Study the continuity of this function
The discussion revolves around studying the continuity of a function defined by a limit as n approaches infinity, specifically the expression \(\lim_{n \to \infty} \frac{n^x - n^{-x}}{n^x + n^{-x}}\). Participants explore various values of x and their implications on the limit and continuity of the function.
  • Participants attempt to evaluate the limit for specific values of x, questioning the behavior of the function at x=0 and as x approaches infinity. There are discussions about the implications of the form \(\frac{\infty}{\infty}\) and whether it indicates discontinuity.
The discussion is active, with participants sharing their findings and questioning each other's reasoning. Some have suggested that the function is continuous for all real numbers except at x=0, while others are exploring the limits for negative values of x and the implications of different forms encountered in the limit.
Participants note the complexity of limits involving infinity and express uncertainty about how to handle cases where algebraic manipulation does not yield a clear result. There is an emphasis on the need for further exploration of specific values to draw conclusions about continuity.
Felafel
Study the continuity of the function defined by:
## \lim n \to \infty \frac{n^x-n^{-x}}{n^x+n^{-x}}##
3. The Attempt at a Solution
I've never seen a limit like this before.
The only thing I have thought of is inserting random values of x to see it the limit exists.
For instance, in this case, for x=0 I'd have ##\frac{\infty^0-\infty^0}{\infty^0+\infty^0}##
which means the function doesn't exist. but every other value of x, it's okay.
Or am i supposed to solve the limit? (btw, how can I solve a limit for n to infinity??)
thank you
By definition, [itex]n^0 = 1[/itex] for any nonzero [itex]n[/itex], so your fraction reduces to
[tex]\frac{n^0 - n^0}{n^0 + n^0} = \frac{1 - 1}{1 + 1} = \frac{0}{2} = 0[/tex]
What does this imly about the limit
[tex]\lim_{n \rightarrow \infty} \frac{n^0 - n^0}{n^0 + n^0}[/tex]?
well, I'd say it means the limit exists and it is = 0 (because I can evaluate it before adding the infinities in the equation).
so the function should continuos on all ##\mathbb{R}##.
Or actually, how should i work for x→∞?
sorry if i have so many doubts about a simple question, but i have never seen this kind of limits before
It's not that hard. You just have to think through all the cases. Suppose x=1. Try and figure it out without just substituting 'infinity' for n. That's not very informative. Just put x=1.
ok.
I see that whatever x i choose (except x=0), I always get a 0 in the nominator and an infinity in the denominator, so appartently f(x)=0. But I'm not sure about that..
Felafel said:
ok.
Let's take a simple concrete case, say x = 1. Then
[tex]\frac{n^x - n^{-x}}{n^x + n^{-x}} = \frac{n - 1/n}{n + 1/n} = \frac{1 - 1/n^2}{1 + 1/n^2}[/tex]
What is the limit of this expression as [itex]n \rightarrow \infty[/itex]?
for x=1 the limit is 1.
and for x=2 as well, because
##\frac{n^2-n^{-2}}{n^2+n^{-2}}##dividing both members by## \frac{1}{n^2} =\frac{1-\frac{1}{n^4}}{1+\frac{1}{n^4}}## and so forth ##\forall x \in \mathbb{R}## except x=0, where f(x)=0.
Then, can i say it is continuos on all |R except between 0 and 1?
You'd better try some more x values before you state a conclusion. What about x=(1/2) or x=(-1)?
Ok.
I've tried several values and found out that if
##x>0 \Rightarrow f(x)=1##
##x=0 \Rightarrow f(x)=0##
##x<0 \Rightarrow \lim f(x)= \frac{\infty}{\infty}## so the function doesn't exist there
Also, it is discontinuos in 0.
Are my assumptions right?
Felafel said:
Ok.
Can you show how you reached that conclusion for x<0? Try x=(-1). infinity/infinity doesn't necessarily mean the limit is undefined.
for x=-1 I get
## \frac{1-\frac{1}{n{^-2}}}{1+ \frac{1}{n^{-2}}}##
##\frac{1-n^2}{1+n^2}= \frac{\infty}{\infty}##
If ##\frac{\infty}{\infty}## doesn't mean it's undefined, when can i say the function is discontinuos?
Felafel said:
for x=-1 I get
Divide numerator and denominator by n^2.
right, i didn't notice it, then for x<0 i get f(x)=-1.
what can i say if i get ##\frac{\infty}{\infty}##? and when can i say that the function is not continuos, if that's not enough?
You can't say anything just from looking at ##\frac{\infty}{\infty}##. A form like that might have a limit and it might not. Ok so f(x)=(-1) for x<0, f(0)=0 and f(x)=1 for x>0. What about continuity?
well, as the right limit is different from the left one, I'd say 0 is a discontinuity point (the only one in R).
fortunately, there are no infinity/infinity cases in this function. but if one of these cases happens with a similar limit, should i just leave it? (if algebric manipulation can't help)
thank you very much for your help, anyway :)
Yes, it's discontinuous only at 0. Leaving a limit as ∞/∞ is about the same thing as saying 'I don't know what the limit is'. If algebra doesn't help you resolve it then there are other tools like l'Hopital.
  • · Replies 40 ·
