What is the limit of \(\lim_{n\rightarrow\infty}(\frac{n+1}{n})^{n+1}\)?
  • Thread starter Thread starter Nerpilis
    Limits
The discussion revolves around evaluating the limit \(\lim_{n\rightarrow\infty}(\frac{n+1}{n})^{n+1}\) and a related limit \(\lim_{n\rightarrow\infty}(\frac{n+3}{n+1})^{n+4}\). Participants explore the implications of the expressions and their relationships to known limits, particularly those involving the number \(e\).
  • Participants discuss rewriting the limits to resemble known forms, such as those related to \(e\). There is exploration of the impact of the exponent and the structure of the limits. Some participants express uncertainty about the effects of certain terms and question the validity of their reasoning.
The conversation is active, with participants providing insights and corrections to each other's reasoning. Some guidance has been offered regarding the structure of the limits and the use of known limit forms. There is an ongoing examination of assumptions and interpretations, particularly concerning the behavior of the limits as \(n\) approaches infinity.
Participants are navigating the complexities of limits involving expressions that approach \(e\) and are considering the implications of additional terms in the exponents. There is a noted uncertainty regarding the application of limit rules and the interpretation of results.
Nerpilis
find the [tex]\lim_{n\rightarrow\infty}(\frac{n+1}{n})^{n+1} =[/tex]
so far what i have is
[tex]\lim_{n\rightarrow\infty}(\frac{n+1}{n})^{n+1} = \lim_{n\rightarrow\infty}(\frac{n}{n} + \frac{1}{n})^{n+1} = \lim_{n\rightarrow\infty}(1 + \frac{1}{n})^{n+1}\\[/tex]
I know this has got to go to [tex]e[/tex] or something very close, my question lies in if I should be concerned with the +1 in the n+1 in the exponet.
There is another one which I'm totally stumped on for a starting point, my gut tells me the limit is 1 or it may not even exist altogether.
[tex]\lim_{n\rightarrow\infty}(\frac{n+3}{n+1})^{n+4} =[/tex]
but then again it could be +[tex]\infty[/tex] if you realize that in the () the numerator is larger than the denominator such that as the exponet is applied it goes to infinity instead od zero.
You said you already have a suspicion that the limit should have to do with e. So I assume you know the limit definition of e which has a very similar form?
The second has a very similar form. Can you rewrite it so the form resembles a limit you already know? (Like that of exp(x) or something).
Did you notice that
[tex]\left(1+\frac{1}{n}\right)^{n+1}[/tex]
is the same as
[tex]\left(1+\frac{1}{n}\right)^n \left(1+ \frac{1}{n}\right)[/tex]
no I did not realize that [tex]\left(1+\frac{1}{n}\right)^n \left(1+ \frac{1}{n}\right)[/tex] I guess that would make the limit equal to e^2?
as far as the second problem I don't know what exp(x) is but i recognized that I can get things to look more like e
[tex]\lim_{n\rightarrow\infty}((\frac{n + 3}{n + 1})(\frac{1/n}{1/n}))^{n+4} =[/tex]
[tex]\lim_{n\rightarrow\infty}\frac{(1 + (3/n))^{n+4}}{(1 + (1/n))^{n+4}} =[/tex]
from here the denominator looks similar to e and the numerator almost looks like e, however I’m a little hesitant to call the limit e/(e^4) = 1/(e^3) therefore I applied bernouli’s inequality to the numerator :
[tex]\geq \lim_{n\rightarrow\infty}\frac{1 + (n + 4)(3/n)}{e^{4}} \geq \frac{\lim_{n\rightarrow\infty}(1 + 3 + (12/n))}{e^{4}} \geq \frac{4}{e^{4}}[/tex]
Is my thinking correct in operating this way?
No. Why don't you just write it out and use some limit rules. This looks like the limit of a product of 2 factors, both with limits you know.
Don't just guess what you think the limit should be. What makes you think that:
[tex]\lim_{n\to \infty} \left(1+\frac{1}{n}\right)^{n+4}=e^4[/tex]
? You can solve this limit in the same way as the previous one by considering it a product of 2 limits.
For a limit like: [itex]\lim_{n\to \infty} (1+x/n)^n[/itex] which looks a lot like the one for e, what method would be useful? (Hint: substitution)
Another way is to write:
[tex]\frac{n+3}{n+1}=\frac{n+1+2}{n+1}=1+\frac{2}{n+1}[/tex]
thank you , i have found my errors
[tex]\lim_{n\rightarrow\infty}\left(1+\frac{1}{n}\right)^n \left(1+ \frac{1}{n}\right) = e \times \lim_{n\rightarrow\infty}\left(1+ \frac{1}{n}\right) = e[/tex]
for the other one:
[tex]\lim_{n\rightarrow\infty}\left(\frac{n+3}{n+1}\right)^{n+4}= \lim_{n\to \infty} \left(1+\frac{2}{n+1}\right)^{n+4} = \lim_{n\rightarrow\infty}\left(1 + \frac{2}{n+1}\right)^{n+1}\left(1 + \frac{2}{n+1}\right)^{3} = \lim_{n\rightarrow\infty}\left(1 + \frac{2}{n+1}\right)^{n+1} \times 1[/tex]
now i have found that this actually goes to [tex]e^{2}[/tex] but i did get some help but i don't know how to prove it other than writing out the sequence values for e and then for this sequence [tex]\lim_{n\rightarrow\infty}\left(1 + \frac{2}{n+1}\right)^{n+1}[/tex]
and noticing that e is a subsequence of the above
You can make a substitution: m=n/x. That makes:
[tex]\lim_{n\to \infty} \left(1+\frac{x}{n}\right)^n[/tex]
look like:
[tex]\lim_{m\to \infty}\left(1+\frac{1}{m}\right)^{xm}[/tex]
Or m-> -infinity if x is negative.
  • · Replies 20 ·
