trying to find a water level sensor/switch
by perplexabot
Tags: sensor or switch, water
perplexabot
perplexabot is offline
#1
Jan17-14, 11:53 PM
P: 192
Hello all. I am trying to find a sensor (probably switch is a better word) that will output a HIGH or LOW depending if the water (say, in a tank) has reached a certain level. I first googled: pressure sensor, then pressure switch. I also stumbled upon water level sensors, and now I am kind of confused.
I searched for some on amazon, this is what I found:
http://www.amazon.com/Amico-Aquarium...r+level+switch
http://www.amazon.com/Amico-Liquid-S...ref=pd_cp_hi_2
These contraptions don't make sense to me, I can only see two wires, GND and VIN, where is the output wire?
Any help will be appreciated. Thanks.
Phys.Org News Partner Engineering news on Phys.org
Lifting the brakes on fuel efficiency
PsiKick's batteryless sensors poised for coming 'Internet of things'
Researcher launches successful tech start-up to help the blind
Baluncore
Baluncore is offline
#2
Jan18-14, 04:33 AM
P: 1,278
The switches have a single contact. You can connect the switch with a twisted pair of wires. One of those wires will be connected to ground, the other is the signal. If the signal is going to a micro-controller input then you will need a pull-up resistor or a programmed bias current on that input to make the voltage high when the sensor switch is open.
dlgoff
dlgoff is offline
#3
Jan18-14, 10:37 AM
Sci Advisor
PF Gold
dlgoff's Avatar
P: 2,631
Other level measurement goodies: http://www.omega.com/section/level-measurement.html
Baluncore
#4
Jan18-14, 03:55 PM
P: 1,278
The level sensors linked in the OP appear to have an external moving magnet and a fixed sealed magnetic reed switch. There are other methods of determining fluid level that do not have external moving parts in contact with the fluid.
To select an appropriate sensor requires knowledge of several of things.
1. What will the level sensor's electrical output be connected to ?
2. What fluid is the sensor being used to measure ?
3. What unusual environmental problems like waves, ice or cattle may be present ?
perplexabot
#5
Jan21-14, 12:31 PM
P: 192
Thank you for the great replies and sorry for my late one. So if my understanding is correct, the level switches in the OP only require a ground? The other wire is the signal? Also, the description of these switches say that the max switch voltage is 100V, I want to know how much voltage I need to supply it with (but then again, If my initial logic is correct, I only need to supply it with ground... Now i am really lost).
Quote Quote by Baluncore View Post
I think first I need to find an appropriate switch then I need to figure out how it works. So first, as Baluncore has mentioned, a couple of things worth mentioning:
1. A micro controller (specifically a arduino nano)
2. Water (H2O)
3. None (a controlled environment... a water tank)
*. Outputs HIGH/LOW (not pressure value)
*. Low power (kind of obvious)
Baluncore
#6
Jan21-14, 02:55 PM
P: 1,278
Attach a twisted pair of wires to the two terminals on your float switch. At the Arduino, connect one wire to the digital ground. Connect the other wire to your Arduino logic input. Place a 10k resistor between the signal pin and +Vcc.
When the float switch contacts are open the input will be high, +5V. No power will be consumed.
When the float switch contacts are closed the input will be low, 0V. Half a milliwatt will be dissipated in the resistor.
perplexabot
#7
Jan28-14, 12:35 AM
P: 192
Ok that makes a lot of sense. Thank you.
Register to reply
Related Discussions
Circuit: Water Sensor: Works when one probe is in water while the other is not Electrical Engineering 9
Water Level Sensor Circuit Electrical Engineering 9
Looking for a gas flow switch/sensor any leads? Mechanical Engineering 2
water level sensor Engineering, Comp Sci, & Technology Homework 1
Water level sensor system Electrical Engineering 9
