Register to reply
Drift velocity in a conductor
by guardaiinalto
Tags: conductor, drift, velocity
Share this thread:
guardaiinalto
#1
Jan21-13, 11:55 AM
P: 1
Dear all,
I have a question on the derivation of the drift velocity in a conductor, and was wondering if somebody could help me with it: drift velocity is the average velocity which a free charge moving in a conductor has due to the influence of an electric field applied to the conductor. In a metal, the free charge will be an electron. As they move through the conductor, electrons will frequently bump into ions. If τ is the mean free time of the electron, i.e. the time between successive collisions, then between two collisions, the action of an external electric field will make the electron accelerate by (E*e/m)*τ, where E is the strength of the field (and this strength is constant), e the charge of an electron, an m the mass of the electron.
Now, two sources I have consulted say that this quantity (E*e/m)*τ is equal to the magnitude of the drift velocity in the conductor. This appears to me to be false, since the quantity expresses the maximum speed gained by the electron, i.e. the speed it has just before it collides with the next ion. But drift velocity is supposed to be the average velocity of the electron due to the field, so I think its magnitude should be just one-half of this quantity.
Any help would be much appreciated.
Guardaiinalto
Phys.Org News Partner Physics news on Phys.org
A new, tunable device for spintronics
Watching the structure of glass under pressure
New imaging technique shows how cocaine shuts down blood flow in mouse brains
Drakkith
#2
Jan21-13, 11:33 PM
Mentor
Drakkith's Avatar
P: 11,875
Wouldn't it be the average magnitude since you are using T as the mean free time in your equation? If you average your time between collisions, then whatever you base off that time should already be an average I would think. Does that sound like it makes any sense?
sophiecentaur
#3
Jan22-13, 05:14 AM
Sci Advisor
Thanks
PF Gold
sophiecentaur's Avatar
P: 12,163
Quote Quote by guardaiinalto View Post
Dear all,
Guardaiinalto
I think you are not using the appropriate model for this. The drift velocity calculation just works on average density and rate of charge flow. The conduction electrons do not, as far as I know, 'hop from ion to ion', pausing on the way, at each one. They are never associated with any particular ion. There is a wide distribution of velocities, extending to very high values (greater than 10^6m/s, according to Wiki) and the mean drift velocity is only in the order of 1mm/s. Your description of accelerated motion, followed by a collision with an ion is more suited to conduction in low pressure gases, where mean free path is relevant to the energy gained by electrons on the way. The field in a metal is very very low and is much less relevant than the potential difference.
vanhees71
#4
Jan22-13, 10:30 AM
Sci Advisor
Thanks
P: 2,471
If you have a normal conductor, i.e., not a superconductor, then the usual classical model is that you have charges, freely movable around as in metals, where the conduction electrons are not bound to the ions of the lattice and thus free to move. "Free" is of course not really true, because there are always some defects by the lattice vibrations of the ions due to temperature and other defects in the crystal lattice of the metal and thus the conduction electrons will suffer some friction moving around.
Now putting an electric field across a conductor the motion of a fluid cell of conduction electrons is given by (in the non-relativistic limit!)
[tex]n \dot{\vec{v}}=- n e \vec{E} - \alpha \vec{v}.[/tex]
Here [itex]n[/itex] is the density of conduction electrons (particles per cubic metres), [itex]e \approx 1.6 \cdot 10^{-19} \text{As}[/itex] the elementary charge (=charge of a proton), [itex]\alpha[/itex] the friction constant.
In the stationary limit the right-hand side must be 0, i.e., the accelerating electric force must compensate precisely the friction force. Then [itex]\vec{v}=\text{const}[/itex] and thus
[tex]\vec{v}=-\frac{n e}{\alpha} \vec{E}.[/tex]
The current density is [itex]\vec{j}=-n e \vec{v}[/itex] and thus
[tex]\vec{j}=\frac{n^2 e^2}{\alpha} \vec{E}.[/tex]
This means the conductance of the metal is given in microscopic terms by
[tex]\sigma=\frac{n^2 e^2}{\alpha}.[/tex]
Independently from this simple classical microscopic picture of conductance, the drift velocity is easy calculated from the current through the conductor, which is given by
[tex]I=A |\vec{j}|=A n e |\vec{v}|\; \Rightarrow \; |\vec{v}|=\frac{I}{A n e}.[/tex]
Here, [itex]A[/itex] is the cross-sectional area of a not too thick wire, so that we can assume the current density to be homogeneous across the wire.
Take [itex]I=1 \; \text{A}[/itex] and a copper wire with cross-sectional area of [itex]1 \; \text{mm}^2=10^{-6} \text{m^2}[/itex]. For copper, in Wikipedia you find the value
[itex]n=8.5 \cdot 10^{28}/\text{m}^3.[/itex]
There you also find an explanation for how this value is obtained from the density and the atomic weight. This leads to
[tex]v=\frac{1 \text{A}}{10^{-6} \text{m}^2 8.5 \cdot 10^{28}/\text{m}^3 \cdot 1.6 \cdot 10^{-19} \text{A s}} \approx 7.3 \cdot 10^{-2} \frac{\text{mm}}{\text{s}}.[/tex]
The drift velocity in every-day applications is thus very very small.
sophiecentaur
#5
Jan22-13, 10:49 AM
Sci Advisor
Thanks
PF Gold
P: 12,163
@vanhees
You describe a "fluid cell of conduction electrons" and the way they behave - hitting defects and being subject to "friction" effects. But how does this take into account the far greater degree of random, thermal motion of the free electrons? Is it ok to say that the energy exchanges with the lattice due to all this activity just 'averages out' and is not relevant? That model looks fine if you ignore the majority activity of the electrons.
vanhees71
#6
Jan22-13, 01:04 PM
Sci Advisor
Thanks
P: 2,471
The thermal motion is homogeneous and isotropic in the restframe of the fluid cell and thus averages out when you take the spatial average over that fluid cell. Note that a fluid cell is small on the scale of the changes of the collective macroscopic degrees of freedom (here the change of the velocity of the conduction electrons with space) but large compared to the microscopic scales (like the mean free path of the electrons).
If you want to describe the electron's motion in more detail you have to go to another level of sophistication, e.g., Vlasov-Boltzmann or even Vlasov-Boltzmann-Uehling-Uhlenbeck transport equations. This is necessary in Plasma physics, when you have a dilute plasma, where the mean free path is not small compared to the macroscopic scales.
Register to reply
Related Discussions
[Drift velocity] Factors affecting velocity General Physics 1
Which is the correct Expression for Drift Velocity of Electrons in a conductor ? General Physics 0
Calculating drift velocity of electrons in a conductor Introductory Physics Homework 1
Relationship between current, drift velocity and thermal velocity General Physics 3
Drift Speed in a Conductor Introductory Physics Homework 2
