Rocket escaping Earth's atmosphere
In summary: But if you have unlimited energy, you could theoretically lift off and gain altitude at a rate of one mile per hour all the way to the moon.
Indy
Hey guys, I didn't really know where to put this and this seemed like the most logical place. Also sorry if there's already been a post like this, I tried searching and couldn't find anything.
Anyway, onto the question. I'm sort of confused about some things to do with rockets and such.
First of all, how fast would something have to be going when it left the ground to escape Earth's gravitational pull and ride off into space?
Secondly, why do people say that space is 62 miles above the ground when parts of our atmosphere reach up to 400km away?
Thirdly(?), does anybody here know if NASA give scholarships to Universities in the UK? I've searched on their website and things but can't seem to find anything other than for schools in the US.
Thanks in advance,
Indy
[edit] Also, one more question. Do singularities have infinite mass? Because if they do wouldn't everything in the universe be pulled toward them at an infinite velocity?
Right around 11 km/sec to totally escape, about 8 km/sec to attain orbit. Though rockets wouldn't "leave the ground" at this speed. If they tried, they would burn up from air friction. What they do is accelerate through the atmosphere, and by the time they reach these types of speeds they're high enough for air resistance to longer be a problem.
This should help answer your question:
http://www.aerospaceweb.org/question/atmosphere/q0090.shtml
I don't know, but being a US government agency, my quess would be no.
Thanks in advance,
Indy
No, they would not have infinite mass, they would have a finite mass compressed to zero volume.
NASA might support US students abroad - but that seems unlikely.
If one is a citizen of UK or other European nation, one should look to ESA, or perhaps contact a particular university or aerospace department about where one might obtain a scholarship.
Cool thanks guys, you've answered all my questions.
Thanks again,
Indy.
One thing that is often taken for granted is that escape velocity is an artificial hurdle set by technology.
You need to achieve that velocity before you run out of fuel and your engines shut down. You will need that velocity to be able to coast out of Earth's gravity well.
On the other hand, if you have a (futuristic) fuel supply that is unlimited, then there is no such thing as escape velocity. You could lift off and gain altitude at a rate of one mile per hour all the way to the Moon if you wanted to.
The constraints on rocket performance are not artificial, but real constraints imposed by the nature of materials, e.g. pressure which is contrained by strength of materials, which decreases with increasing temperature. The challenge to us is to understand those constraints and expand the envelope while preventing failure. There is only so much energy one can obtain from a material/physical system.
On the other hand, if you have a (futuristic) fuel supply that is unlimited, then there is no such thing as escape velocity. You could lift off and gain altitude at a rate of one mile per hour all the way to the Moon if you wanted to.[/QUOTE]
1 mph? Seems a bit slow. At 1 mph, it would take about ~240,000 hrs (~10,000 days or 27.4 yrs) to get to the moon.
Perhaps one meant an acceleration of 1 mph/s or 1 mph/min?
We don't have access to an infinite supply of propellant, with the exception of the solar wind and GCR which don't provide a lot of thrust.
I'm not sure if you're refuting my statements or not.
Perhaps I should clarify that my comments are really academic in nature. They are about the principle of space travel from Earth, not much use in practice for the forseeable future.
What I"m trying to say is that escape velocity is only a critical target because, in practice, we must shut our rockets down and coast since we can only carry so much fuel. If we run out of fuel at any velocity less than escape velocity, our rocket will fall back to Earth (or into an elliptical orbit).
But in principle if we did not run out of fuel, we do not have to reach any specific velocity. Yes, if we chose to, we could travel at 1mph all the way to the Moon.
I'm not suggesting we'd want to; I just wanted to dispel the possible myth that it is impossible to escape a planetary gravity well without acheiving escape velocity.
But even traveling at 1 mph away from the Earth, you will reach escape velocity if you travel far enough, since you will eventually reach a distance where the escape velocity is 1 mph.
1. How does a rocket escape Earth's atmosphere?
A rocket escapes Earth's atmosphere by generating enough thrust to overcome the gravitational pull of the planet. It does this by igniting its engines and using their powerful force to propel itself upwards. As the rocket moves away from the surface of the Earth, it enters the thinner atmosphere of outer space and is able to continue its journey.
2. What is the main challenge in escaping Earth's atmosphere?
The main challenge in escaping Earth's atmosphere is the strong gravitational pull of the planet. This requires a rocket to have a powerful and efficient engine that can generate enough thrust to lift the rocket and its payload off the ground.
3. How fast does a rocket need to travel to escape Earth's atmosphere?
A rocket needs to travel at a speed of approximately 7 miles per second, or 25,000 miles per hour, to escape Earth's atmosphere. This is known as the escape velocity and is the minimum speed required to overcome Earth's gravitational pull.
4. What happens to a rocket as it leaves Earth's atmosphere?
As a rocket leaves Earth's atmosphere, it first passes through the troposphere and then into the stratosphere. As it continues to ascend, it enters the mesosphere and then the thermosphere. Finally, it reaches the exosphere, which marks the boundary between Earth's atmosphere and outer space. At this point, the rocket is able to continue its journey into space.
5. Are there any risks associated with escaping Earth's atmosphere?
Yes, there are several risks associated with escaping Earth's atmosphere. These include the high forces and temperatures experienced during liftoff, the potential for mechanical failures or malfunctions, and the exposure to high levels of radiation in space. Rocket scientists and engineers work hard to mitigate these risks through thorough testing and safety measures.
  • Atomic and Condensed Matter
  • Astronomy and Astrophysics
  • Earth Sciences
16K
  • Aerospace Engineering
