Anoter question on vector spaces an rationnal numbers
The discussion revolves around the properties of rational numbers and their relationship to vector spaces and completeness. Participants explore the completion of the set of rational numbers \( \mathbb{Q} \) under various norms, the implications of Cauchy sequences, and the cardinality of sets, particularly in relation to the real numbers \( \mathbb{R} \). The conversation includes theoretical considerations, mathematical reasoning, and challenges to interpretations of these concepts.
  • Some participants propose that the set of rational numbers \( \mathbb{Q} \) with the usual operations forms a vector space, and question whether adding Cauchy sequences results in a complete space.
  • Others argue that completing \( \mathbb{Q} \) under the ordinary Euclidean norm yields the real numbers \( \mathbb{R} \), suggesting that \( \mathbb{Q}^* \) is not equal to \( \mathbb{R} \).
  • A participant expresses confusion about the existence of a bijection between countable sequences and the uncountable set of real numbers, seeking clarification on the implications of cardinality.
  • Some participants challenge interpretations of the relationship between rational sequences and real numbers, emphasizing the need for understanding the transition from countable to uncountable sets.
  • There are references to the Schroeder-Bernstein theorem and discussions about injections between sets, with some participants suggesting that finding bijections may not be necessary for understanding cardinality.
Participants do not reach consensus on the implications of completing \( \mathbb{Q} \) or the nature of bijections between sets. Multiple competing views remain regarding the relationship between rational numbers, Cauchy sequences, and the cardinality of real numbers.
Participants express varying levels of familiarity with concepts of cardinality and completeness, leading to differing interpretations of mathematical results. Some discussions hinge on the definitions and properties of sets, particularly in relation to countability and uncountability.
  • #31
matt grime said:
the polarization identity only gives an inner product under certain conditions and does not always give an inner prooduct. the banach norm must sttisfy the parallelogram idnetity
|u+v|^2 + |u-v|^2 = 2( |u|^2 + |v|^2)
Thanks a lot. I have missed the linearity and antilinearity pb of <x,y> based on the polarisation identity.
Seratend.
  • #32
Can we say that in a non separable hilbert space there isn't any injective compact bounded linear applications on this space (and thus, no compact bounded bijections)?
Seratend.
  • #33
I doubt that that is true. Can you save me the effort and give me some examples of non-separable hilbert spaces?
having said that, you mean functional by application don't you?
  • #34
Yes, I mean a continuous linear function f: H --> H that is compact (i.e. closure[f(B)] is a compact set in H where B is the unit radius ball in H).
Example of a non separable hilbert space: [itex]l^2(I)[/itex] where I is an uncountable set (for example a |R interval). It is the hilbert space of uncountable real number sequences [itex](x_i)_i_\in _I[/itex] such that [itex]\sum _{i_\in _I}|x_i|^2 < \infty[/itex]
Seratend
  • #35
Hint for my question: It is an extrapolation from the spectral theory of compact continuous linear functions (i.e. only Ker(f) seems to be the only subspace that can be non separable).
Seratend.
  • #36
a linear functional is not the same as a linear function from H to itself.
  • #37
Ok, I am sorry for my bad mathematical terms (sometimes they are direct translations).
I mean a linear operator (call it f), if you prefer, "acting" on the hilbert space H (an endomorphism if I am right):
f: H --> H
x[itex]\in H[/itex] --> f(x) [itex]\in H[/itex]
such that f(x1+k.x2)=f(x1)+k.f(x2)
we choose f as a bounded compact operator on H. My question stays: can we say that there isn't any injective bounded compact linear operator on a non separable hilbert space?
  • #38
We can either restrict this question to the normal subset of these linear operators (i.e. an operator such that ff*=f*f).
Seratend.
  • #39
In order to help the members of this forum to answer to this question (and also to believe that the answer is probably yes), we can already say that there isn't any bijective compact bounded operator on infinite dimensional Hilbert spaces (separable or not).
Here is the demonstration:
We know that the closed unit ball cannot be a compact set in an infinite dimensional Hilbert space. However, if we have a compact isomorphism between Hilbert spaces that are continuous, the image of closed set is a closed set and thus because we have a compact operator, the image of the closed unit ball is a compact set (the closure of the set is equal to the set, because the set is closed). Thus, the image of this compact set under the inverse continuous operator is a also compact set. Thus, the unit ball is a compact set for a compact continuous isomorphism. QED. So it is easy to demonstrate the impossibility of compact isomorphisms on infinite dimensional Hilbert spaces (separable or not).
However, if we reduce the case to the injective compact continuous operators case, we just have the property that the closure of the image of a closed unit ball is a compact set. Therefore, the unit ball is not a compact set if the image is not compact and the question is still valid.
Seratend.
  • #40
The answer:
There is no compact (continuous) injective operator on a non separable hilbert space.
Quick demo: H the hilbert space. T the compact injective operator => Closure[T(H)] is a separable space (compacity property) => there is no injection between a non separable hilbert space and the separable one.
Moreover, we have a weaker formulation of this impossibility: there is no injective compact operator between a non separable Hilbert space and any banach space. (i.e. we can have an injective compact operator between 2 banach spaces, even if the banach spaces are non separable).
Seratend.
  • · Replies 0 ·
9K
  • · Replies 38 ·
  • · Replies 25 ·
