Is the Reissner-Nordström repulsion real?
  • Thread starter bcrowell
  • Tags
    Repulsion
In summary: Basically, he discusses the surprising repulsive force that you get when M=0 in Reissner Nordstrom, then argues that this is unrealistic because with the charge present, there will be always an equivalent electromagnetic mass, consequently the field ends up being attractive !
bcrowell
Staff Emeritus
Insights Author
429
The googleable literature on the Reissner-Nordström repulsion is leaving me confused. This seems to be a contentious topic. I've found the following:
1. Grøn, "Non-existence of the Reissner-Nordström repulsion in general relativity," 1983, "The radial motion of a free neutral test particle in the Reissner-Nordström space-time is studied. It is shown that when the contribution of the electrical field energy to the mass of the central body is properly taken account of, there is no repulsion of the test particle inside the inner horizon of the space-time." http://adsabs.harvard.edu/abs/1983PhLA...94..424G
2. Qadir, "Reissner-Nordstrom repulsion," "It is pointed out that there was an error in the recent paper by Grøn claiming that there is no electro-gravitic repulsion in the Reissner-Nordstrom geometry. It is concluded that the earlier result of Mahajan, Qadir and Valanju still stands." http://adsabs.harvard.edu/abs/1983PhLA...99..419Q
3. Grøn, "Poincaré stress and the Reissner-Nordström repulsion," GRG 20 (1988) 123, " The Reissner-Nordström repulsion is shown to be a consequence of Poincaré stresses in a static, charged object. The strong energy condition implies that the Reissner-Nordström repulsions do not stop a neutral test particle, falling freely from rest at infinity in the fields of a charged body, before it hits the surface of the body. However, if the particle falls from rest at a sufficiently small height above the surface of the body, it will not reach the surface due to the Reissner-Nordström repulsion."
4. "Einstein's general theory of relativity: with modern applications in cosmology," Øyvind Grøn, Sigbjørn Hervik, 2007
[homework problem] "Consider a radially infalling neutral particle in the Reissner-Nordström spacetime with M>|Q|. Show that when the particle comes inside the radius r=Q2/m it will feel a repulsion away from r=0 (i.e. that d2r/dtau2<0 for tau the proper time of the particle). Is this inside or outside the outer horizon r+? Show further that the particle can never reach the singularity at r=0."
Unfortunately 1-3 are not freely accessible online. Are 3 and 4 showing that Grøn has changed his mind (possibly being won over by the arguments in 2)? But the specific statements made in 3-4 do not clearly contradict the ones made in 1.
It's not obvious to me that "repulsion" has a unique definition. The acceleration referred to in 4 is a coordinate acceleration, not a proper acceleration, so it's coordinate-dependent. It seems to me that on a general manifold, "repulsion" clearly can't be well defined. E.g., if a body at the north pole of a sphere causes a body at the south pole to accelerate in a certain direction, is that an attraction, or a repulsion? But I suppose it's possible to define "repulsion" in a more unabmiguous way if your spacetime is asymptotically flat...?
Not really answering your question directly, but a related discussion which may be useful - namely the apparently repulsive field of a charged mass point is discussed by Pekeris:
http://www.pnas.org/content/79/20/6404.full.pdf"
Thanks, for the reply, Sheaf. However, when I click on the link I get an error. Do you have a reference so that maybe I could find an abstract by googling?
-Ben
-Ben
Bizarre, I can't get to it now either, but I could this morning. Sorry about that. Maybe there's a server problem. A google search which will bring up that link is "gravitational field point charge pekeris". If you don't have any luck and can't get to it, PM me and I can mail a copy.
Basically he discusses the surprising repulsive force that you get when M=0 in Reissner Nordstrom, then argues that this is unrealistic because with the charge present, there will be always an equivalent electromagnetic mass, consequently the field ends up being attractive !
I see, thanks!
But I guess this doesn't say anything about the nonzero mass case.
bcrowell said:
I see, thanks!
No, I guess it doesn't. It seems to be a restatement of your abstract number 1 above. His abstract states (sorry, the copy from the pdf screws up the mathematical notation, and I'm too lazy to Latex it !)
Adopting, with Schwarzschild, the Einstein gauge
(lg_mu_nul = -1), a solution of Einstein's field equations for a charged
mass point of mass M and charge Q is derived, which differs from
the Reissner-Nordstr0m solution only in that the variable r is replaced
by R = (r^3 + a^3)^1/3, where a is a constant. The Newtonian
gravitational potential psi = (2/c^2)(l - goo) obeys exactly the Poisson
equation (in the R variable), with the mass density equal to
(E^2/4mc^2), E denoting the electric field. Psi also obeys a second
linear equation in which the operator on psi, is the square root of
the Laplacian operator. The electrostatic potential phi (= Q/R),
A, and all the components of the curvature tensor remain finite
at the origin of coordinates. The electromagnetic energy of the
point charge is finite and equal to (Q2/a). The charge Q defines
a pivotal mass M* = (Q/G^1/2). IfM < M*, then the whole mass
is electromagnetic. If M > M*, the electromagnetic part of the
mass M_em equals [M - (M^2 - M*^2)^1/2], whereas the material part
of the mass M_em equals (M^2 - M*^2)^1/2. When M > M*, the constant
a is determined following Schwarzschild, by shrinking the
"Schwarzschild radius" to zero. When M < M*, a is determined
so as to make the gravitational acceleration vanish at the origin.
Good point you make about defining repulsion in a covariant manner.
1. What is Reissner-Nordström repulsion?
Reissner-Nordström repulsion is a concept in theoretical physics that describes the repulsive force between two charged objects with mass, based on the Reissner-Nordström metric. It is a consequence of the electric charge of the objects, which causes the space surrounding them to curve and create a repulsive force that counteracts gravity.
2. How does Reissner-Nordström repulsion relate to general relativity?
Reissner-Nordström repulsion is a phenomenon predicted by Einstein's theory of general relativity. In this theory, gravity is described as the curvature of space-time caused by the presence of mass and energy. The electric charge of an object also contributes to this curvature, resulting in a repulsive force that opposes gravity.
3. Are there any real-life examples of Reissner-Nordström repulsion?
Although Reissner-Nordström repulsion is a theoretical concept, it is believed to play a role in the behavior of black holes. According to the theory, a black hole with a significant electric charge would experience a repulsive force that could counteract the force of gravity and prevent the formation of a singularity.
4. Can Reissner-Nordström repulsion be observed or measured?
Currently, there is no direct evidence of Reissner-Nordström repulsion, as it is a highly theoretical concept. However, scientists are studying the behavior of black holes and other highly charged objects to look for potential effects of this repulsive force.
5. How does Reissner-Nordström repulsion impact our understanding of the universe?
Reissner-Nordström repulsion is a crucial concept in understanding the behavior of highly charged objects in space, such as black holes. It also plays a role in theories of quantum gravity and the search for a unified theory of physics. By studying this repulsive force, scientists can gain a better understanding of the fundamental laws of the universe.
  • Other Physics Topics
  • Cosmology
