New Reply
Isothermal Compression of an Ideal Gas in a Frictionless PCD
Share Thread
Feb5-13, 12:41 AM   #1
A frictionless piston-cylinder compresses 1 mol of nitrogen to a tenth of its original volume isothermally at 300 K. Assume nitrogen is an ideal gas with Cp*=(7/2)R.
(a) Show two different approaches to calculate the compression work required.
(b) What is the corresponding heat flow?
(c) If the piston-cylinder now experiences significant friction, how will the heat and work flows be different in order to accomplish the same thermodynamic change?
(d) Can the two different approaches in (a) be used to calculate the compression work for a piston cylinder with significant friction? Explain.
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
New Reply
Similar discussions for: Isothermal Compression of an Ideal Gas in a Frictionless PCD
Thread Forum Replies
costeffective Isothermal air compression General Engineering 0
Isothermal Compression HELP! Introductory Physics Homework 1
Isothermal compression vs thermally isolated compression Introductory Physics Homework 2
Isothermal compression of ideal gas Engineering, Comp Sci, & Technology Homework 0
isothermal compression of monatomic gas ? Introductory Physics Homework 5
