Buy Alum Sulfate for 8000 Gal 48% Solution
  • Thread starter Thread starter obrien040362
The discussion revolves around calculating the amount of alum sulfate needed to create an 8000-gallon solution at a concentration of 48%. It involves mathematical reasoning related to solution preparation and density considerations.
  • Homework-related
  • One participant inquires about the quantity of alum sulfate required for the solution.
  • Another participant suggests determining the density of the 48% alum sulfate solution as a first step.
  • A participant expresses uncertainty about calculating the solution weight for both 25% NaOH and 48% aluminum sulfate.
  • There is a suggestion to use specific gravities to calculate the weight of the solution.
  • A later reply provides a method for calculating the weight of the 48% alum sulfate solution based on the specific gravity and includes adjustments for different forms of alum sulfate (anhydrous, octadecahydrate, hexadecahydrate).
Participants do not appear to reach a consensus on the calculation method, as there are multiple approaches suggested and some expressions of uncertainty regarding the calculations.
Participants mention specific gravities and ratios for different forms of alum sulfate, indicating that assumptions about density and solution composition are critical to the calculations, but these assumptions are not fully resolved.
obrien040362
How many pounds of alum sulfate do I need to buy to make 8000 gallons of 48% solution.
Thank you
Chemistry news on Phys.org
You do it the same way you did the 25% NaOH solution. You will need to determine the density of 48% alum sulfate first.
I did review that answer before I posted , but I don't know how to calculate the solution weight of 25% NaOh or 48% Aluminum Sulfate
Can you figure weight of solution with specific gravities?
Yes. Multiply the weight of a gallon of water by the specific gravity of your want to be alum solution to get the weight of a gallon of 48% w/w alum sulfate. Multiply that by. 48 and multiply that answer by 8000.
That's how much anhydrous aluminum sulfate you will need to use. If you are purchasing the octadecahydrate, multiply that number by the ratio (666/342). If purchasing the hexadecahydrate multiply it by the ratio (648/342).
