How does a clock measure time?
In summary, the conversation discusses the concept of time and how it is measured by a clock. It touches on the different theories and interpretations of time in physics, the role of measurement in comparing processes, and the idea that time is a mental construct rather than a physical property. The conversation concludes that time is a system of measurement and not something that can be measured itself.
mangaroosh
358
Albert Einstein is quoted as having said "Zeit ist das, was man an der Uhr abliest" ["Time is what a clock measures"]. The question is, as per the title of the thread, how exactly does a clock measure time?
When considering this question we need to consider a few things; namely:
- what time is considered to be in the physical sciences
- how the physical processes of a clock measure a secondary physical property called time (if that is what time is asserted to be)
- how a clock demonstrates that there is a temporal dimension i.e. how it demonstrates the relationship between past and present, or present and future.Time in physics
The first point is something I'm not abundantly clear on.
Time is absolute in standard quantum theory and dynamical in general relativity.
Does time exist in Quantum Gravity?
In Einsteinian relativity, time appears to be physical, dynamical, as well as relative; motion affects its passage for different frames of reference. It appears to be different in Quantum Mechanics, where it appears to take on a more absolute form. That appears to be similar to the view under the interpretation of Lorentzian relativity, which is equally supported by relativistic experiments, as Einsteinian relativity. All three view time as a physical property of the universe - or so I believe.Measurement
A clock provides a regularly occurring, repetitive process which is used for the purpose of comparison. The repetitive process provides a standard unit in which other, different processes are expressed, and then compared to yet other processes, expressed using the same standard units.
For example, if we take the standard atomic clock, the recurring process there is the oscillations of the caesium-133 atom; what appears to be actually measured, by the atomic clock, is the number of oscillations of the atom, not some secondary physical property called time. Theses oscillations are then used to compare different processes.
For example; if we say that an object is displaced by a distance of X in 1 second, what we actually mean is that when 9,192,631,770 oscillations are counted, the distance traveled by the object will be X.
We can then compare other objects using this standard unit of comparison; if an object is displaced by a distance of X+2 when the counter of the clock reaches 9,192,631,770, then we say that the second object has moved more quickly than the first.
The question is, at what point in this process is a secondary (or tertiary), physical property called time measured - without, of course, simply assuming that it is?"Distance"
"Distance is what a ruler measures" is a comparison often used to attempt to explain how a clock measures time, but, much like time, "distance" is just a concept. If we talk about measuring the "distance" between ourselves and a remote object what we are actually saying is how many standard units of measurement - a metre stick for example - could we fit between [an arbitrarily defined point on] ourselves and [an arbitrarily defined point on] the object. If the object we are talking about is a coffee table in our living room for example, we might say how many metre sticks can we lay between ourselves and the coffee table; that number would correspond to the amount of floor between us and the coffee table. While we might say the floor exists, the coffee table exists, we exist, and the metre stick exists, "distance" is just a concept.Dimensions
"Length is what a ruler measures" is somewhat different to the notion of a ruler measuring distance, because here we are talking about the physical dimensions of an object, as opposed to the conceptual distance between objects.
Time, however, is somewhat different to the spatial dimensions of an object; the three spatial dimensions are [in general] clearly observable, however, the question is how do we discern that an object, or a process, has a temporal dimension? The time co-ordinate of an object, or a process, will always be "now"; that is, any attempt to measure a temporal dimension can only be carried out in the present moment. While we may be able to recall a previous state of an object or process, this recollection is just a mental construct, a memory; we may also be able to project a future state of the object, but this too is just a mental contsrtuct, or a concept. The same applies to any mathematical representation of the "past" and "future" states.
Given that this same reasoning applies to any clock, how can a clock demonstrate that there is a temporal dimension?
Conclusion
A conclusion that could be drawn is that time is not actually a physical property; it is, however, dynamical and relative but only insofar as it is a mental construct for each individual, and our memories and projections can be distorted. It appears as though "time" is not so much something to be measured, as it is the system of measurement, or comparison.
All that, of course, is based on the reasoning that a clock does not actually measure a physical property called time; but the question remains, how exactly does a clock measure time?
It counts a rate of change, or better said a length of change.
A clock is calibrated. The basic measures or units (seconds, minutes, hours) of time are arbitrary.
Of course, the day is based on the rotation of the earth, and the year is based on the Earth's period of revolution around the sun - and of course, the year is not some nice integer number of days.
The number of degrees in a circle, and arcminutes/arcseconds are arbitrary. Like seconds and minutes, they are based on 60.
Nevertheless, time is based on those things that affect human life.
Again, if we relate this back to an atomic clock for example, what is actually counted is the number of oscillations of the caesium-133 atom; where does the physical, dynamical and relative property called time come into that equation?
The number of degrees in a circle, and arcminutes/arcseconds are arbitrary. Like seconds and minutes, they are based on 60.Nevertheless, time is based on those things that affect human life.
Indeed, time is the system of measurement that breaks those phenomena into units that can be used for comparison and communication; a secondary physical property called time is not measured by those phenomena.
My wife is a genius, she can turn "Just a minute" into three minutes or more.:smile:
"Again, if we relate this back to an atomic clock for example, what is actually counted is the number of oscillations of the caesium-133 atom; where does the physical, dynamical and relative property called time come into that equation?"
Again a changing quantity, or a countable number of the changes. Many things can effect change including rate of decay of the atom, yet so far it is one of the more stable items. . This were the rest of it all comes into play.
If I take the rate of decay as the unit to be measured by and accelerate it from a point and leave an identical one there( at the point) the forces of nature will have will have less effect on one, than the other.
A relay crude way to explain this : A candle flame. Leave your hand in it you get burnt.
Accelerate through it and it has less effect. very crude but might get the idea across.
Apologies, I struggle to see where "time" comes into play in any of the above.
A clock actually measures motion. That motion (if the clock is built correctly) will coincide with mans concept of time.
I say mans concept of time because I have never seen an animal watching the clock.
I would say that time is merely a concept, with no physical existence; this doesn't appear to be how time is treated in physical theories, however. Einsteinian relativity appears to treat it as being physical and dynamical. I'm wondering how a clock measures time in this context, without simply assuming that it does; or how a temporal dimension can be deduced from the processes of a clock.
In relation to time being conceptual, I would say that the concept of a temporal dimension arises due to humankinds capacity for memory and projection, meaning that "past" and "future" are just mental constructs. It corresponds directly to motion, because man's concept of time is entirely based on motion and change; memory of a previous [no longer existing] state is labelled as "the past"; the current state (which is the only state that can ever really be said to exist) is the present; the projection of a state that has yet to materialise is labelled as "the future".
This obviously isn't anything original, but just worth stating for the purpose of discussion; as I have yet to hear it satisfactorily addressed.
But just to try and stick to the strict topic of the thread; if we consider the processes of a clock, where is the physical entity called "time" actually measured? The counter of an atomic clock counts the number of events (or oscillations) in the clock i.e. it measure the number of events; where does the measurement of the temporal (and physical) element of spacetime occur?
We measure it relative to some other process: this process could be mechanical in the form of a clock like using gravity and a pendulum to utilize a measure of periodicity that eventually translates into 'one second' or one 'time unit', or alternatively use a process like that found in the cesium atom way of measuring one second.
From these things we use some kind of change to effectively measure time. The changes can be something as simple as the periodicity of a pendulum in a huge grandfather clock to something a little more complicated like the entropy increase law in thermodynamics as we currently understand it.
Also its important to remember that all of the things that are usually utilized to measure time have a huge dynamic component. In other words if you have some kind of process that does not change, then its really hard to use that process to measure time so naturally we want to get some kind of process that is dynamic with properties that are well understood enough to extract the appropriate information about what kind of unit of time we are looking for.
One final thing: in order to get any universal measurement it is a good idea to use any universal constant(s) that we can use. If we choose things that are not constants we run into trouble getting different answers for the same thing.
Since in our current understanding the speed of light has so far looked to be a constant, this gives us a good candidate for measuring something in a more standardized way since so far it has passed the 'universality' test.
As long as we have some kind of standardization (the pendulum utilizes gravity which is for the most part well understood in the context that it is in in terms of its mechanics), then we can be sure that to whatever appropriate level of accuracy, that there will be the right standardization so that it can be used in many reference frames and therefore have everyone agree on it.
mangaroosh said:
Again, if we relate this back to an atomic clock for example, what is actually counted is the number of oscillations of the caesium-133 atom...
No, it isn't.
But why is this in General Discussion?
Gokul43201 said:
No, it isn't.
Sometimes it is.
The Navy said:
A cesium clock operates by exposing cesium atoms to microwaves until they vibrate at one of their resonant frequencies and then counting the corresponding cycles as a measure of time.
http://tycho.usno.navy.mil/cesium.html
And if she is to spend "just a minute" in a shop?? :biggrin:
Time? Like light, do we even know if it's discrete or continuous?
As I've said many times, there is nothing fundamentally wrong with our concept of time for this question to be useful. You wouldn't ask where (or when!) on a ruler the measurement of length occurs, would you? It's meaningless and you've got to stop seeing a problem with time in such questions: the problem isn't with time, it is with your meaningless questions.
No memory = no time. The present is the only reality. How long is the present? For humans it's as long as the psychological smear of past/present we can hold in consciousness, and the vast bulk of that is, in fact, memory. In fact, the present is more like a dimensionless euclidian point: a 'location' with no actual dimensions. (A hypothetical being with consciousness but no memory would perceive the world as a static phenomenon.) We don't know, and I don't think there is a way to know, the authentic rate that point "travels", because we would need some other kind of time to compare it to, and there isn't any.
The best established linguistic theories assert that words only have demonstrable meaning in specific contexts and the newest theories in quantum mechanics suggest this principle of contextualism applies to physical observations as well. Whether the cat is perceived to be dead, alive, or in superposition could be merely a question of the specific context in which we take the measurement. Relativity makes a similar assertion that whether we perceive something as time or space merely depends on the context of our relative motion. Thus the simplest and most demonstrable explanation to date is that time can be considered a physical property in some contexts and not one in others.
Is the cat really dead, alive, or in superposition? Is time really a physical property or not? Who cares! We observe what we observe and the rest I leave to the metaphysicians and mystics to debate. A photon doesn't appear to experience time so its perfectly sensible to tell someone time is not a physical property of photons. Clocks measure time so its makes perfect sense to tell someone time is a physical property of clocks. What matters first and foremost is what we observe, and communicating effectively about what we observe.
Clocks don't "measure" the passage of time directly, they estimate it through the measurement of an oscillating circuit (whether it's electrtical, mechanical, or atomic). This is an important distinction in my humble opinion.
Yes, clocks count periodic events. But I don't see how that makes the word "estimate" applicable.
Jimmy Snyder said:
Sometimes it is.
That's not accurate. In fact, the paragraph following the one you quoted provides a better explanation. The frequency that is being matched corresponds to the energy absorbed/emitted during one specific (hyperfine) electronic transition. It has nothing to do with the vibration of the Cs atoms.
Here's a better source: http://hyperphysics.phy-astr.gsu.edu/hbase/acloc.html#c2
That's not accurate. In fact, the paragraph preceding the one you quoted provides a better explanation.
"Measure" indicates in my opinion a direct link between the subject of the measure and the instrument performing it. Measurment of a distance for example can be done between two points using an instrument. "Measurement" of time gets a bit more abstract though, because the methods of measurement being used are one or two degrees removed from the raw subject.
Maybe I'm thinking a little far into the philosophical defenses, but it all goes back to the circular definition of "measuring" time using a periodic event which has (using either a frequency or distance or velocity) time as a fundamental unit in it's own definition:
Wikipedia.org said:
Time is one of the seven fundamental physical quantities in the International System of Units. Time is used to define other quantities — such as velocity — so defining time in terms of such quantities would result in circularity of definition.
An operational definition of time, wherein one says that observing a certain number of repetitions of one or another standard cyclical event ... leaves aside the question whether there is something called time, apart from the counting activity just mentioned, that flows and that can be measured.
I'm not seeing how counting events is removed from time by any degrees.
Is it the inherrent granularity that you take issue with? Does a surveyors wheel measure or estimate distance?
The wiki's complaint about the measurement of time being dependent on motion/distance has it backwards: it is distance that is measured/defined using time, not the other way around. But it really doesn't matter either way: to be overly fair to length, it was a practical decision based on measurement technology and accuracy. If I were to be less fair, I'd say that length is inherrently inferior to time due to the lower accuracy of measurement.
I suppose the measurment of time isn't really any fundamentally different than measurement of length. Different instruments have different precision, and none give the "real" value, only one subject to their accuracy.
I just seem to find time measurement's traceability to a fundamental standard to be a bit fuzzier than physical measurement...
Me too. In a lab, one measures length by comparing it to another (calibrated) length; it's a direct comparison. But to measure time, there's more involved (time = distance/rate).
Some species of animals are known to use simple tools -- I can almost see such a species understand how to measure a stick length using the length comparison described above. No way can they understand a time measurement, though.
Why can't you measure time by a direct comparison as well? What your doctor does with his hand on your pulse and his eye on a wristwatch is essentially how we all measure time - by a direct comparison to some other calibrated time interval.
I think most any predator that actively hunts prey (not the kind that ambush) has a pretty good intuitive sense of time.
And of course time isn't constant- its measurement depends on your speed, further complicating things!
In Test of Relativity Theory, Superaccurate Atomic Clocks Prove Your Head Ages Nanoseconds Faster than Your Feet
PopSci.com said:
In a study published today in the journal Science, researchers at the National Institute of Standards and Technology explain that a one-foot difference in altitude between two clocks caused them to tick at slightly different rates. The optical clocks can even measure changes in the passage of time caused by a 20-mile-per-hour speed difference.
The emboldened sentence above is the assumption that is being challenged. I cannot see how a physical property called "time" is measured; even less obvious is how the temporal and physical aspect of spacetime is measured using a clock. You see, I can't see how we measure "time" relative to some other processes; we measure processes relative to other processes - "time" does not seem to enter the equation, unless we assume that it does.
The use of a periodic cycle simply gives us a common unit of comparison, in which we can express information about a process. We can then compare other processes by expressing them in terms of this common unit. The periodic cycle exists, and the processes that are expressed in terms of the cycle exist, but physical "time" cannot be deduced from that.
Gokul43201 said:
No, it isn't.
I started a different thread, related to a similar topic, in the philosophy thread, but it was moved to the GD section; so I just presumed to start this one here.
What does the counter in an atomic clock count; and how does an atomic clock measure time?
  • #31
"Length", much like "time", is just a concept; what happens when we use a ruler to measure the physical dimensions of an object is, in a simplistic example, we take a standard unit and hold it beside a physical object, and see how many of those standard units can be held beside the object. This allows us to express the physical dimensions of the object in a standard unit, which allows us to compare the physical dimensions of other objects expressed in the same units. That objects have spatial dimensions is self-evident.
The measurement of the temporal dimension is not quite as straight forward - impossible if it doesn't exist - because the attempted temporal measurement of an object can only ever be carried out in the present; that is, the actual time co-ordinate will always be "now". We may of course remember a past state, and project a future state, but those are just mental constructs. The object only ever exists in the present.
  • #32
I would agree to a large extent with that.
  • #33
The question is about what do we actually observe. Physical theories, make ontological claims about the nature of things like time and space; to have more accurate physical theories we need to see if those claims are justifiable. Indeed, our subconscious belief in time, just as our other subconscious beliefs, can affect our experience of reality, or more pointedly, how we live our lives.
Again, it is the emboldened in the last paragraph that is being questioned.
  • #34
Whether it is estimated or not, how does the counting of periodic events allow us to deduce that there is a temporal dimension; bearing in mind that the memory of a past event is just a mental construct, and only events in the present can be said to be real, without assuming that past or future events are real?
  • #35
In the example above, one process is compared to another process - where does physical "time" enter the equation?
  • Other Physics Topics
