Surface Area of a Sphere in Spherical Coordinates; Concentric Rings
In summary, the conversation is about deriving the surface area of a sphere using only spherical coordinates. The method involves integrating concentric rings and using the equation for the circumference of a circle. However, to stay in spherical coordinates, the differential element of area needs to be written in spherical coordinates. This involves taking into account the radius varying with the sine of the zenith. The conversation also mentions a related fact about the area of the sphere being equal to the corresponding area on a cylinder wrapped around it. This was proven by Archimedes in 225 BC.
AmagicalFishy
50
Hey, folks.
I'm trying to derive the surface area of a sphere using only spherical coordinates—that is, starting from spherical coordinates and ending in spherical coordinates; I don't want to convert Cartesian coordinates to spherical ones or any such thing, I want to work geometrically straight from spherical coordinates. I am trying to do this by integrating concentric rings. Here's a picture of what I'm talking about:
[tex]\phi - \text{ is the Azimuth (note; there is one instance at the center and one near the top for illustration)}\\
\theta - \text{ is the Zenith}\\
r - \text{ is the radius of the circle currently being integrated} \\
R - \text{ is the radius of the sphere}[/tex]
I began simply by deriving the equation for the circumference of any circle:
[tex]\int_0^{2\pi}\!r\ \mathrm{d}\phi[/tex]
(The arc-length is the circle's radius multiplied by the angle; d[itex]\phi[/itex] is the infinitesimal angle, so the integrand is the infinitesimal arc-length.)
In a sphere, the radius r of the integrated-circles varies according to the Zenith. The radius is:
[tex]r = R sin{\theta}[/tex]
Then, the circumference of any given circle within the sphere, at a height designated by θ, is:
[tex]\int_0^{2\pi}R sin{\theta} \ \mathrm{d}\phi[/tex]
That is, the radius of a circle multiplied by the infinitesimal angle, from zero to two-pi, as shown above, will give you the circumference of that circle.
Now, we want the integral to sum all of the circles' circumferences of the sphere, so θ has to move from top-to-bottom. The limits of integration on θ are therefore from zero to pi, and the whole integral is:
[tex]\int_0^\pi \int_0^{2\pi}\! \!R sin{\theta} \ \ \mathrm{d}\phi \ \mathrm{d}\theta[/tex]
This evaluates to: 4[itex]\pi[/itex]R
... which is close, but wrong. If I threw in another R, life would be good, but I can't well do that without knowing why. I've thought of why I should need another R, but I can't figure anything out.
Where am I missing an R factor, and why should I be factoring it in? Everything above makes pretty intuitive sense to me, and I can't point out where or why I would add in another R. Though it's often the case that I'm making a dumb mistake.
Thanks. :)
To stay in spherical coordinates, you need to write the differential element of area in spherical coordinates. In the [itex]\hat\phi[/itex] direction, the differential arc is [itex]rd\phi[/itex]. In the [itex]\hat\theta[/itex] direction, the differential arc is [itex]r\sin\theta d\theta[/itex], as you can convince yourself by drawing a diagram or looking in a calculus book. Thus the differential area is [itex]r^2\sin\theta d\theta d\phi[/itex] , and the total surface area is [tex]r^2\int_0^{2\pi}d\phi\int_0^\pi \sin\theta d\theta.[/tex]
Wait.
Oh, wait, I get it!
Haha! Excellent. At one point, I was on the verge of that—then I realized that the radius of the circle being integrated varied with the sin of the zenith, and (I don't know why) decided on concentric rings.
Thank you. :)
Here is a cool fact that is related to your question.
Wrap a cylinder around that sphere. i.e. x^2+y^2 = R^2 with z between -R and R. Any region on the sphere has the same area as the corresponding area on the cylinder. The correspondence is via a radial projection out from the z axis. So, for example, the area between latitudes would be 2pi*R^2(cos(phi1)-cos(phi2)).
That is pretty cool!
That was actually proven by Archimedes and published in 225 BC. He was a smart guy...
1. What is the formula for finding the surface area of a sphere in spherical coordinates?
The formula for finding the surface area of a sphere in spherical coordinates is 4πr², where r is the radius of the sphere.
2. How do you convert from Cartesian coordinates to spherical coordinates?
To convert from Cartesian coordinates (x, y, z) to spherical coordinates (ρ, θ, φ), you can use the following formulas: ρ = √(x² + y² + z²), θ = arctan(y/x), and φ = arccos(z/ρ).
3. Can the surface area of a sphere be calculated in terms of concentric rings?
Yes, the surface area of a sphere can be calculated by summing the surface area of each concentric ring. This is often used as an alternative method for finding the surface area of a sphere in spherical coordinates.
4. How does the surface area of a sphere change as the radius increases?
As the radius of a sphere increases, the surface area also increases. This is because the surface area is directly proportional to the square of the radius.
5. Is it possible to find the surface area of a partially filled sphere in spherical coordinates?
Yes, it is possible to find the surface area of a partially filled sphere in spherical coordinates by subtracting the surface area of the empty portion from the surface area of the full sphere. This can be calculated using the same formula of 4πr².
  • Calculus
  • Calculus
