Concatinating signals on Matlab
  • Context: MATLAB
  • Thread starter Thread starter princess Maro
    Matlab Signals
The discussion revolves around a user's challenge in concatenating different types of signals in MATLAB, specifically when the user can select multiple signal types based on input. The conversation includes code snippets and error messages encountered during the coding process, focusing on the technical aspects of signal concatenation and user input handling.
  • One participant describes their attempt to concatenate signals using a loop and encounters an error related to vector size during assignment.
  • Another participant suggests that the error may stem from how the user is attempting to concatenate the signals and emphasizes the importance of ensuring vector dimensions match.
  • A participant shares their code and indicates that they are unsure how to concatenate the chosen signals for plotting, expressing a need for further assistance.
  • Concerns are raised about the definition of variables in the code, particularly the variable 'k', which is used without prior definition, leading to potential errors.
  • One participant proposes a method to build the signal vector incrementally to avoid size mismatch errors, suggesting a different approach to concatenation.
  • There are questions about the implications of user input, such as the order of breakpoints and the handling of non-integer values, which could affect the output.
Participants express varying opinions on the source of the errors and the best approach to concatenate signals. There is no consensus on a single solution, as multiple suggestions and concerns are raised regarding the code and user input handling.
Limitations include potential issues with variable initialization, the need for careful handling of user input, and the requirement for consistent vector sizes during concatenation. The discussion highlights the complexity of the problem without resolving the specific coding errors.
princess Maro
Hiiiiii Everyone ,
It is My First Post ...And I will be Very pleased if You helped me find a solution to my problem .
well... It is a Matlab code &
I have different type of signals (impulse ,Ramp, sinusoidal,Dc ,exponintial )
& the type of signal is determined by the user ( the user enter a number from 1 to 5) to determine the signal & the user can have multiple selection ..& the user tells me how many time he want to select signals
But The Problem i don't Know how to concatenate the signal .. I tried to make it like this
A=[];
for i=1:c+1
A=[A y(choice)]
end
but an error keeps bothering me
? In an assignment A(I) = B, the number of elements in B and
I must be the same.
please anyone help me..
So if you are storing the possible signals in vectors m1 m2 etc, and the user constructed vector is a, then, at each selection, you are doing a=[a,m1] (if type 1 was selected).
I think your error means that you have made a mistake in your assignments to do with the vector size. Check that you are concatenating to the right place with the correct orientation.
But I suspect it is the y(choice) part ... MATLAB would see that as an assignment of form A(I)=B you see?
i.e.
Code:
7> m=magic(4)
m =
   16    2    3   13
    5   11   10    8
    9    7    6   12
    4   14   15    1
8> a=m(1,:)
a =
   16    2    3   13
9> a=[a,m(4,:)]
a =
   16    2    3   13    4   14   15    1
10> a=[a,m(:,3)]
error: number of rows must match (4 != 1) near line 10, column 6
10> a=[a;m(3,:)]
error: number of columns must match (4 != 8)
To be able to tell what is going wrong for you I need to see the code and the context for the error (the actual error message copy-and-past).
Thanks Monsieur simone For Your Help :)
But That wasnot the point that i was asking about .. You R Right you have to see the code to be able to see the problem
c=input('enter the number of break point: ');
for n=1:c
m(1,k)=input('enter positions of break point:');
k=k+1;
end
p=[-5 m 3]; % The signal start at -5 & end at 3 & m is the position of the break
for k = 1:c+1
t=linspace(p(1,k),p(1,k+1),(p(1,k+1)-p(1,k))*100); % the frequency =100
choice=menu('Choose a type','y(1)','y(2)','y(3)','y(4)','y(5)');
if choice==1
g=p(1,k+1)-p(1,k);
y(1)=[4 zeros(1,(g-1))];
end
if choice==2
y(2)=5*ones(1,t);
end
if choice==3
y(3)=3*t+1;
end
if choice==4
y(4)=3*exp(-2);
end
if choice==5
y(5)=5*sin(100*t+30);
end
% Here i want to conatenate all the choosen signals & Plot it With T
% But i can't Write the proper code of concatination
T=linspace(-5,3,(3+5)*100);
A=ones(1,(3+5)*100);
end
princess Maro said:
Thanks Monsieur simone[*] For Your Help :)
I can see a number of problems with the below:
for n=1:c
k=k+1;
end
... you have not defined k - change the n to a k or the k to an n.
With this change, the output looks like this:
Code:
48> sig
enter the number of break point: 3
enter positions of break point:0.1
enter positions of break point:0.2
enter positions of break point:2
Choose a type
  [ 1] y(1)
  [ 2] y(2)
  [ 3] y(3)
  [ 4] y(4)
  [ 5] y(5)
pick a number, any number: 1
error: A(I) = X: X must have the same size as I
error: called from:
error:   /home/simon/sig.m at line 15, column 5
line 15 is:
if choice==1
g=p(1,k+1)-p(1,k);
end
consider: what does "y(1)" mean to matlab?
- what do you y to look like?
if you want y to be a row vector containing the signal, then you can build it as you go.
something like:
y=[y,[4 zeros(1,(g-1))] ];
That gets rid of the error but there are other problems.
Work through your loops by hand - pick c=1 and choose 0 so that p=[-5,0,3] and see what happens. Make sure it's what you want to happen.
What happens if the user chooses break point positions out of order? i.e. if c=2, and the first point is 2 and the second is -1?
What happens if the user chooses non-integer break point positions?
I'm guessing you'll work out how to build a horizontal axis later?
[*] Shouldn't that be by Monsieur (Simon) Dupont for French? IIRC: "Simone" is the feminine spelling in French as it is in English so you are kinda implying that you think I'm a girl? Mind you - if I'm an honorary woman then I get to be "right" don't I so... no complaints there ;)
It is masculine in Italian though - for "Signor (Simone) Ponte" or something(?)
