Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > General Physics
Closed Thread
image Maximun energy of a photon Share It Thread Tools image
Old Jul30-03, 03:55 PM                  #1
JAL
JAL is
Posts: n/a
Question Maximun energy of a photon
Please explain the error in this logic (if any):
E = hc / λ
Where
h = Planck Constant = 6.62606876 x 10-34 Js
c = Speed of light = 299792458 m/s
λ = Wavelength
The wavelenght can't possibly be smaller than Planck Length (1.6160 x 10-35 m) yields:
Maximun Energy = 12292360398.7464 J
Maximun Energy = 7.6722887211823E+28 ev
Is this valid? Is there a limit on how much energy an photon can carry? I've never heard of that...
Old Jul30-03, 04:53 PM                  #2
AndersHermansson
AndersHermansson is Offline:
Woops
Old Jul30-03, 06:29 PM                  #3
jcsd
jcsd is Offline:
Recognitions:
What's you argument for a phton's wavelength not being smaller than the Planck length? I mean the compton wavelength of a flea is about the same as the Planck length. Are you saying that a photon with a wavelength of the pPlanck length would be unable to escape it's own gravitaional field, cos I believe that's been theorized, but I'm unsure.
Old Jul31-03, 10:08 AM                  #4
JAL
JAL is
Posts: n/a
Actually I was just wondering if there is a minumum wavelength for EM radiation and if so if it is the Planck Lenght? This would mean that there is a limit to the energy of a photon can carry.
Old Jul31-03, 10:17 AM                  #5
jcsd
jcsd is Offline:
Recognitions:
All I can say is probably not, the idea that a photon will collapse under it's own graviational field is fallacious (it forgets blue-shifting), unless there's something I'm unware of I don't see why a photon can't have a wavelength > the Planck length, though such a photon would be unstable with any interaction probably forming an electron-positron pair. Infact Isaac Asimov (I don't like quoiting sci-fi authors but anyway) said that the maximum energy of a photon was the energy of the cosmos and the minimum energy was the enrgy corresponding to a photon with a wavelength the same as the size of the cosmos.
Old Jul31-03, 01:05 PM                  #6
russ_watters
PF Mentor
russ_watters is Online:
I'm not sure what gravity has to do with this, jcsd - JAL din't mention it. Planck's constant is the "size" of quantum uncertainty. I don't think a photon can have a wavelength shorter than that.
Old Jul31-03, 01:11 PM                  #7
Brad_Ad23
Brad_Ad23 is Offline:
Well I would suggest doing some simple quantum calculations with escape velocity as well.
However, it does seem that a photon of that small wavelength would be extremely energetic for a photon, and hence would be very unstable.
Old Jul31-03, 05:56 PM                  #8
jcsd
jcsd is Offline:
Recognitions:
Yep, but it has been suggested in a physics report that the Planck length is the maximum length for a virtual photon as any photon with a wavelength greater than this would collapse in it's own graviational field like a black hole. This logic is obviously fallacious as from a different reference frame the photon's wavelength would be blue-shifted above the Planck wavelength so following this logic it wouldn't collapse in this reference frame, so we must reject it collapsing in a refernce frame where it's wavelength is below the Planck length.
Macroscopic objects, including yourself, generally have Compton wavelengths below the Planck length, why not a photon? There is no comopelling reason to think that photons with wavelengths smaller than the Planck length could at exist in theory.
Old Aug1-03, 09:15 AM                  #9
wimms
wimms is Offline:
confused. Did you mean that photon with wavelength 'shorter' than planck's would collapse, and that redshift would 'avoid' that? Shouldn't frame of photon be the only one that matters (if such q makes sense)?
Photon at planck length would have mass of 1.5E+23 Me. Shouldn't such 'thing' condense into matter?
Old Aug1-03, 01:07 PM                  #10
drag
drag is Offline:
Recognitions:
SST says the photon will grow instead of becoming
smaller, I think. [t)]
Live long and prosper.
Old Aug1-03, 02:11 PM                  #11
jcsd
jcsd is Offline:
Recognitions:
No, as I said before the premise behind it is faulty, as considering a differen refrence frames the wavelength would be different.
Photons don't have mass, but yes, such a high energy phton is unstable and would after nearly any interaction change into massive particles.
Old Aug1-03, 03:03 PM                  #12
russ_watters
PF Mentor
Isn't that just a mathematical average? Analagous to the idea of light "slowing down" when traveling through a medium?
You mean could NOT exist, right? There is no compelling reason to think they could NOT exist? I still think HUP is a pretty compelling reason (not that I necessarily understand it all that well).
Old Aug1-03, 03:08 PM                  #13
JAL
JAL is
Posts: n/a
What is HUP?
Old Aug1-03, 03:28 PM                  #14
JAL
JAL is
Posts: n/a
Upper end of the electromagnetic spectrum
Question answered by an High Energy Astronomer at:
http://imagine.gsfc.nasa.gov/docs/as...s/970412e.html
Old Aug1-03, 06:09 PM                  #15
Integral
PF Mentor
Integral's Avatar
Integral is Offline:
HUP=Heisenberg Uncertiantiy Priciple.
Old Aug1-03, 06:14 PM                  #16
jcsd
jcsd is Offline:
Recognitions:
Re: Upper end of the electromagnetic spectrum
For some reason I can't open that page, could you quote the relevant sections?
image image
Closed Thread
Thread Tools
Similar Threads for: Maximun energy of a photon
Thread Thread Starter Forum Replies Last Post
energy of the photon leah0084 Introductory Physics 4 Sep23-07 04:22 PM
Maximun bps rate on an ITU channel over standard single mode fiber jga General Engineering 1 May27-07 10:41 AM
Help - energy of a photon :-/ Yael Introductory Physics 2 Mar27-06 11:36 AM
help - energy of a photon Yael Introductory Physics 1 Mar26-06 05:45 PM
energy of a photon UrbanXrisis Introductory Physics 9 May17-04 01:53 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
