Phase-Locked Loop: Understanding Coherent Demodulation of AM
  • Thread starter Thread starter cyeokpeng
    Loop
The discussion focuses on the Phase-Locked Loop (PLL) system's role in coherent demodulation of Amplitude Modulated (AM) signals. Key components of a PLL include a Voltage-Controlled Oscillator (VCO), a phase detector, and often a loop filter, which collectively ensure that the local oscillator frequency aligns with the carrier frequency of the received AM signal. The conversation highlights the importance of feedback mechanisms in maintaining frequency stability and addresses the design differences between first-order and second-order PLL systems. Participants also explore the concept of steady-state phase error and its implications in PLL stability.
  • Understanding of Phase-Locked Loop (PLL) systems
  • Knowledge of Voltage-Controlled Oscillators (VCO)
  • Familiarity with phase detectors and loop filters
  • Basic principles of feedback control systems
  • Study the design principles of first-order and second-order PLL systems
  • Learn about the mathematical analysis of PLL transfer functions
  • Explore the final value theorem in Laplace transforms
  • Investigate the effects of steady-state phase error in PLL systems
Electrical engineers, communications specialists, and students studying control systems or signal processing who seek to deepen their understanding of Phase-Locked Loops and their applications in coherent demodulation.
cyeokpeng
Though I have gone through a communications course in EE, I am still very blur about the Phase-locked loop system in performing coherent demodulation of AM signal.
The problem with direct coherent detection straight from the received AM signal from the receiver antennae is that the local oscillator cannot reproduce the exact same carrier frequency to be hecterodyned with the AM signal to bring it back to baseband. Many reasons colud have caused that, for example, the phenomenon of frequency shifting due to relative motion of the Tx or the Rx (What is the name I forgot), etc etc. So there needs to be a negative feedback to ensure the frequency of the local oscillator approaches the frequency of the carrier in the AM signal. But I really do not understand the mathematics analysis of the system. Can anyone give me an insight to that?
A phase-locked loop generally consists of at least two parts:
1) A voltage-controlled oscillator (VCO). A higher input voltage results in a higher frequency, for example.
2) A phase detector. This device compares the phase of the received carrier and the oscillator's output, and produces an error signal. The error signal is fed back into the VCO to adjust its frequency.
Many PLLs also include a thrid component:
3) Loop filter. This filter generally is designed for a specific application, and prevents ringing, overshoot, and other unwanted behavior. The loop filter keeps the loop stable.
Keep in mind that a constant phase error corresponds to a simple frequency error. If the received carrier has a higher frequency than the VCO, the phase error will be constantly positive, making the VCO oscillate more rapidly. If the received carrier has a lower frequency than the VCO, the phase error will be constantly negative, making the VCO oscillate more slowly.
- Warren
Mmm, I am a bit clearer now.
Another question, the PLL can be designed to be a first-order PLL or second-order PLL. How do you design such PLL systems such that they have different order transfer function characteristics? I have just learn feedback theory, systems and control course, and I still do not know how to find the transfer function of a system H(s) with a feedback transfer function H1(s).
And what is the meaning of steady state phase error?
My conception of steady-state phase error is the steady state phase error output signal when passed through the PLL system, and since the PLL is designed to be stable (in phase lock), the steady state phase error will be finite, and we can use the final value theorem of Lasplace tranform to work out its steady state phase error value.
Hope I am correct.
  • · Replies 46 ·
  • · Replies 29 ·
  • · Replies 31 ·
13K
10K
