New Reply
Metal disk problem!
Share Thread Thread Tools
Nov29-12, 12:32 PM   #1
Metal disk problem!
1. The problem statement, all variables and given/known data
A uniform metal disk (M = 8.21 kg, R = 1.88 m) is free to oscillate as a physical pendulum about an axis through the edge. Find T, the period for small oscillations.
2. Relevant equations
[itex]I = mr^{2}/4[/itex]
[itex]T = 2\pi √(I/mgd)[/itex]
3. The attempt at a solution
I combined the formula together to get:
[itex]T = 2\pi √((mr^{2}/4)/(mgr))[/itex]
[itex]T = 2\pi √(r/(4g))[/itex]
But the answer is incorrect
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov29-12, 01:24 PM   #2
Mentor
Quote by NasuSama View Post
How did you arrive at this result?
Nov29-12, 01:56 PM   #3
Quote by Doc Al View Post
I am thinking that I need to use the moment of inertia of the disk.
Nov29-12, 02:15 PM   #4
Mentor
Metal disk problem!
Of course you do, but that's not the correct formula.
Nov29-12, 06:29 PM   #5
Then, it's something like I = mrČ/2, rotating to its center. However, the disk oscillates through its edge.
I am not sure which path to go for...
Nov29-12, 06:31 PM   #6
Mentor
Right.
Use the parallel axis theorem. (Look it up!)
Nov29-12, 07:01 PM   #7
Right.
Hm.. By the Parallel Axis Theorem, I would assume that:
[itex]I = I_{center} + md^{2}[/itex]
[itex]I = mr^{2}/2 + mr^{2}[/itex] [Since the disk rotates about an axis through the edge, we must add the inertia by mrČ. r is the distance between the center and the edge of the disk.]
[itex]I = 3mr^{2}/2[/itex]
Is that how I approach this? Let me know where I go wrong. Otherwise, I can just plug and chug this expression:
[itex]T = 2\pi √((3mr^{2}/2)/(mgr))[/itex]
[itex]T = 2\pi √(3r/(g))[/itex]
Nov29-12, 07:18 PM   #8
Nvm. My answer is right. Thanks for your help by the way!
Nov29-12, 07:33 PM   #9
Mentor
Good!
New Reply
Thread Tools
Similar Threads for: Metal disk problem!
Thread Forum Replies
Thermal expansion of a metal round disk with hole in the middle General Physics 3
Would metal hitting metal or metal hitting glass make more noise? General Discussion 3
Spinning Disk Problem Introductory Physics Homework 2
Hard Disk Problem Computing & Technology 2
