What is the Official Definition of Glass?
  • Context: High School
  • Thread starter Thread starter mceddy2001
    Glass Liquid Solid
The discussion revolves around the definition of glass, particularly whether it should be classified as a solid or a liquid. Participants explore various perspectives on the nature of glass, including its amorphous characteristics and the implications of its historical manufacturing processes. The conversation touches on theoretical definitions and the physical properties of glass.
  • Some participants suggest that glass is an "amorphous liquid," indicating it lacks a crystalline structure.
  • Others argue that glass should be classified as a solid because it does not flow under normal conditions.
  • A participant mentions that the debate about glass being a liquid originated from observations of old glass panes in cathedrals, which were found to be thicker at the bottom, leading to the belief that glass flows over time.
  • Further contributions highlight that some old panes were found to be thicker at the top or unevenly distributed, suggesting manufacturing inconsistencies rather than fluidity.
  • Some participants discuss the definitions of solids and liquids, questioning whether a substance can be classified as a liquid if it does not flow in certain conditions, such as in outer space.
  • There is mention of glass's behavior under temperature changes, with one participant noting that glass does not have a definitive freezing point and changes viscosity with temperature.
  • One participant cites a chemistry textbook that classifies glass as an amorphous solid, prompting discussions about the implications of this classification.
  • Another participant raises a hypothetical question about whether all materials could eventually be considered liquids over long periods under gravity.
Participants express multiple competing views regarding the classification of glass, with no consensus reached on whether it is a solid or a liquid. The discussion remains unresolved, with various definitions and interpretations presented.
Participants note that definitions of solids and liquids may depend on specific conditions and contexts, and there is uncertainty regarding the implications of glass's amorphous nature and its behavior under different physical conditions.
mceddy2001
Ive heard some arguments for and against glass being a liquid. But what is it officially?
An 'amorphis' liquid. (means 'without shape')
It's also heard by me...
But first we have to purely define
WHAT IS SOLID AND WHAT IS LIQUID ?
What's your opinion?
It's NOT an opinion, 'solids' do not (generally speaking) change shapes, 'liquids' take on the shape of the vessel that they are deployed within, but do not change volume, as a 'gas' would...see chemistry; 101
Supercooled liquid is the way I had it explained to me.
It is my understanding that this entire debate get started because certain very large very old (400 years plus) panes of glass in the old cathedrals and the like were found to be significantly thicker at the bottom then they were at the top. This led to the conclusion that the glass was actually a highly viscous fluid and over its 400-500 years of existence was slowly "flowing" to the bottom of the pane.
However, I later heard that further research revealed some of 400-year-old panes of glass that were thicker at the top then at the bottom. Still others were thicker on the right side or the left.
Turns out, 400 years ago glassmakers simply did not have the technology to extrude a large pane of glass of uniform thickness. After that, I rather lost track of the subject.
Too right. I'm sick of hearing that glass is a liquid. This is one of those stupid urban myths that just gets retold all the time. What other scientific 'fact' depends on the study of old artefacts. (actually I can think of many...but you know what I mean)
Evidence please!
glass is a supercooled liquid.
Glass is amorphous substances that has no crystalline form. Amorphous substances can be thought of as supercooled liquids. The application of an external force over a period of time causes these materials to flow and become permanently deformed.
-Benzun
All for god.
Pretty slick, heh?
Yes - that's one way out of a conumdrum, redefine things!
And as I said - it DOESN'T flow!
So I stand corrected.
So... A liquid can be defined as a substance that flows? How many liquids flow in outerspace and thefore would glass be a liquid if the gravity of the planet it was on, was not strong enough to accelerate the particles down towards the ground. At a certain pressure would glass be a solid and what is the freezing point of glass?
regular glass does not have a freezing point, per se. (and I'm talking about normal pressures; I don't know what the deal is in very high or very low pressures). Glass changes its viscocity as temperature increases. Most things do, but glass never hits a point where temperature stops going up while it melts. So the opposite is also true: temperture does not stop going down while it freezes.
So glass will go from a "solid" that will change its shape if pressure is applied slowly, to a thick fluid, to a thinner fluid, and etc.
By the way, a "fluid" is defined as anything that flows. THis includes gasses as well as liquids.
The chemistry textbook in front of me classes glass as an amorphous solid. Same class as rubber and butter.
Isn't that an oxymoron?
No. "Amorphous" just means "Lacking distinct crystalline structure." Though most solids have a distinct chrystal structure, it isn't required. And even those that do have many flaws in the structure. A perfect chrystal is extremely difficult to achieve. However, given what we have seen in this thread, I'd say the definition of "glass" in Adam's textbook may be incomplete. What level is the book, Adam?
University level, first year chemistry. I did not copy in everything the book says, merely wanted to say what class of matter glass is.
here's one for ya, couldn't all things be determined to be liquid? i'd imagine that after a long enough time that the atoms in "solid" objects would begin to droop (if gravity is applied for the duration) thus allowing for a say a rock to occupy any shape of container. would i be incorrect in assuming that would be possible?
Russ, I may have spelt it wrong but I got the definition of it right, first page, second post...
Clearly spelt "Amorphous" not the manner in which I originally spelled it.
  • · Replies 26 ·
  • · Replies 37 ·
  • · Replies 44 ·
16K
  • · Replies 20 ·
  • · Replies 19 ·
16K
