Why does solder (or braze alloy) flow towards heat?
  • Context: Undergrad
  • Thread starter Thread starter DTM
    Alloy Flow Heat
The discussion revolves around the phenomenon of solder or braze alloy flowing towards heat during the soldering process. Participants explore potential explanations for this behavior, including physical and chemical properties, as well as specific mechanisms like the Marangoni effect. The scope includes theoretical insights and practical observations related to soldering techniques.
  • One participant notes the common observation that solder flows towards hotter metal but seeks a fundamental explanation for this behavior.
  • Another participant suggests that the attraction of solder to certain metals, like copper and gold, may play a role, while also mentioning the complexity of soldering other metals like aluminum.
  • A different viewpoint introduces the Marangoni effect, linking it to temperature-dependent surface tension, but acknowledges conflicting reports about its influence on wetting.
  • One participant emphasizes the role of flux in soldering, suggesting that it allows solder to wet the metal surface and may influence the flow of solder.
  • Another participant references the Marangoni effect and provides links to external resources for further reading, indicating a desire for deeper understanding.
  • A later reply expresses appreciation for the Marangoni effect as a valid explanation and notes its relevance to practical applications like sweating copper fittings.
Participants express varying viewpoints on the mechanisms behind solder flow, with some supporting the Marangoni effect while others highlight chemical properties and the role of flux. No consensus is reached on a definitive explanation.
Participants mention the complexity of soldering different metals and the influence of surface tension and flux, but do not resolve the underlying assumptions or provide a comprehensive mathematical framework for the discussed phenomena.
This discussion may be of interest to individuals involved in soldering, materials science, or those seeking to understand the physical principles behind fluid dynamics in metal joining processes.
DTM
You hear it over and over again, that solder or braze alloy will flow towards the heat. Another way of saying this is it flows towards hotter metal and away from colder metal. I've done enough soldering to see that it certainly appears to be true. But I've never heard, nor have I found, a good fundamental explanation of why liquid solder or braze alloy flows towards the heat. What force is causing this motion? Any thoughts?
Science news on Phys.org
I think mostly because of the property of soldier to attract some metals like copper, gold, I don't think that it will attract any metal like iron or aluminium.That's why it is very complicated and you have to use special chemicals to solder aluminum wire.I think it is because of some chemical properties of different alloys , metals and solder itself.that's why they have gold plated connectors so that they would be easier and better to solder to and make a stronger contact , try flowing the hot solder unto a iron bar I bet it won;'t hold nor flow it;'s way.
But maybe someone else has something more advanced to say about this.
AFAIK, it's due to Marangoni/thermocapillary flow: the temperature-dependent surface tension. However, I couldn't find a definitive result, and a few reports say that Marangoni flow *opposes* wetting.
Good question!
Have you tried soldering without using a flux. Flux dissolves the oxides on the metal surface allowing the solder to wet the metal surface. Have you noticed the flux around the perimeter of the solder - the liquid solder follows the flux.
Andy is on the right track...see here, but an actual description is not really provided:
http://en.wikipedia.org/wiki/Marangoni_effect
The Marangoni effect (also called the Gibbs–Marangoni effect) is the mass transfer along an interface between two fluids due to surface tension gradient. In the case of temperature dependence, this phenomenon may be called thermo-capillary convection[1] (or Bénard–Marangoni convection[2]).
I suspect one can get more of an insight here:
but I did not look through the equation details...be sure this applies to solids as well as liquids...
Thank you for the responses. The Marangoni effect is a good explanation. I also like the term "thermo-capillary convection", very descriptive. I'm surprised the Wikipedia article doesn't list soldering/brazing as applications of this mechanism, as it is applicable to anyone who has ever sweated copper fittings. If anyone's an expert they ought to add to the Wiki article.
  • · Replies 16 ·
