Finding Perimeter/Circumference of part of a circle
  • Thread starter sdoyle1
  • Tags
    Circle
It would really help with the visualization.In summary, the problem involves finding the perimeter and area of a shaded region between two concentric circles. The inner radius is 2.9 m and the outer radius is 6.5 m, both measured from point A. The angle at point A is 110 degrees. To find the perimeter, the circumference of the full circle is multiplied by the ratio of the given angle to 360 degrees. For the area, the difference between the areas of the larger and smaller circles is calculated.
sdoyle1
23
The inner radius is measured from a point A and is 2.9 m. The outer radius is measured from the same point A and is 6.5 m. The angle at A is 110*. What is the Perimeter of the shaded area in meters? What is the area of the shaded are in square meters?
C=2rpi
Just for part A I tried to find the total circumference as if the circle was a full 360* and then multiplied the resulting answer by the ratio of 110*/360*. The answer was incorrect. The answers are suppose to be 25.3 m and 32.5 m^2
C=2rpi
From your description, it seems that you need to find the perimeter and area of a section of a ring or annulus.
The circumference of a circle is C = r * 2pi. The arc length along the portion of a circle subtended by an arc whose measure is theta (in radians) is r * theta.
The area of an annulus is pi(R^2 - r^2), where R and r represent the outer and inner radii respectively.
We know the area of a circle as:
[PLAIN]https://dl.dropbox.com/u/4645835/MATH/Area%20of%20Circle.gif
Part B:
We want to find the area of the shaded portion. So, we find the area of the outside circle and subtract from it the area of the inside circle.
[PLAIN]https://dl.dropbox.com/u/4645835/MATH/Worked.gif
Well, I don't know what the drawing looks like, so I don't know exactly what the problem is. How does the angle of 110 degrees enter into the problem?
I imagine it as a larger circle around a smaller circle. The shaded region they are referring to would be the area enclosed by the two circles. The given angle...according to my interpretation...is between the 0 degree line and the radii extending from point A.
The problem doesn't include a picture?
1. How do you find the perimeter of a part of a circle?
To find the perimeter of a part of a circle, you need to add together the length of the curved section and the length of the straight lines that make up the part of the circle.
2. What is the formula for finding the circumference of a part of a circle?
The formula for finding the circumference of a part of a circle is C = 2πr, where C is the circumference, π is pi (approximately 3.14), and r is the radius of the circle.
3. How do you calculate the length of the curved section of a part of a circle?
The length of the curved section of a part of a circle can be calculated by multiplying the circumference of the whole circle by the fraction of the circle that the part represents. For example, if the part represents 1/4 of the circle, you would multiply the circumference by 1/4.
4. Can you find the perimeter of a part of a circle if you only know the radius?
Yes, you can find the perimeter of a part of a circle if you only know the radius. You would use the formula P = 2πr, where P is the perimeter and r is the radius.
5. What is the difference between perimeter and circumference?
Perimeter refers to the total distance around the outside of a shape, while circumference specifically refers to the distance around a circle. Perimeter can be used to find the distance around any shape, while circumference is only used for circles.
22K
