Sum of Numbers with distinct digiits?
In summary, the conversation discussed finding the sum of all 4536 numbers with distinct digits from 1000 to 10000. Various methods and strategies were suggested, such as adding pairs of numbers and considering the contributions of each digit. The final solution was determined to be 45 * 504 * 10^3 + 45 * 448 * 10^2 + 45 * 448 * 10 + 45 * 448.
FryerMath
I need to find the sum of all 4536 numbers with distinct digits from 1000 to 10000 (so 4 digit numbers). Now, I developed a primary method for a solution but its too time consuming! anybody have any clever ideas?
Are you allowed to make a program that calculates it?
No. Do it analytically please.
I think the purpose is for you to work this out on your own. But I will get you on the right path.
Suppose you write the numbers down twice only in two columns. In the first column write then in the order 1000, 1001, 1002 ... 9999. In the second column you assume the numbers are written in reversed order. If I understand you there should be 9000 numbers in each column, not the 4536 total you mentioned in your post. Now suppose you add the pair in each row and put in column 3: 1000 + 9999 = 10999; 1001 + 9998 = 10999; 1002 + 9997 = 10999; ... 9999+1000 = 10999.
How many 10999's will ther be in column 3 when you are done.
What is the sum of these 10999's represent ( in respect to the sums of the numbers in columns 1 and 2)?
Edit OK I think I see why there are only 4536 total numbers. Each of the four digits must be distinct! That calls for a more specific solution.
With each digit from 1 to 9 in the thousands position you have 9*7*6 total ways to write the remaining digits. So the total of the sum of the digits in the thousands position will be T(9) * 9*8*7 or 45*9*8*7. You use a slightly different method to total the digits from 1 to 9 in the 100's, 10's and 1's positions. Zeros don't count in the sum but they figure in the determination of how many of each digit there would be in the 1000's, 100's or 10's or 1's.
No, sorry. The digits of the numbers have to be distinct
doing what you explained would be a lot easier though
just use n(n+1)/2 from 1-10,000 and then again from 1-1000 and subtract the second from the first
9*C(9,3)*3!=4536
4536/9=504
digit 1000
0 * 0
1 * 504 = 504
2 * 504 = 1008
9 * 504 = 4536
sum = 22680
why 504 & 448? <--- ?
digit 100
0 * 504 = 0
1 * 448 = 448
9 * 448 = 4032
sum = 20160
digit 10
digit 1
20160*3 + 22680 = 83160
Sorry, No. There are 4536 numbers with each valuing above 1000. So, the SUM must be at least 4536,000 (BUT it is more!).
I think that Xitami has the right idea, but left out some details. Let's consider
[tex]abcd = 10^3 a + 10^2 b + 10 c + d[/tex]
where a, b, c, d are distinct integers between 0 and 9, and [itex]a \neq 0[/itex]. The problem is to sum all numbers abcd that meet these conditions. First, we sum the contributions from the leading digit. The leading digit can take any of the values 1, 2, ..., 9. For any choice of the leading digits there are 9x8x7 = 504 choices for the next three digits. Therefore, the sum of the leading digits is
[tex]1 \cdot 10^3 \cdot 504 + 2 \cdot 10^3 \cdot 504 + \cdots + 9 \cdot 10^3 \cdot 504 = 45 \cdot 504 \cdot 10^3[/tex]
Next we consider the contribution of the second digit to the sum. The second digit b can take any of the 10 values 0, 1, ..., 9. If b = 0, then there are again 9x8x7 choices for the remaining digits. For each choice of b = 1, 2, ..., 9, there are 8 possibilities for a (since a can't equal 0), 8 choices for c (since c can equal 0) and 7 choices for d, a total of 8x8x7 = 448. If b = 0, it contributes nothing to the sum, so we may disregard it. Therefore, the total contribution of the second digit to the sum is
[tex]1 \cdot 10^2 \cdot 448 + 2 \cdot 10^2 \cdot 448 + \cdots + 9 \cdot 10^2 \cdot 448 = 45 \cdot 448 \cdot 10^2[/tex]
The contributions of the third and fourth digits to the sum are handled similarly. I'll let you work it out from here. Post your final answer and I'll tell you if it agrees with mine.
I think that both myself and Xitami left out some detail for FryerMath to fill in. I just gave the sum of the digits in the thousands position 45*9*8*7. I see FryerMath knew to multiply that figure by 1000. I was hoping he would see how to arrive at the figure 45*8*8*7 for the sum of the digits in the 100's position himself. As you say a similar analysis such as you gave should apply to the 10's and 1's digit sums.
PS I should have edited out the steps to find the sum of all 4 digit numbers as soon as I saw it irrelevant as it was a distraction from my final message.
Petek, you were correct! Thank you! I verified the solution with a collegue. I summed the values up to be 24887520
You seem to be off by some 30 + thousand.
My way:
If we allow for leading zeros (the numbers 0123-9876) the solution is quite obviously 4999.5 * 10!/(10-4)! (because every digit at every place is equiprobable)
so if we just subtract off the 3 digit numbers we're good.
We can calculate 3 digit numbers with the same method as above but this includes 2 digit numbers that aren't included in the 4 digit calculation... and so on...
the final calculation is thus:
4999.5 * 10!/(10-4)! - 499.5 * 10!/(10-3)! + 49.5 * 10!/(10-2)! - 4.5 * 10!/(10-1)!
24,842,250
Perfection said:
My way:
24,842,250
I think Petek, Xitami and I each came up with 24,917,760 as the answer. Using your method I would put it at 1111*45*9!/(9-3)! - 111*45*9!/(9-2)! + 11*45*9!/(9-1)! -45 or 24,842,250 which is your answer. I am not sure why your method gives a different answer, but I am certain that 1000*45*9*8*7 + 111*45*8*8*7 which equals 24,917,760 is the correct answer.
Yeah, there's double counting here. For instance 0104 would be subtracted from the total erroneously.
Crud!
Yes, I also got 24,917,760.
Crud!
That is the key, once there is a leading zero, there can be no more zeros. So
the answer is 1111*9*8*7*45 - 111*8*7*45 or 24917760
1. What is the sum of numbers with distinct digits?
The sum of numbers with distinct digits is the total value obtained by adding all the numbers that have unique digits. For example, the sum of numbers with distinct digits from 1 to 9 would be 45 (1+2+3+4+5+6+7+8+9).
2. Why is it important to calculate the sum of numbers with distinct digits?
Calculating the sum of numbers with distinct digits can be useful in a variety of mathematical problems, such as finding the total number of possible combinations or permutations. It can also help in identifying patterns and relationships between numbers.
3. Can the sum of numbers with distinct digits be negative?
No, the sum of numbers with distinct digits cannot be negative. This is because all numbers with distinct digits are positive integers, and adding positive integers will always result in a positive sum.
4. How do you calculate the sum of numbers with distinct digits?
To calculate the sum of numbers with distinct digits, first list out all the numbers that have unique digits within a given range. Then, add all the numbers together to get the sum. Alternatively, you can use the formula n(n+1)/2, where n is the largest number in the range.
5. What is the significance of the sum of numbers with distinct digits in number theory?
The sum of numbers with distinct digits is often used in number theory to study the properties of numbers. For example, it can be used to identify prime numbers and to understand the distribution of numbers with distinct digits in a given range. It is also used in various mathematical proofs and conjectures.
  • Set Theory, Logic, Probability, Statistics
  • Precalculus Mathematics Homework Help
  • Linear and Abstract Algebra
16K
  • General Math
  • General Math
