New Reply
Why is Entropy a concave function of internal energy?
Share Thread Thread Tools
Jan14-13, 07:20 AM   #1
Hello
I may well be all wrong about this but I am trying to understand from a microscopic point of view why Entropy is a concave function of internal energy. I found this in the following .pdf:
http://physics.technion.ac.il/ckfind...potentials.pdf
I started from this wikipedia article and i understand why, if the particles composing the system have a limited number of available energy levels, then S(E) first increases and then decreases.
But saying that S(E) is concave should mean:
- when the temperature is T1, if i give a dE to the system its entropy increases of dS1
- when the tempereture is T2>T1, if I give the same dE to the system, its Entropy increases only of dS2 < dS1
I cannot see this with single particles.
If I have N particles in their lowest energy state there is only one microstate: all the particles are still.
If I give to this system the tiniest possible amount of energy, it will be taken by just one of the particle, so the possible microstates are N.
If I add another dE, the possible microstates should be N + N(N-1) = N^2 ... that is or one particle gets both dE or two different particles get it. Every time I add a dE I should increase the power of N.
Now, if the entropy is somehow proportional to the logarithm of the number of microstates, I should get S proportional to K ln(N^E), that is, something that is proportianl to E... taht is, no concavity
I am sure I am getting all this wrong... could you please help me understand this?
Thank You
Wentu
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan14-13, 07:27 AM   #2
Recognitions:
Quote by Wentu View Post
Where do you get the first N on the left hand side from?
Jan14-13, 07:49 AM   #3
The first N is for a single particle having 2*dE energy and all other particles ground energy
Jan14-13, 08:08 AM   #4
Recognitions:
Ah, ok. Shouldn't the second term should rather read N(N-1)/2?
Jan14-13, 08:14 AM   #5
You are right... I was considering distinguishble particles but this isn't enough, so yes, the term should be divided by 2. I wonder if this is enough to change the behaviour from linear to less-than-linear... I think the number of microstates still increases as a power with the increasing of E... but again, i could be all wrong
W.
New Reply
Tags
entropy, microstates, temperature
Thread Tools
Similar Threads for: Why is Entropy a concave function of internal energy?
Thread Forum Replies
Internal energy and thermodynamic entropy Classical Physics 7
Entropy and internal energy Introductory Physics Homework 6
Entropy, Adiabatic Conditions and Internal Energy Introductory Physics Homework 0
Internal energy vs. Enthalpy vs. Entropy Advanced Physics Homework 6
