Understanding the Purpose of Infinite Gain in Ideal Opamps
  • Thread starter Thread starter jd12345
    Model Opamp
The discussion revolves around the purpose of infinite gain in ideal operational amplifiers (opamps), exploring its implications for circuit design, particularly in applications like differential amplifiers and impedance buffering. Participants examine the necessity of feedback in utilizing opamps effectively and the trade-offs involved in their design.
  • Some participants question why opamps are designed with infinite gain, suggesting it complicates their use without feedback.
  • Others propose that infinite gain allows for precise gain settings using external resistors, making the circuit's behavior less dependent on the opamp's internal characteristics.
  • A participant illustrates the use of high gain in an impedance buffer, arguing that high open-loop gain results in minimal steady-state error.
  • Some express confusion about the necessity of opamps for achieving certain gain configurations, suggesting that resistor networks could suffice.
  • Participants discuss the role of feedback networks, including reactive components, in tailoring gain and enabling non-linear circuit designs.
  • There are repeated requests for clarification on how high gain and feedback interact, indicating a lack of consensus on the underlying concepts.
Participants express varying levels of understanding regarding the role of infinite gain and feedback in opamp circuits. While some agree on the benefits of high gain for precision, others remain skeptical about the necessity of opamps for certain applications, leading to unresolved questions and differing viewpoints.
Some participants highlight limitations in understanding the feedback mechanism and its implications for circuit design. There are also mentions of practical challenges, such as temperature variations and the need for precise resistor values, which may affect the performance of opamps.
This discussion may be of interest to electronics students, circuit designers, and hobbyists looking to deepen their understanding of operational amplifiers and their applications in various electronic circuits.
jd12345
An ideal opamp is said to have infinite gain and high input resistance.
But why do the designers want to have infinite gain? This makes it impossible to use it as differential amplifier as even small voltages will have very large values. We have to add a negative feedback to use the opamp properly
why can't they just design the opamp with lesser gain so that's its easier to use without any feedback
An op-amp designed to be used for differential signals without feedback would be a instrumentation amplifier...They've been around for a very long time.
Note that you can build a "discrete" instrumentation amplifier using a couple of op-amps.
I don't understand how making the gain incredibly high and then adding feedback to compensate it help.
Can you explain
Here is a basic reason. Suppose you want to use the opamp as an impedance buffer. You have a high impedance source that you want to drive a low impedance load. The opamp has a gain of 10. You connect the source directly to the non-inverting input and connect the output directly to the inverting input. The output will be equal to the voltage at the non-inverting input plus the gain times the difference between the two inputs. So with a voltage of 5V on the non-inverting input and a gain of 10, what will the output voltage be? It will be 4.5V - not a very good buffer.
But if the gain is 100K, then the output voltage will be 4.99995 volts.
I note that when I set the cruise control on my car exactly at 50mph, the car's speed stabilizes at 49mph. Does that mean that the gain in my cruise control is 50?
There's plenty of tutorials around
http://www.electronics-tutorials.ws/opamp/opamp_2.html
the mental exercise of working feedback in your head needs to become second nature.
Let's use skeptic's cruise control as an example. (Edit - sorry skeptic i thought that was OP- my face is red , old jim)
One toe power on accelerator pedal controls maybe five hundred horsepower, if you have an old Plymouth hemi from early 60's.
That's a lot of gain.
Your cruise control has two inputs, measured speed and desired speed, and one output, engine power.
Engine power becomes speed after overcoming friction and inertia. That's the system being controlled.
Measuring the system's output(speed) and feeding it back to accelerator pedal keeps engine at just right power to match car's need for power, probably thirty hp or so.
Result is that measured and desired speed are held equal.
It is the duty of the circuit designer to surround the op-amp with a circuit that enables it to hold its inputs equal.
Now you have at the math and see why steady state error is 1/( open loop gain).
High open loop gain gives small error, and small error is good.. That's why it is used.
The idea of infinite gain op amp is to allow gain with feedback to be set arbitrarily and precisely with external resistors. In other words the gain depends largely only on resistor values which can be very precise.
If I want an amplifier with a gain of, say, 20, I could design a custom transistor circuit that has an open loop gain of 20 and has no feedback. Problem is:
1 - I would only be able to use it at a gain of 20.
2 - Its gain would vary over temperature, process, and applied voltage.
Got it. Thank you guys
Can you explain
the reason they do that is so that the parameters of the op-amp circuit depends virtually entirely on the parts around the op-amp and not the op-amp itself. that way it doesn't matter if the op-amp has a gain of 100,000 or 150,000 or 90,000, the behavior of the circuit will not be much different if the surrounding components are the same.
Ok so this way the opam functioning only depends on the parts surrounding it.
But I don't understand one thing - in inverting amplifier the voltage gain is -r2/r1. We don't really need an amplifier to achieve this result right? We can directly connect input voltage to output voltage with some resistance combination to achieve the same result.
I think i am missing some concept
I think you can answer this yourself. Step 1: sketch the resistor network that you propose will provide a gain of x10 (or is it -10; you choose). Step 2: write some equations based on Ohm's or Kirchoff's laws. Step 3: determine Vo/Vin
Can you explain
Don't forget that the feedback network can include reactance (e.g., capacitors) as well as resistance, so the feedback can be frequency dependent, thus allowing you to tailor the gain to have peaks and troughs (i.e., the gain varies as the frequency varies). The feedback can also include non-linear elements, allowing a designer to invent non-linear circuits.
I couldn't really come up with a circuit that has voltage gain as the opamp but i am pretty sure you can get the same result using some resistors and voltage dource. You don't need an opamp with feedback to achieve that.
Can you please tell me an application of inverting opamp
That's a voltage divider.
try and build a voltage divider with gain > 1.
Oh yeah ok silly me!
So let me see if I got it right - the characteristics of an opamp help us to gets its output depend only on the circuit surrounding and not its internal working, temperature etc.
That's the general idea. :approve: But in the real world everything is a compromise, so you still need to keep in mind the limitations of the op-amp itself on your overall design.
An op-amp also allows you to realize functions that cannot be constructed using a network of passive components alone (including, for example, negative resistance).
  • · Replies 22 ·
  • · Replies 28 ·
9K
