Loop-and-allied QG bibliography
  • Context: Graduate
  • Thread starter Thread starter marcus
    Bibliography
The discussion revolves around the concepts and intuitive understanding of Loop Quantum Gravity (LQG), particularly focusing on the nature of spin networks and their implications in the framework of quantum gravity. Participants explore various analogies and descriptions to clarify the fundamental ideas of LQG and its differences from traditional field theories.
  • Some participants describe Rovelli's vision for LQG, emphasizing the coupling of the standard model to quantized loops to avoid infinity problems and enable non-perturbative calculations.
  • There is a suggestion to create an intuitive sketch of LQG to clarify its unique aspects, particularly its background independence.
  • One participant proposes analogies, such as a drumhead and a sink of soapsuds, to illustrate the concept of spin networks as polymers that represent the excitations of space.
  • Another participant defines spin networks as directed graphs with assigned numbers to edges and vertices, linking these to the computation of areas and volumes in LQG.
  • There is a discussion about the relationship between spin networks and group representations, with some uncertainty regarding the terminology and definitions used in different sources.
  • Participants note that intertwining operators play a role in the evolution of spin networks, though there is some confusion about their exact nature and function.
Participants express various interpretations and analogies regarding spin networks and their properties, indicating that there is no consensus on the best way to describe these concepts. Some agree on the definitions while others express uncertainty or seek clarification on specific terms and their implications.
There are unresolved questions regarding the definitions of intertwining operators and the relationship between different approaches to quantum gravity, such as the canonical approach versus the sum-over-histories approach. Additionally, the discussion reflects varying levels of familiarity with the technical aspects of LQG among participants.
  • #1,951
http://arxiv.org/abs/1305.4582
Causal Dynamical Triangulations without Preferred Foliation
S. Jordan, R. Loll
(Submitted on 20 May 2013)
We introduce a generalized version of the Causal Dynamical Triangulations (CDT) formulation of quantum gravity, in which the regularized, triangulated path integral histories retain their causal properties, but do not have a preferred proper-time foliation. An extensive numerical study of the associated nonperturbative path integral in 2+1 dimensions shows that it can nevertheless reproduce the emergence of an extended de Sitter universe on large scales, a key feature of CDT quantum gravity. This suggests that the preferred foliation normally used in CDT is not a crucial (albeit convenient) part of its background structure.
  • #1,952
http://arxiv.org/abs/1305.4790
Quantum-gravity inspired collapse with far observable bounce
Cosimo Bambi, Daniele Malafarina, Leonardo Modesto
(Submitted on 21 May 2013)
We consider general relativistic homogeneous gravitational collapses for dust and radiation. We show that replacing the density profile with an effective density justified by some quantum gravity framework leads to the avoidance of the final singularity. The effective density acts on the collapsing cloud by introducing an isotropic pressure, which is negligible at the beginning of the collapse and becomes negative and dominant in the strong field regime. For sufficiently small sources, the horizon never forms. For larger objects, the horizon forms, it disappears when the matter density approaches a critical value and gravity becomes very weak (asymptotic freedom regime), it forms again after the bounce as a consequence of the decrease in the matter density, and it eventually disappears when the density becomes too low and the matter is radiated away. In both cases, the bounce stage regulated by quantum gravity effects turns out to be visible to distant observers. The possibility of detecting radiation coming from the high density region of a collapsing astrophysical object in which classically there would be the creation of a singularity could open a new window to experimentally test theories of quantum gravity.
10 pages, 6 figures
http://arxiv.org/abs/1305.4702
Exploring Torus Universes in Causal Dynamical Triangulations
T.G. Budd, R. Loll
Motivated by the search for new observables in nonperturbative quantum gravity, we consider Causal Dynamical Triangulations (CDT) in 2+1 dimensions with the spatial topology of a torus. This system is of particular interest, because one can study not only the global scale factor, but also global shape variables in the presence of arbitrary quantum fluctuations of the geometry. Our initial investigation focusses on the dynamics of the scale factor and uncovers a qualitatively new behaviour, which leads us to investigate a novel type of boundary conditions for the path integral. Comparing large-scale features of the emergent quantum geometry in numerical simulations with a classical minisuperspace formulation, we find partial agreement. By measuring the correlation matrix of volume fluctuations we succeed in reconstructing the effective action for the scale factor directly from the simulation data. Apart from setting the stage for the analysis of shape dynamics on the torus, the new set-up highlights the role of nontrivial boundaries and topology.
30 pages, 12 figures
brief mention:
http://arxiv.org/abs/1305.4685
Machian Classical and Semiclassical Emergent Time
Edward Anderson
Classical and semiclassical schemes are presented that are timeless at the primary level and recover time from Mach's "time is to be abstracted from change" principle at the emergent secondary level. The semiclassical scheme is a Machian variant of the Semiclassical Approach to the Problem of Time in Quantum Gravity. The classical scheme is Barbour's, cast here explicitly as the classical precursor of the Semiclassical Approach...
22 pages and 1 figure.
  • #1,953
http://arxiv.org/abs/1305.5203
A computable framework for Loop Quantum Gravity
Viqar Husain, Tomasz Pawlowski
(Submitted on 22 May 2013)
We present a non-perturbative quantization of general relativity coupled to dust and other matter fields. The dust provides a natural time variable, leading to a physical Hamiltonian with spatial diffeomorphism symmetry. The methods of loop quantum gravity applied to this model lead to a physical Hilbert space and Hamiltonian. This provides a framework for physical calculations in the theory.
3 pages. To appear in Proceedings of the 13th Marcel Grossmann Meeting (MG13), Stockholm, Sweden, 1-7 July 2012
http://pirsa.org/13050000/
A la recherche du temps perdu...in quantum gravity
Speaker(s): Fay Dowker
Abstract: Causal set quantum gravity is based on the marriage between the concept of causality as an organising principle more basic even than space or time and fundamental atomicity. Causal sets suggest novel possibilities for "dynamical laws" in which spacetime grows by the accumulation of new spacetime atoms, potentially realising within physics C.D. Broad's concept of a growing block universe in which the past is real and the future is not.
To do justice to relativity and general covariance, the atoms must accumulate in a partial order, exactly the order that the atoms have physically amongst themselves. That this is possible is demonstrated by the Rideout-Sorkin Classical Stochastic Growth models. This proof of concept -- of the compatibility of relativity and "becoming'' -- is, however, classical and is challenged by the global character of the physical world within a path integral framework for quantum theory. Out of the struggle to reconcile the global and local natures of the physical world may arise a quantal dynamics for causal sets.
Date: 22/05/2013 - 2:00 pm
http://arxiv.org/abs/1305.4986
Mechanical laws of the Rindler horizon
Eugenio Bianchi, Alejandro Satz
Gravitational perturbations of flat Minkowski space make the Rindler horizon dynamical: the horizon satisfies mechanical laws analogous to the ones followed by black holes. We describe the gravitational perturbation of Minkowski space using perturbative field-theoretical methods. The change in the area of the Rindler horizon is described in terms of the deflection of light rays by the gravitational field. The difference between the area of the perturbed and the unperturbed horizon is related to the energy of matter crossing the horizon. We derive consistency conditions for the validity of our approximations, and compare our results to similar ones present in the literature. Finally, we discuss how this setting can be used in perturbative quantum gravity to extend the classical mechanical laws to thermodynamic laws, with the entanglement of field modes across the Rindler horizon providing a notion of thermodynamic entropy.
10 pages, 2 figures
http://arxiv.org/abs/1305.5191
A small cosmological constant due to non-perturbative quantum effects
Jan Holland, Stefan Hollands
We propose that the expectation value of the stress energy tensor of the Standard Model should be given by ⟨Tμν⟩ = ρvac ημν, with a vacuum energy ρvac that differs from the usual “dimensional analysis” result by an exponentially small factor associated with non-perturbative effects. We substantiate our proposal by a rigorous analysis of a toy model, namely the 2-dimensional Gross-Neveu model. In particular, we address, within this model, the key question of the renormalization ambiguities affecting the calculation. The stress energy operator is constructed concretely via the operator-product-expansion. The non-perturbative factor in the vacuum energy is seen as a consequence of the facts that a) the OPE-coefficients have an analytic dependence on g, b) the vacuum correlations have a non-analytic (=non-perturbative) dependence on g, which we propose to be a generic feature of QFT. Extrapolating our result from the Gross-Neveu model to the Standard Model, one would expect to find ρvac ∼ Λ4e−O(1)/g2 , where Λ is an energy scale such as Λ = MH, and g is a gauge coupling such as g2/4π = αEW. The exponentially small factor due to non-perturbative effects could explain the “unnatural” smallness of this quantity.
11 pages.
  • #1,954
http://arxiv.org/abs/1305.3326
A Discrete and Coherent Basis of Intertwiners
Laurent Freidel, Jeff Hnybida
(Submitted on 15 May 2013)
We construct a new discrete basis of 4-valent SU(2) intertwiners. This basis possesses both the advantage of being discrete, while at the same time representing accurately the classical degrees of freedom; hence it is coherent. The closed spin network amplitude obtained from these intertwiners depends on twenty spins and can be evaluated by a generalization of the Racah formula for an arbitrary graph. The asymptotic limit of these amplitudes is found. We give, for the first time, the asymptotics of 15j symbols in the real basis. Remarkably it gives a generalization of the Regge action to twisted geometries.
  • #1,955
http://arxiv.org/abs/1305.5062
Dual redshift on Planck-scale-curved momentum spaces
Giovanni Amelino-Camelia, Leonardo Barcaroli, Giulia Gubitosi, Niccoló Loret
Several approaches to the investigation of the quantum-gravity problem have provided "theoretical evidence" of a role for the Planck scale in characterizing the geometry of momentum space. One of the main obstructions for a full exploitation of this scenario is the understanding of the role of the Planck-scale-curved geometry of momentum space in the correlations between emission and detection times, the "travel times" for a particle to go from a given emitter to a given detector. These travel times appear to receive Planck-scale corrections for which no standard interpretation is applicable, and the associated implications for spacetime locality gave rise to the notion of "relative locality" which is still in the early stages of investigation. We here show that these Planck-scale corrections to travel times can be described as "dual redshift" (or "lateshift"): they are manifestations of momentum-space curvature of the same type already known for ordinary redshift produced by spacetime curvature. In turn we can identify the novel notion of "relative momentum-space locality" as a known but under-appreciated feature associated to ordinary redshift produced by spacetime curvature, and this can be described in complete analogy with the relative spacetime locality that became of interest in the recent quantum-gravity literature. We also briefly comment on how these findings may be relevant for an approach to the quantum-gravity problem proposed by Max Born in 1938 and centered on Born duality.
  • #1,957
http://arxiv.org/abs/1305.6315
Why gravity codes the renormalization of conformal field theories
Henrique Gomes, Sean Gryb, Tim Koslowski, Flavio Mercati, Lee Smolin
(Submitted on 27 May 2013)
We give a new demonstration that General Relativity in d+1 dimensions with negative or positive cosmological constant codes the renormalization group behaviour of conformal field theories (CFT) in d dimensions. This utilizes Shape Dynamics, which is a conformally invariant theory known to be equivalent to General Relativity. A key result of Shape Dynamics is that the evolution of observables under local conformal transformations and spatial diffeomorphisms is shown to be equivalent to many fingered time, i.e., d+1-dimensional spacetime diffeomorphisms. This relationship explains why the renormalization group flow of a CFT is governed by a geometry with d+1-dimensional spacetime diffeomorphism invariance.
25 pages
brief mention:
http://arxiv.org/abs/1305.6565
Path Integrals and Reality
Adrian Kent
(Submitted on 28 May 2013)
We define the idea of real path quantum theory, a realist generalisation of quantum theory in which it is postulated that the configuration space path actually followed by a closed quantum system is probabilistically chosen. This is done a postulate defining probabilities for paths, which we propose are determined by an expression involving path amplitudes and a distance function that quantifies path separation. We suggest a possible form for a path probability postulate and explore possible choices of distance function, including choices suitable for Lorentz or generally covariant versions of real path quantum theory. We set out toy models of quantum interferometry and show that in these models the probability postulate and specific distance functions do indeed give a physically sensible path ontology. These functions can be chosen so as to predict quantum interference for interference of microscopic quantum systems and the failure of interference for macroscopic quantum systems. More generally, they predict interference when the beams are close, and its failure when they are far apart, as determined by the distance function. If taken seriously in its present relatively unconstrained form, real path quantum theory thus motivates experimental tests of quantum interference in all unexplored regimes defined by potentially physically interesting parameters, including the mass of the beam object, the beam separation distance, the beam separation time, and many others. We discuss open questions raised by these ideas.
20 pages
symptom of shift towards bounce models:
http://arxiv.org/abs/1305.6346
Bouncing cosmologies in massive gravity on de Sitter
David Langlois, Atsushi Naruko
  • #1,958
http://arxiv.org/abs/1305.6714
Black hole entropy from KMS-states of quantum isolated horizons
Daniele Pranzetti
(Submitted on 29 May 2013)
By reintroducing Lorentz invariance via a complex connection formulation in canonical loop quantum gravity, we define a geometrical notion of temperature for quantum isolated horizons. Upon imposition of the reality conditions in the form of the linear simplicity constraints for an imaginary Barbero-Immirzi parameter, the exact formula for the temperature can be derived by demanding that the horizon state satisfying the boundary conditions be a KMS-state. In this way, our analysis reveals the connection between the passage to the Ashtekar self-dual variables and the thermality of the horizon. The horizon equilibrium state can then be used to compute both the von Neumann and the Boltzmann entropies. By means of a natural cut-off introduced by the topological theory on the boundary, we show that the two provide the same finite answer which allows us to recover the Bekenstein-Hawking formula in the semi-classical limit. The connection with Connes-Rovelli thermal time proposal for a general relativistic statistical mechanics is worked out.
10 pages, 1 figure
http://arxiv.org/abs/1305.6680
CDT and the Search for a Theory of Quantum Gravity
J. Ambjorn, A. Goerlich, J. Jurkiewicz, R. Loll
Causal Dynamical Triangulations provide a non-perturbative regularization of a theory of quantum gravity. We describe how this approach connects with the asymptotic safety program and Ho\vrava-Lifgarbagez gravity theory, and present the most recent results from computer simulations.
23 pages, 5 figures. Based on plenary talk at MG13. To appear in the proceeding
brief mention:
http://arxiv.org/abs/1305.6859
Dark Matter
P. J. E. Peebles
The evidence for the dark matter of the hot big bang cosmology is about as good as it gets in natural science. The exploration of its nature is now led by direct and indirect detection experiments, to be complemented by advances in the full range of cosmological tests, including judicious consideration of the rich phenomenology of galaxies. The results may confirm ideas about DM already under discussion. If we are lucky we also will be surprised once again.
3 pages. Essay for the Dark Matter Sackler Colloquium, October 2012, Irvine CA
http://arxiv.org/abs/1305.6838
The Physics of the Far Future
Ruxandra Bondarescu, Andrew P. Lundgren, Mihai Bondarescu
3 pages. Proceeding for the 13th Marcel Grossmann Meeting in Stockholm, Sweden
  • #1,959
http://arxiv.org/abs/1305.6741
Finite Quantum Gravity
Leonardo Modesto
We hereby present a class of multidimensional higher derivative theories of gravity that realizes an ultraviolet completion of Einstein general relativity. This class is marked by a "non-polynomal" entire function (form factor), which averts extra degrees of freedom (including ghosts) and improves the high energy behavior of the loop amplitudes. By power counting arguments, it is proved that the theory is super-renormalizable in any dimension, i.e. only one-loop divergences survive. Furthermore, in odd dimensions there are no counter terms for pure gravity and the theory turns out to be "finite." Finally, considering the infinite tower of massive states coming from dimensional reduction, quantum gravity is finite in even dimension as well.
  • #1,960
brief mention:
http://arxiv.org/abs/1305.7190
Vector Fields in Holographic Cosmology
James B. Hartle, S. W. Hawking, Thomas Hertog
(Submitted on 30 May 2013)
We extend the holographic formulation of the semiclassical no-boundary wave function (NBWF) to models with Maxwell vector fields. It is shown that the familiar saddle points of the NBWF have a representation in which a regular, Euclidean asymptotic AdS geometry smoothly joins onto a Lorentzian asymptotically de Sitter universe through a complex transition region. The tree level probabilities of Lorentzian histories are fully specified by the action of the AdS region of the saddle points. The scalar and vector matter profiles in this region are complex from an AdS viewpoint, with universal asymptotic phases. The dual description of the semiclassical NBWF thus involves complex deformations of Euclidean CFTs.
17 pages, 3 figs
  • #1,961
http://arxiv.org/abs/1305.7289
Twisting loops and global momentum non-conservation in Relative Locality
Andrzej Banburski
(Submitted on 31 May 2013)
Recent work in Relative Locality has shown that the theory allows for a solution of an on-shell causal loop. We show that the theory contains a different type of a loop in which locally momenta are conserved, but there is no global momentum conservation. Thus a freely propagating particle can decay into two particles, which later recombine to give a particle with momentum and mass different than the original one.
http://arxiv.org/abs/1305.7479
Generalized fuzzy torus and its modular properties
Paul Schreivogl, Harold Steinacker
We consider a generalization of the basic fuzzy torus to a fuzzy torus with non-trivial modular parameter, based on a finite matrix algebra. We discuss the modular properties of this fuzzy torus, and compute the matrix Laplacian for a scalar field. In the semi-classical limit, the generalized fuzzy torus can be used to approximate a generic commutative torus represented by two generic vectors in the complex plane, with generic modular parameter \tau. The effective classical geometry and the spectrum of the Laplacian are correctly reproduced in the limit. The spectrum of a matrix Dirac operator is also computed.
  • #1,962
brief mention:
http://arxiv.org/abs/1306.0527
Quantum Field Theory on Curved Backgrounds - A Primer
Marco Benini, Claudio Dappiaggi, Thomas-Paul Hack
(Submitted on 3 Jun 2013)
Goal of this review is to introduce the algebraic approach to quantum field theory on curved backgrounds. Based on a set of axioms, first written down by Haag and Kastler, this method consists of a two-step procedure. In the first one, a suitable algebra of observables is assigned to a physical system, which is meant to encode all algebraic relations among observables, such as commutation relations, while, in the second step, one must select an algebraic state in order to recover the standard Hilbert space interpretation of a quantum system. As quantum field theories possesses infinitely many degrees of freedom, many unitarily inequivalent Hilbert space representations exist and the power of such approach is the ability to treat them all in a coherent manner. We will discuss in detail the algebraic approach for free fields in order to give to the reader all necessary information to deal with the recent literature, which focuses on the applications to specific problems, mostly in cosmology.
36 pages, invited review to appear on IJMPA
  • #1,963
http://arxiv.org/abs/1306.0861
Matrix Elements of Lorentzian Hamiltonian Constraint in LQG
Emanuele Alesci, Klaus Liegener, Antonia Zipfel
(Submitted on 4 Jun 2013)
The Hamiltonian constraint is the key element of the canonical formulation of LQG coding its dynamics. In Ashtekar-Barbero variables it naturally splits into the so called Euclidean and Lorentzian parts. However, due to the high complexity of this operator, only the matrix elements of the Euclidean part have been considered so far. Here we evaluate the action of the full constraint, including the Lorentzian part. The computation requires an heavy use of SU(2) recoupling theory and several tricky identities among n-j symbols are used to find the final result: these identities, together with the graphical calculus used to derive them, also simplify the Euclidean constraint and are of general interest in LQG computations.
  • #1,964
http://arxiv.org/abs/1306.0820
Quantum cosmology from the de Broglie-Bohm perspective
N. Pinto-Neto, J.C. Fabris
We review the main results that have been obtained in quantum cosmology from the perspective of the de Broglie-Bohm quantum theory. As it is a dynamical theory of assumed objectively real trajectories in the configuration space of the physical system under investigation, this quantum theory is not essentially probabilistic and dispenses the collapse postulate, turning it suitable to be applied to cosmology. In the framework of minisuperspace models, we show how quantum cosmological effects in the de-Broglie-Bohm's approach can avoid the initial singularity, and isotropize the Universe. We then extend minisuperspace in order to include linear cosmological perturbations. We present the main equations which govern the dynamics of quantum cosmological perturbations evolving in non-singular quantum cosmological backgrounds, and calculate some of their observational consequences. These results are not known how to be obtained in other approaches to quantum theory. In the general case of full superspace, we enumerate the possible structures of quantum space and time that emerge from the de Broglie-Bohm picture. Finally, we compare some of the results coming from the de Broglie-Bohm theory with other approaches, and discuss the physical reasons for some discrepancies that occur.
http://arxiv.org/abs/1306.0515
Passing through the Firewall
Erik Verlinde, Herman Verlinde
(Submitted on 3 Jun 2013 (v1), last revised 4 Jun 2013 (this version, v2))
We propose that black hole information is encoded in non-local correlations between microscopic interior and exterior degrees of freedom. We give a simple qubit representation of this proposal, and show herein that for every black hole state, the apparent firewall can be removed via a universal, state independent unitary transformation. A central element in our discussion is the distinction between virtual qubits, which are in a specified vacuum state, and real qubits, that carry the free quantum information of the black hole. We outline how our proposal may be realized in AdS/CFT
http://arxiv.org/abs/1306.0516
Black Hole Information as Topological Qubits
The principle of balanced holography, introduced in [1], posits that black hole information is stored in non-local correlations between the interior and exterior. Based on this concept, we propose that black hole information decomposes into elementary units in the form of topological qubits, and is protected from local sources of decoherence. The topological protection mechanism ensures that the horizon of an evaporating black hole stays young and smooth.
http://arxiv.org/abs/1306.0353
Wheeler-De Witt equation and AdS/CFT correspondence
Francesco Cianfrani, Jerzy Kowalski-Glikman
The radial Wheeler-De Witt equation on the asymptotically AdS spacetime proposed in [9] has as its semiclassical solution the wave function that asymptotically satisfies the conformal Ward identity, exemplifying the AdS/CFT correspondence. In this paper we show that this results holds also in the case of a complete quantum solution of the radial Wheeler-De Witt equation. It turns out that if the wavefunction is expanded in the parameter $\rho$ with $\rho\rightarrow0$ defines the asymptotic boundary of the spacetime, the quantum loop corrections to the semiclassical wave are of subleading order.
  • #1,965
http://arxiv.org/abs/1306.1546
Structural aspects of asymptotically safe black holes
Benjamin Koch, Frank Saueressig
(Submitted on 6 Jun 2013)
We study the quantum modifications of classical, spherically symmetric Schwarzschild (Anti-) de Sitter black holes within Quantum Einstein Gravity. The quantum effects are incorporated through the running coupling constants Gk and Λk, computed within the exact renormalization group approach, and a common scale-setting procedure. We find that, in contrast to common intuition, it is actually the cosmological constant that determines the short-distance structure of the RG-improved black hole: in the asymptotic UV the structure of the quantum solutions is universal and given by the classical Schwarzschild-de Sitter solution, entailing a self-similarity between the classical and quantum regime. As a consequence asymptotically safe black holes evaporate completely and no Planck-size remnants are formed. Moreover, the thermodynamic entropy of the critical Nariai-black hole is shown to agree with the microstate count based on the effective average action, suggesting that the entropy originates from quantum fluctuations around the mean-field geometry.
25 pages 10 figures
  • #1,966
http://arxiv.org/abs/1306.1668
Terminating black holes in quantum gravity
(Submitted on 7 Jun 2013)
We study the homogeneous gravitational collapse of a spherical cloud composed of radiation or dust in a super-renormalizable and asymptotically free theory of gravity. The central singularity appearing in classical general relativity is resolved in both cases. The singularity is replaced by a bounce, after which the cloud re-expands indefinitely. In this model, strictly speaking, a black hole never forms and the high density state governed by quantum-gravitational physics is visible to faraway observers. Our result is quite general, and it holds for gravity theories with form factors suggested by string field theory and non-commutative geometries.
  • #1,967
http://arxiv.org/abs/1306.1489
Affine group formulation of the Standard Model coupled to gravity
Ching-Yi Chou, Eyo Ita, Chopin Soo
(Submitted on 6 Jun 2013 (v1), last revised 8 Jun 2013 (this version, v2))
This work demonstrates that a complete description of the interaction of matter and all forces, gravitational and non-gravitational, can in fact be realized within a quantum affine algebraic framework. Using the affine group formalism, we construct elements of a physical Hilbert space for full, Lorentzian quantum gravity coupled to the Standard Model in four spacetime dimensions. Affine algebraic quantization of gravitation and matter on equal footing implies a fundamental uncertainty relation which is predicated upon a non-vanishing cosmological constant.
  • #1,968
http://arxiv.org/abs/1306.2987
Coarse graining of spin net models: dynamics of intertwiners
Bianca Dittrich, Mercedes Martín-Benito, Erik Schnetter
(Submitted on 12 Jun 2013)
Spin foams are models of quantum gravity and therefore quantum space time. A key open issue is to determine the possible continuum phases of these models. Progress on this issue has been prohibited by the complexity of the full four--dimensional models. We consider here simplified analogue models, so called spin nets, that retain the main dynamical ingredient of spin foams, the simplicity constraints. For a certain class of these spin net models we determine the phase diagram and therefore the continuum phases via a coarse graining procedure based on tensor network renormalization. This procedure will also reveal an unexpected fixed point, which turns out to define a new triangulation invariant vertex model.
33 pages, 17 figures
brief mention:
http://arxiv.org/abs/1306.3021
The Trace-Free Einstein Equations and inflation
George F R Ellis
(Submitted on 13 Jun 2013)
The trace-free version of the Einstein Gravitational equations, essentially equivalent to unimodular gravity, can solve the troubling issue of the huge discrepancy between quantum field theory estimates of the vacuum energy density and the astronomically observed value of the cosmological constant. However it has been suggested that this proposal cannot work because it prevents the inflaton potential energy from driving inflation. It is shown here that that concern is unjustified: inflation proceeds as usual if we adopt the trace free gravitational equations.
10 pages
http://arxiv.org/abs/1306.2964
The Sterile Neutrino Field and Late Time Acceleration
Stephon H.S. Alexander
We show that when the neutrino minimal standard model (νMSM) with a light sterile neutrino has a long range interaction between the neutrino vacuum charge density and a dark U(1) gauge potential, late time acceleration is dynamically realized. Moreover, the relation between the scale of dark energy, the weak and Planck masses derived by Arkani-Hamed et. al that addresses the coincidence problem arises naturally in this model. Assuming that the cosmological constant is zero by some as yet [un]known mechanism, the only fine tuning in our model is the mass of the sterile neutrino. We show that perturbations of the vector fields are oscillatory and hence, there are no instabilities.
4 pages, 1 figure
A strange paper, which some people may be curious to know about:
http://arxiv.org/abs/1306.2993
How all of quantum mechanics can be derived from a single law of physics
Holger F. Hofmann
Author's comment: I sincerely believe that this paper presents a comprehensive answer to all interpretational problems of quantum mechanics. It contains new and surprising insights from recent experiments that should be considered with great care and thoroughness. Please take a look and see for yourself
18 pages
  • #1,969
http://arxiv.org/abs/1306.3021v1
George F R Ellis
  • #1,970
http://arxiv.org/abs/1306.3241
Testing the role of the Barbero-Immirzi parameter and the choice of connection in Loop Quantum Gravity
Jibril Ben Achour, Marc Geiller, Karim Noui, Chao Yu
We study the role of the Barbero-Immirzi parameter γ and the choice of connection in the construction of (a symmetry-reduced version of) loop quantum gravity. We start with the four-dimensional Lorentzian Holst action that we reduce to three dimensions in a way that preserves the presence of γ. In the time gauge, the phase space of the resulting three-dimensional theory mimics exactly that of the four-dimensional one. Its quantization can be performed, and on the kinematical Hilbert space spanned by SU(2) spin network states the spectra of geometric operators are discrete and γ-dependent. However, because of the three-dimensional nature of the theory, its SU(2) Ashtekar-Barbero Hamiltonian constraint can be traded for the flatness constraint of an sl(2,C) connection, and we show that this latter has to satisfy a linear simplicity-like condition analogous to the one used in the construction of spin foam models. The physically relevant solution to this constraint singles out the non-compact subgroup SU(1,1), which in turn leads to the disappearance of the Barbero-Immirzi parameter and to a continuous length spectrum, in agreement with what is expected from Lorentzian three-dimensional gravity.
36 pages
http://arxiv.org/abs/1306.3246
Spectra of geometric operators in three-dimensional LQG: From discrete to continuous
We study and compare the spectra of geometric operators (length and area) in the quantum kinematics of two formulations of three-dimensional Lorentzian loop quantum gravity. In the SU(2) Ashtekar-Barbero framework, the spectra are discrete and depend on the Barbero-Immirzi parameter γ exactly like in the four-dimensional case. However, we show that when working with the self-dual variables and imposing the reality conditions the spectra become continuous and γ-independent.
13 pages. 2 figures
http://arxiv.org/abs/1306.3458
Dynamics of apparent horizons in quantum gravitational collapse
Yaser Tavakoli, Joao Marto, Andrea Dapor
(Submitted on 14 Jun 2013)
We study the gravitational collapse of a massless scalar field within the effective scenario of loop quantum gravity. Classical singularity is avoided and replaced by a quantum bounce in this model. It is shown that, quantum gravity effects predict a threshold scale below which no horizon can form as the collapse evolves towards the bounce.
4 pages. Contribution to the Spanish Relativity Meeting in Portugal 2012 (ERE2012), Guimaraes, Portugal
  • #1,971
http://arxiv.org/abs/1306.4035
Graviton scattering amplitudes and Pure Connection Formulation of GR
Gianluca Delfino
(Submitted on 17 Jun 2013)
We show how the recently introduced "Pure Connection Formulation" of gravity provides a natural framework for approaching the problem of computing graviton scattering amplitudes. In particular, we show that the interaction vertices are greatly simplified in this formalism as compared to the Einstein-Hilbert perturbation theory. This, in turns, leads to very simple Feynman rules that we employ for the direct computations. Furthermore, this framework naturally extends to wider class of gravitational theories, which encompasses General Relativity as a special case. We compute all the possible tree-level graviton-graviton scattering amplitudes for a general theory from this class. In the GR case the results are in complete accordance with the known expressions in the literature. Moreover, for the general theory distinct from GR, we find new tree-level parity-violating amplitudes. The presence of this new amplitudes is a direct consequence of the fact that the general theory does not exhibit explicit parity invariance.
122 pages, PhD Thesis
  • #1,972
http://arxiv.org/abs/1306.5206
The boundary is mixed
Eugenio Bianchi, Hal M. Haggard, Carlo Rovelli
(Submitted on 21 Jun 2013)
We show that Oeckl's boundary formalism incorporates quantum statistical mechanics naturally, and we formulate general-covariant quantum statistical mechanics in this language. We illustrate the formalism by showing how it accounts for the Unruh effect. We observe that the distinction between pure and mixed states weakens in the general covariant context, and surmise that local gravitational processes are indivisibly statistical with no possible quantal versus probabilistic distinction.
8 pages, 2 figures
http://arxiv.org/abs/1306.4995
Dust time in quantum cosmology
(Submitted on 20 Jun 2013)
We give a formulation of quantum cosmology with a pressureless dust and arbitrary additional matter fields. The dust provides a natural time gauge corresponding to a cosmic time, yielding a physical time independent Hamiltonian. The approach simplifies the analysis of both Wheeler-deWitt and loop quantum cosmology models, broadening the applicability of the latter.
brief mention:
http://arxiv.org/abs/1306.5063
Entropy from near-horizon geometries of Killing horizons
Olaf Dreyer, Amit Ghosh, Avirup Ghosh
We derive black hole entropy based on the near-horizon symmetries of black hole space-times. To derive these symmetries we make use of an (R,T)-plane close to a Killing horizon. We identify a set of vector fields that preserves this plane and forms a Witt algebra. The corresponding algebra of Hamiltonians is shown to have a non-trivial central extension. Using the Cardy formula and the central charge we obtain the Bekenstein-Hawking entropy.
8 pages.
  • #1,973
http://www.fqxi.org/community/forum/topic/1816
Essay Abstract
Relative information at the foundation of physics by Carlo Rovelli
I observe that Shannon's notion of relative information between two physical systems can effectively function as a foundation for statistical mechanics and quantum mechanics, without referring to any subjectivism or idealism. It can also represent the key missing element in the foundation of the naturalistic picture of the world, providing the conceptual tool for dealing with its apparent limitations. I comment on the relation between these ideas and Democritus.
http://www.fqxi.org/community/forum/topic/1831
Information-Based Physics and the Influence Network by Kevin H Knuth
This essay considers a simple model of observers that are influenced by the world around them. Consistent quantification of information about such influences results in a great deal of familiar physics. The end result is a new perspective on relativistic quantum mechanics, which includes both a way of conceiving of spacetime as well as particle “properties” that may be amenable to a unification of quantum mechanics and gravity. Rather than thinking about the universe as a computer, perhaps it is more accurate to think about it as a network of influences where the laws of physics derive from both consistent descriptions and optimal information-based inferences made by embedded observers.
  • #1,974
http://arxiv.org/abs/1306.5332
Super-accelerating bouncing cosmology in asymptotically-free non-local gravity
Gianluca Calcagni, Leonardo Modesto, Piero Nicolini
(Submitted on 22 Jun 2013)
Recently, evidence has been collected that a class of gravitational theories with certain non-local operators is renormalizable. We consider one such model which, at the linear perturbative level, reproduces the effective non-local action for the light modes of bosonic closed string field theory. Using the property of asymptotic freedom in the ultraviolet and fixing the classical behaviour of the scale factor at late times, an algorithm is proposed to find general homogeneous cosmological solutions valid both at early and late times. Imposing a power-law classical limit, these solutions (including anisotropic ones) display a bounce instead of a big-bang singularity, and super-accelerate near the bounce even in the absence of an inflaton or phantom field.
http://arxiv.org/abs/1306.5697
Dynamical Black Holes: Approach to the Final State
Abhay Ashtekar, Miguel Campiglia, Samir Shah
(Submitted on 24 Jun 2013)
Since black holes can be formed through widely varying processes, the horizon structure is highly complicated in the dynamical phase. Nonetheless, as numerical simulations show, the final state appears to be universal, well described by the Kerr geometry. How are all these large and widely varying deviations from the Kerr horizon washed out? To investigate this issue, we introduce a well-suited notion of horizon multipole moments and equations governing their dynamics, thereby providing a coordinate and slicing independent framework to investigate the approach to equilibrium. In particular, our flux formulas for multipoles can be used as analytical checks on numerical simulations and, in turn, the simulations could be used to fathom possible universalities in the way black holes approach their final equilibrium.
http://arxiv.org/abs/1306.5470
Bimetric Gravity, Variable Speed of Light Cosmology and Planck2013
J. W. Moffat
(Submitted on 23 Jun 2013)
A bimetric gravity model with a variable speed of light is shown to be in agreement with the results reported from the Planck satellite in 2013. The predicted scalar mode spectral index is $n_s\approx 0.96$ and its running is $\alpha_s\approx 8\times 10^{-4}$ when the fundamental length scale $\ell_0$ in the model is fixed to be $\ell_0\approx 10^5\ell_P$, where $\ell_P$ is the Planck length $\ell_P=1.62\times 10^{-33}\,{\rm cm}$, giving the observed CMB fluctuations: $\delta_H\approx 10^{-5}$. The enlarged lightcone ensures that horizon and flatness problems are solved. The model is free from many of the fine-tuning problems of the inflationary models and the fluctuations that form the seeds of structure formation do not lead to a chaotic inhomogeneous universe and the need for a multiverse.
http://arxiv.org/abs/1306.5471
Quantum Structures: A View of the Quantum World
Jasmina Jeknic-Dugic, Momir Arsenijevic, Miroljub Dugic
We oer a systematic account of decomposition of quantum systems into parts. Dierent decompositions (structures) are mutually linked via the proper linear canonical transformations. Dierent kinds of structures, as well as their relations, are considered. Emphasis is placed on mutually global and irreducible structures. Is there a privileged structure of the closed system? Is there a preferred (bipartite) structure of an open system? Are there any practical advantages of certain alternative structures of the system? Is there a simple dynamical relation for a pair of structures? The [necessarily partial] answers are rather intriguing. Relativity of quantum correlations (that include entanglement as well as the "one-way" and "two-way" discord) is carefully presented. Emphasis is placed on the "parallel occurrence of decoherence" in the quantum Brownian motion. The environment-selected preferred structure of an open composite system is presented for a pair of harmonic oscillators (or the ?eld modes). A limitation of the Nakajima-Zwanzig projection method appears as a consequence of quantum correlations relativity. Hence, describing dynamics of an alternate open-system is a delicate task. Certain interpretational issues, which include "quantum reference frames" issue, are discussed. Some recent experiments are also discussed. To this end, the option that "there are no particles" on the most fundamental physical level naturally follows. Certain open questions and prospects for further research are highlighted.
  • #1,975
http://arxiv.org/abs/1306.6126
The generator of spatial diffeomorphisms in the Koslowski- Sahlmann representation
Madhavan Varadarajan
(Submitted on 26 Jun 2013)
A generalization of the representation underlying the discrete spatial geometry of Loop Quantum Gravity, to accommodate states labelled by smooth spatial geometries, was discovered by Koslowski and further studied by Sahlmann. We show how to construct the diffeomorphism constraint operator in this Koslowski- Sahlmann (KS) representation from suitable connection and triad dependent operators. We show that the KS representation supports the action of hitherto unnoticed "background exponential" operators which, in contrast to the holonomy-flux operators, change the smooth spatial geometry label of the states. These operators are shown to be quantizations of certain connection dependent functions and play a key role in the construction of the diffeomorphism constraint operator.
8 pages
http://arxiv.org/abs/1306.6142
Consistent probabilities in loop quantum cosmology
David A. Craig, Parampreet Singh
A fundamental issue for any quantum cosmological theory is to specify how probabilities can be assigned to various quantum events or sequences of events such as the occurrence of singularities or bounces. In previous work, we have demonstrated how this issue can be successfully addressed within the consistent histories approach to quantum theory for Wheeler-DeWitt-quantized cosmological models. In this work, we generalize that analysis to the exactly solvable loop quantization of a spatially flat, homogeneous and isotropic cosmology sourced with a massless, minimally coupled scalar field known as sLQC. We provide an explicit, rigorous and complete decoherent histories formulation for this model and compute the probabilities for the occurrence of a quantum bounce vs. a singularity. Using the scalar field as an emergent internal time, we show for generic states that the probability for a singularity to occur in this model is zero, and that of a bounce is unity, complementing earlier studies of the expectation values of the volume and matter density in this theory. We also show from the consistent histories point of view that all states in this model, whether quantum or classical, achieve arbitrarily large volume in the limit of infinite 'past' or 'future' scalar 'time', in the sense that the wave function evaluated at any arbitrary fixed value of the volume vanishes in that limit. Finally, we briefly discuss certain misconceptions concerning the utility of the consistent histories approach in these models.
22 pages, 3 figures
  • #1,976
http://arxiv.org/abs/1306.5805
Is the Pusey-Barrett-Rudolph Theorem Compatible with Quantum Nonseparability?
Maximilian Schlosshauer, Arthur Fine
The Pusey-Barrett-Rudolph (PBR) no-go theorem targets a class of "epistemic" hidden-variables models in which hidden variables associated with distinct quantum states overlap. We show that the PBR strategy leads to a no-go result that would also rule out nonepistemic ("ontic") models. Moreover, it would rule out a vast class of deterministic hidden-variables theories, even those known to be consistent. The strength of this result calls into question a central assumption of the PBR strategy about how hidden variables of composite systems relate to hidden variables of components.
http://www.fqxi.org/community/forum/topic/1842
Essay Abstract
It from Qubit by Giacomo Mauro D'Ariano
In this essay I will embark on the venture of changing the realist reader’s mind about the informational viewpoint for physics: “It from Bit”. I will try to convince him of the amazing theoretical power of such paradigm. Contrary to the common belief, the whole history of physics is indeed a winding road making the notion of “physical object”–the “It”–fade away. Such primary concept, on which the structure of contemporary theoretical physics is still grounded, is no longer logically tenable. The thesis I advocate here is that the “It” is emergent from pure information, an information of special kind: quantum. The paradigm then becomes: “It from Qubit”. Quantum fields, particles, space-time and relativity simply emerge from countably infinitely many quantum systems in interaction. Don’t think that, however, I can cheat by suitably programming a “simulation” of what we see. On the contrary: the quantum software is constrained by very strict rules of topological nature, which minimize the algorithmic complexity. These are locality, unitariety, homogeneity, and isotropy of the processing, with minimal quantum dimension. What is amazing is that from just such simple rules, and without using relativity, we obtain the Dirac field dynamics as emergent.
  • #1,977
George F R Ellis
I have read both, the rules for that forum and the article. I find that it is an interesting and very clear exposé of a controversial and difficult problem (The inflation of our universe and the equation of state for the vacuum remain two puzzling item, so far I know).
Staying exclusively at the mathematical and physical level of the discussion, I get some confusion because of the fact that the conversation introduces (see p. 6) three different mass densities: the effective, the gravitational and the inertial one. Furthermore, equation (21) page 6 indicates an obvious difference between the gravitational and the inertial mass density. Isn't it in contradiction with some fundamental principle stating the equivalence between inerty and gravitation? What did I certainly miss? Thanks for explaining better, if possible.
  • #1,978
Blackforest, our custom here is to reserve this thread for bibliography and start a separate discussion thread for any paper we want to discuss. I have quoted your post, with your question, in order to start a discussion thread.
https://www.physicsforums.com/showthread.php?p=4428693#post4428693
The idea is not to overload this thread and interfere with bibliography function.
  • #1,979
http://arxiv.org/abs/1307.0096
Elementary Particles as Gates for Universal Quantum Computation
Deepak Vaid
(Submitted on 29 Jun 2013)
It is shown that there exists a mapping between the fermions of the Standard Model (SM) represented as braids in the Bilson-Thompson model, and a set of gates which can perform Universal Quantum Computation (UQC). This leads us to conjecture that the "Computational Universe Hypothesis" (CUH) can be given a concrete implementation in a new physical framework where elementary particles and the gauge bosons (which intermediate interactions between fermions) are interpreted as the components of a quantum computational network, with the particles serving as quantum computational gates and the gauge fields as the information carrying entities.
  • #1,980
http://arxiv.org/abs/1101.5185
Einstein Manifolds As Yang-Mills Instantons
John J. Oh, Hyun Seok Yang
(Submitted on 27 Jan 2011 (v1), last revised 2 Jul 2013 (this version, v4))
It is well-known that Einstein gravity can be formulated as a gauge theory of Lorentz group where spin connections play a role of gauge fields and Riemann curvature tensors correspond to their field strengths. One can then pose an interesting question: What is the Einstein equations from the gauge theory point of view? Or equivalently, what is the gauge theory object corresponding to Einstein manifolds? We show that the Einstein equations in four dimensions are precisely self-duality equations in Yang-Mills gauge theory and so Einstein manifolds correspond to Yang-Mills instantons in SO(4) = SU(2)_L x SU(2)_R gauge theory. Specifically, we prove that any Einstein manifold with or without a cosmological constant always arises as the sum of SU(2)_L instantons and SU(2)_R anti-instantons. This result explains why an Einstein manifold must be stable because two kinds of instantons belong to different gauge groups, instantons in SU(2)_L and anti-instantons in SU(2)_R, and so they cannot decay into a vacuum. We further illuminate the stability of Einstein manifolds by showing that they carry nontrivial topological invariants.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 0 ·
