| Thread Closed |
Have I found the world's first endless source of energy? |
Share Thread |
| Dec5-12, 01:00 AM | #1 |
| Dec5-12, 01:02 AM | #2 |
how will you prevent the water from leaking out of your one-way valve? :-)
I think the friction at that point will counteract any energy. There's a historical scam I saw recently called the Keely machine (mysteries of the museum show on US cable) for intersting reading: http://en.wikipedia.org/wiki/John_Ernst_Worrell_Keely It was later found that he had a pump hidden in another room powering the device. |
| Dec5-12, 01:08 AM | #3 |
| Dec5-12, 01:13 AM | #4 |
Recognitions:
Have I found the world's first endless source of energy?So the construction is absolutely possible. That's not the problem. The problem is that the float only floats when surrounded by liquid from all directions. What happens to the float that's passing into the container through the iris? Well, it experiences full pressure of the fluid from above and none from below. The net force will be down. It's very easy to show that no matter how many floats are in the fluid above it, the downward force on the bottom float will always be greater. (To fit more floats, you need a higher water column, resulting in higher pressure on bottom float.) The conservation of energy actually becomes immediately apparent if you try to figure out how much work you need to do against the float to push it into the fluid through the bottom valve/iris. The amount of energy needed to take the float from outside and put it at the bottom of container is exactly the same regardless of whether you force the float into liquid from above or from bellow. The difference of potential energies in two situations is exactly the same, and so the energy requirement is the same regardless of path. Long story short, the machine can't work, which really shouldn't be a surprise. |
| Dec5-12, 01:20 AM | #5 |
![]() Well done! Truth is my teacher gave us that riddle in class to see how well we remembered hydraulics (turned out we didn't, heh), I just thought it was cool and wanted to have the full explanation written down, so I decided to post it here in the fashion that I did ![]() Thanks for playing along and for providing it
| Dec5-12, 01:27 AM | #6 |
Recognitions:
If you don't mind me asking, what language is that, besides English and Russian?
| Dec5-12, 01:39 AM | #7 |
| Dec5-12, 01:56 AM | #8 |
Recognitions:
I also have some trilingual friends, and they would be upset with me for not recognizing it.
| Dec5-12, 11:23 AM | #9 |
I recognized the font and can understand every language known except Greek :-)
| Dec5-12, 11:35 AM | #11 |
| Dec5-12, 11:51 AM | #12 |
Mentor
Please re-read the Rules link at the top of the page. There is a section on banned topics, and they include discussions of perpetual motion machines (PMMs).
Thread is locked. |
| Dec5-12, 12:18 PM | #13 |
Mentor
BTW, here is the text from the Rules link that lists PMM discussions. Note the helpful links which you can use to answer your schoolwork question on this banned topic:
| Thread Closed |
Similar discussions for: Have I found the world's first endless source of energy?
| Thread | Forum | Replies | ||
| End of the World Cancelled - New Mayan Calendar Found | General Discussion | 10 | ||
| A Source of Anti Matter found | Cosmology | 5 | ||
| where gems are found in the world | Earth | 2 | ||
| How are Differential Equations usually found in real world applications? | Differential Equations | 4 | ||
| Antarctica 'Lost World' Found | Earth | 2 | ||
