Calculating the Length of a Function
  • Context: Undergrad
  • Thread starter Thread starter daniel_i_l
    Function Length
The discussion revolves around the calculation of the length of a function, specifically focusing on the arc length of curves defined by functions. Participants explore different formulations and conditions related to this concept.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant presents an equation for the length of a function, L(x) = ∫√(f'(x)² + 1)dx, derived from the slope of a line.
  • Another participant clarifies that for a vector function, the arc length is given by ℓ = ∫ₐᵇ ||d𝑓/dt|| dt, noting conditions for continuity and existence of derivatives.
  • The same participant explains that when a function is expressed as y = f(x), the formula simplifies to ℓ = ∫ₐᵇ √(1 + y'²) dx.
  • There is an exchange confirming that the topic being discussed is indeed arc length.
Participants generally agree on the topic of arc length, but there are variations in the formulations and assumptions presented. No consensus is reached on the correctness of the initial equation proposed.
Limitations include the need for continuity and existence of derivatives in the context of arc length calculations, which are not fully explored in the discussion.
daniel_i_l
My friend told me that they had just learned an equation to find the length of a function. I decided that it would be cool to try to find it myself. I got: [tex] L(x) = \int \sqrt(f'(x)^2 +1)dx[/tex]
I got that by saying that the length of a line with a slope of a over a distance of h is: [tex]\sqrt(f'(x)^2 +1)[/tex]
Am I right?
In general, when a function f is determined by a vectorfunction (so you have a parameter equation of the curve), the arc length is given by:
[tex]\ell = \int_a^b {\left\| {\frac{{d\vec f}}<br /> {{dt}}} \right\|dt}[/tex]
There are of course conditions such as df/dt has to exist, be continous, the arc has to be continous.
Now when a function is given in the form "y = f(x)" you can choose x as parameter and the formula simplifies to:
[tex]\ell = \int_a^b {\sqrt {1 + y'^2 } dx}[/tex]
Which is probably what you meant :smile:
Thanks!:biggrin: :biggrin:
You're talking about arc length, right?
Yes, at least that's what I assumed.
  • · Replies 25 ·
