New Reply
Coherency and entanglement
Share Thread Thread Tools
Jan25-13, 11:19 AM   #1
Trying to understand coherence and entanglement and have some questions:
1. Do incoherent photons interfere?
a) Single particle interference through double slit
b) Multiple photons through double slit
Is it that the interference pattern in the above cases is not a clear fringe pattern however there is still interference?
2. Why does coherence increase when light is passed through a pin hole?
3. Why does brighter light have higher coherence?
4. What does coherence within a single photon mean?
5. Can coherence be changed (is it reversible) within the same photon?
i.e. Is entanglement changeable between two photons?
i.e. can the experimenter play with coherence and entanglement with the same set of entangled photons?
i.e. decrease coherence and watch the effect of increased entanglement, Increase coherence and watch the effect of decreased entanglement?
6. In a single particle, double -slit experiment are the wave-functions passing through each slit assumed to be entangled with each other? in the case of an "in-coherent" photon?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jan25-13, 01:10 PM   #2
mfb
Newcomer 2012
Recognitions:
Homework Helper Homework Help
What do you mean with "incoherent photons"?
There are no photons you can point to and say "this cannot have interference".
You can get interference effects with all light, but if the different photons in that light are not coherent (to each other!), you might be unable to notice this.
Depends on the setup. You select some specific part of your light, which might have some special properties (with the obvious one: "went through that hole").
This is not a general rule. It might depend on the setup.
What do you mean with that?
You can transfer entanglement between different photon pairs, and modify the entangled properties. If that does not answer your question, I don't understand it.
It is a single wave function.
New Reply
Thread Tools
Similar Threads for: Coherency and entanglement
Thread Forum Replies
Coherency matrix of partially polarized light incomplete? General Physics 3
Phase synchronization and coherency Electrical Engineering 0
question about entanglement and the chines photon polarazation entanglement experimen Quantum Physics 2
Angled electron reflection, coherency Quantum Physics 1
Proofread my mineralogy essay? More for structure/coherency than accuracy. Biology, Chemistry & Other Homework 0
