Register to reply
Mass of the moon?
by wasi-uz-zaman
Tags: mass, moon
Share this thread:
wasi-uz-zaman
#1
Dec30-12, 06:53 AM
P: 40
hi, i can calculate the distance of moon from the earth and its diameter - but i could't get the formula by which i can calculate the mass of the moon - although i can calculate the mass of the moon by assuming it has same average density that of earth -
Phys.Org News Partner Astronomy news on Phys.org
Exoplanet measured with remarkable precision
New star catalog reveals unexpected 'solar salad'
RXTE satellite decodes the rhythm of an unusual black hole
mfb
#2
Dec30-12, 08:11 AM
Mentor
P: 11,815
The orbital period of the moon depends on its distance and the sum of masses of earth and moon - if you can determine this sum with sufficient precision, you can subtract the mass of earth and get the mass of moon.
Satellites orbiting the moon are a better way to determine its mass - they give direct access to the gravitational acceleration at a specific distance, together with the gravitational constant this can be used to calculate its mass.
wasi-uz-zaman
#3
Jan2-13, 11:37 AM
P: 40
but how do i calculate the sum of earth and moon mass?
mfb
#4
Jan2-13, 11:59 AM
Mentor
P: 11,815
Mass of the moon?
Measure distance, orbital period and the gravitational constant.
##M+m=\frac{4\pi^2a^3}{GT^2}## with the semi-major axis a (for a circular orbit, this would be the distance)
BobG
#5
Jan4-13, 07:28 PM
Sci Advisor
HW Helper
BobG's Avatar
P: 2,280
I'm curious as to how you calculated the distance between the Moon and Earth. That distance might not be the semi-major axis of the Moon's orbit. It might be the sum of the Moon's semi-major axis and the Earth's semi-major axis, as measured from their combined center of mass. (The 'a' in the previous equation is actually the sum of the semi-major axes, or the distance you most likely calculated.)
In practice, calculating the mass and the semi-major axis of planets was an almost impossible task even after Newton turned Kepler's Third Law into a formula. You had a formula containing three unknown variables (the universal gravitational constant, the mass, and the semi-major axis) and the only known was the orbital period.
In fact, that's why the Earth's semi-major axis for it's orbit around the Sun was measured in astronomical units, with one AU being the distance between the Sun and the Earth. You could measure Jupiter's semi-major axis in AU's, but had no way to convert that into a more traditional measure such as kilometers.
Register to reply
Related Discussions
Mass of man-earth vs moon Introductory Physics Homework 1
Moon Mass Concentrations Astronomy & Astrophysics 1
Center of mass of the earth and the moon Classical Physics 18
Mass of the moon Introductory Physics Homework 4
