Vector of magnitude m making angles alpha, beta and gamma with i,j,k
In summary: Check that cos(alpha)= a/magnitude(d), which is determined by a ,b ,c together.Correct. The magnitude and angle of a vector are both determined by the three components of the vector. if you try to change a in order to change alpha, the magnitude will change with a,so cos(beta) and cos(gamma) will change with a , since they also depends throughthe magnitude(d). that is to say, beta and gamma is varying with alpha and hold a fix relation among the 3 angles, when you keep b, c constant and change a.Yes, that is correct. Changing one component will affect the other components and the angles will change accordingly. As a result
manjuvenamma
102
Many of us have seen how to find a vector satisfying the following conditions (i) magnitude is m (ii) makes angles alpha, beta and gamma with i,j,k vectors i.e. unit vectors along x,y and z axes.
My question is can the angles be taken arbitrarily or they should satisfy some condition like angles in a triangel add up to pi radians.
I have a dilemma. The method we see in books indicates like we can arbitrarily choose the angles.
But let us consider the following:
The vectors making gamma angle with z axix should necessarily be on a cone. Now the condition that it should make alpha with x-axis restrains this vector space to vectors on the cone to a few that make alpha angle angel with x-aix. Out of these vectors are we always sure that there will be a vector which also makes beta angle with the y-axix, whatever be the alpha, beta and gamma?
Science news on Phys.org
No we can not arbitrarily choose the angles. If you are given 2 angles, there are at most 2
possibilities left for the third. (intersection of two cones). the third angle is only given to tell which of these 2 it ts.
there is the equation about the 3 angle :cos(a)^2+cos(b)^2+cos(g)^2=1
if the alpha and beta are too small , their cosine will be too big to get the gamma
Likes TiffanyErika
But here is the dilemma. The following method looks logical and looks like yielding a vector whatever be the m, alpha, beta and gamma. Assume the desired vector to be d=ai+bj+ck. In that case, d.i = a = magnitude(d)..cosine(alpha). Since we know, magnitude of d (which is m) and alpha we can calculate a. Similarly we can calculate b and c and arrive at the desrired vector d whatever be m, alpha, beta and gamma. Where is the catch?
As a result, in effect you can't choose the angles arbitrarily
No. Since the magnitude is arbitrary only the direction needs to be determined. A direction requires two parameters. Let us use a vector of unit length as an example (since all other vectors with the same direction are merely a multiply of this unit vector). Once you specify the second angle there are only two choices for the third.
There are only two choices for the third angle as far as I can recall.
I doubt that is true. Can you show me a picture of what you're referring too?
If the angle [itex]\gamma[/itex] is 90 degrees then it will lie in the xy-plane and not on a cone. In this case the second angle will then determine which direction the unit vector points in and that can be specified by one angle. As such the third angle will be uniquely determined. There are not two choices in this instance, only one.
Picture this in your mind; Choosing the first angle will determine a cone about the z-axis (unless the angle is 90 degrees). Choosing the angle the vector makes with the x-axis will determine a cone around the x-axis. Since the direction must satisfy the same angles then you're looking for the intersection of two cones. There are two directions specified by the interesection of these two cones.
Out of these vectors are we always sure that there will be a vector which also makes beta angle with the y-axis, whatever be the alpha, beta and gamma?
Once the first two angles are determine the second angle is restricted. If the first angle is not 90 degrees then there are two choices for the third. If the first angle is 90 degrees then once the second angle is chosen the third angle is uniquely determined.
Best wishes
Pete
That expression can be solved for one of the angles when the other two are given. Since there will be two signs (one for the positive square root and one for the negative square root) unless it is zero. Therefore the last angle has at most two solutions. If one angle is 90 degrees then the second angle uniquely determines the direction and there is no other choice for the last, third, angle.
Pete
My question is where is the catch? I choose arbitrarily m, alpha, beta and gamma. I find a,b,c as mentioned above and as such arrive at a vector d which satisfies all the conditions of m, alpha, beta and gamma. Whatever be this four values. For example, I choose m =1000, alpha = pi/3, beta = pi/10, gamma = 3pi/5, I arrive at d. Even if some of the 3 angles are pi/2, pi or whatever.
manjuvenamma:
this is a question about "necessary condition" and "sufficient condition."
if you have d=ai+bj+ck, you can get di=a by mutiplying i, similiarly dj=b and dk=c;
but if you only have di=a, dj=b,and dk=c, you CANNOT obtain d=ai+bj+ck.
i thick here is the catch , a logic problem.
Pete:
sorry i wasnot able to say it clear. what i wanted to say is that
in effect you cannot choose the 2 angles of the 3. arbitrarily
for example
if two of the 3 angbles are both too small, the two cosine values' sum will be larger than 1, thus, you cannot get the last one,either.
zhanghe said:
Pete:
for example
Wow! I must still be pretty ill not to have seen that. :rofl: You're absolutely right of course. A good example is when the angle the unit vector makes with z is 90 degress. The two other degrees must then add up to 90 degrees. Thanks for pointing that out. I guess I'm getting old! :smile:
Pete
zhanghe, Now I am clear, thanks. But this is the first time I can remember where we started with a wrong assumption (existence of a vector satistying the 4 conditions) and ended with a wrong answer (a neat answer for the vector even though the vector satisfying all the conditions may not exist). Generally, in math, when we start with a wrong assumption, we end with an absurd answer so we realize we started with a wrong assumption. (Reductio ad absurdum). Are there any examples of this kind i.e start with a wrong assumpiton and also end up with an incorrect or misleading answer.
Pete and manjuvenamma ,you are welcome, :)
Simply resolve vector 'm' on anyone axis n plane formed by other two...
lets say z-axis n xy-plane
This means,
on z-axis, we get " m.cosZ"
on xy-plane,we get "m.sinZ"
now further resolving oon xy-plane gives
m.sinZ.cosθ and m.sinZ.sinθ
and we have the following condition,
m.sinZ.cosθ = m.cosX
m.sinZ.sinθ = m.cosY
THIS GIVES
sinZ.cosθ = cosX
sinZ.sinθ = cosY
the relation u were searching for,...
Please reply if anyone find it useful...
1. What is a vector of magnitude m making angles alpha, beta, and gamma with i,j,k?
A vector of magnitude m making angles alpha, beta, and gamma with i,j,k is a mathematical representation of a physical quantity that has both magnitude (size) and direction. The angles alpha, beta, and gamma represent the direction of the vector in relation to the x, y, and z axes (i,j,k) respectively.
2. How do you calculate the magnitude of a vector with given angles?
The magnitude of a vector with given angles can be calculated using the Pythagorean theorem, where the magnitude (m) is equal to the square root of the sum of the squares of the three components (i,j,k) multiplied by the cosine of each angle (alpha, beta, and gamma) respectively.
3. What is the importance of the direction of a vector?
The direction of a vector is important because it determines the physical meaning of the vector. For example, a vector representing velocity must have both magnitude and direction in order to accurately describe the speed and direction of an object.
4. Can a vector have negative magnitude?
No, a vector cannot have negative magnitude. The magnitude of a vector is always a positive value, while the direction of the vector can be positive or negative depending on the orientation of the vector in relation to the coordinate axes.
5. How do you represent a vector with given magnitude and direction?
A vector with given magnitude and direction can be represented using vector notation, where the magnitude is written as a number with a unit and the direction is indicated by an arrow pointing in the direction of the vector. Alternatively, the vector can be represented using its components in the form of (x,y,z) or (i,j,k) where each component represents the magnitude of the vector in the x, y, and z direction respectively.
