all terms of a given order are included.
  • · Replies 19 ·
