Most of the op-amps use differential amplifier
In summary, the input stage of most op-amps use a differential amplifier, but the two transistors must be biased correctly and it is not always possible to achieve exact matching. This results in a small DC current at the input terminals. The op-amp characteristics, including input offset voltage, do depend on temperature. The mismatching of the input differential pair can cause an input offset current, which can lead to an output offset voltage error depending on the application.
vvkannan
23
1.My text says 'most of the op-amps use differential amplifier as the input stage.The two transistors must be biased correctly.But it is not possible to get exact matching of two transistors.Thus the input terminals which are the base terminals of the transistors do conduct small dc current'.
I can't understand this.If the characteristics of the two transistors are not similar would it result in the op-amp drawing small dc current?.
2.There's one line which says the op-amp characteristics do not depend on temperature and there's another statement which states the input-offset voltage depends on temperature.which is true?
For BJT inputs, there will certainly be an input bias current, independent of the quality of the matching of the differential pair. Even for FET inputs, there is a very tiny input bias current. The mismatching of the input differential pair gives rise to the Input Offset current/voltage specifications, not the Input Bias Current specification.
And all of those depend on temperature. Your text must have been referring to something else when it mentioned temperature independence.
thank you for replying.so the op-amp will draw some bias current(due to indvidual transistors ) and the offset current will add to this current when the transistors are mismatched.am i right?
Sort of right. The bias currents are just that -- they are what help to bias up the input differential pair in their linear region. The "offset" current is the extent to which these input bias currents are different. This is important in some applications, because the input offset current will generate an input offset voltage via the input bias resistors that you put outside the opamp, and this offset voltage will get multiplied by the gain of the opamp and cause an output offset voltage error. In some applications, this doesn't matter; in others, it can be a problem.
1. What is a differential amplifier?
A differential amplifier is an electronic circuit that amplifies the difference between two input signals while rejecting any common-mode signals. It is commonly used in op-amps to provide high gain and high input impedance.
2. Why do most op-amps use differential amplifiers?
Most op-amps use differential amplifiers because they provide high gain and high input impedance, making them ideal for amplifying small signals with minimal distortion. They also have a high common-mode rejection ratio, allowing them to reject noise and interference from the input signal.
3. How does a differential amplifier work?
A differential amplifier works by taking in two input signals and amplifying the voltage difference between them. It consists of two transistors with their emitters connected together and their collectors connected to the power supply. The voltage difference between the two inputs is amplified and output through a load resistor.
4. What are the advantages of using a differential amplifier in an op-amp?
The advantages of using a differential amplifier in an op-amp include high gain, high input impedance, and high common-mode rejection ratio. This allows for accurate amplification of small signals, minimal distortion, and rejection of noise and interference from the input signal.
5. Are there any disadvantages to using a differential amplifier in an op-amp?
One potential disadvantage of using a differential amplifier in an op-amp is the need for careful circuit design and matching of components to ensure proper operation. Additionally, the use of a differential amplifier may increase the complexity and cost of the op-amp circuit.
  • Electrical Engineering
