Constructing a 1Hz 50 Hz 500 Hz 5Khz 30 Khz 50 khz Switching Device
by gedfire
Tags: 5khz, constructing, device, switching
gedfire
gedfire is offline
#1
Jan14-13, 01:40 PM
P: 14
Hello All,
I am thinking about pulsing the power from individual 9-12 volt Batteries @ the different frequencies of 1 Hz, 50 hz, 500hz 5 khz 30 khz and 50khz .
All I want to do is to create a pulse DC charge from a 9 volt or 12 volt battery.Car or Motor Cycle batteries are my targets.
I want to pulse this DC voltage using as little amperage as possible to a capacitor.Now I would also want to know what kind of protective device I could use to prevent the Super Capacitor (50F at 12 volts ) from over charging? Zener Diode, varistor,gas discharge tube etc? Please let me know the best components to use and if possible, the specifications based on the parameters I have outlined.
Can MOSFETS be used? If so how? The simplified version if possible please
Best regards,
Gary
Phys.Org News Partner Engineering news on Phys.org
A smart prosthetic knee with in-vivo diagnoses
Old tires become material for new and improved roads
Students take clot-buster for a spin
vk6kro
vk6kro is offline
#2
Jan14-13, 06:38 PM
Sci Advisor
P: 4,003
If you produce pulses that vary from 0 volts to 12 volts, then you can't overcharge your 12 V rated capacitor. Make it 10 volts to be safe.
You can generate a range of frequencies in many ways, but an easy way is to use a 555 chip. You can find a circuit that uses only one resistor and one capacitor if you use Google in image mode.
A MOSFET can be used to switch the current to the capacitor, but the voltage across the capacitor will not look like a pulse. It will be like a charging capacitor where the voltage is rising to the peak value of the input pulse.
You can limit the current by placing a suitable resistor in series with the capacitor.
Perhaps you could explain what you are trying to do?
berkeman
berkeman is offline
#3
Jan14-13, 10:10 PM
Mentor
berkeman's Avatar
P: 39,683
Quote Quote by gedfire View Post
Hello All,
Best regards,
Gary
You other similar thread and this one are very confused and confusing. Could you please say exactly what you are trying to do?
gedfire
gedfire is offline
#4
Jan18-13, 04:11 PM
P: 14
Quote Quote by vk6kro View Post
Hi,
Thank you for replying.You say I cannot overcharge a capacitor as long as I pulse it with a suitable voltage.I am pulsing it with a dc voltage through a diode.I thought the charge would accumulate until it passes the voltage rating and possibly explode?
I am trying to pulse charge a capacitor though a diode placed on one leg.
If you need anymore details please let me know.
Ged
gedfire
gedfire is offline
#5
Jan18-13, 04:14 PM
P: 14
Quote Quote by berkeman View Post
Thanks for stating your position.
I am trying to charge a capacitor through using a diode on one leg.Like this:
http://www.youtube.com/watch?v=B_f1p6V1Gb8
but with a solid state version like this:
http://www.youtube.com/watch?v=wBuXeanEFhY
In this video the capacitor voltage increased....what if the gentleman had allowed the charging to continue?
Hope this answers your questions.After charging the capacitor,I want to use it to power a load safely.
Thanks
Ged
vk6kro
vk6kro is offline
#6
Jan18-13, 07:28 PM
Sci Advisor
P: 4,003
Hi,
Ged
No, that can't happen.
The diode will only conduct if the voltage on its anode is more positive (by at least 0.7 volts) than the voltage on the cathode.
So, if the capacitor is already charged to, say, 11.3 volts, the voltage on the anode has to be at least 12 volts before the diode will conduct.
If the peak input pulse value is 12 volts, then charging will stop.
Register to reply
Related Discussions
Switching or not switching from Civil Engineering to Physics Career Guidance 6
Constructing Bijections Calculus & Beyond Homework 1
Constructing a function! Calculus 5
Constructing a category Linear & Abstract Algebra 2
