How do you go from (3w-1)/(w+2) and get: 3-(7/(w+2))?
  • Thread starter adelaide87
In summary, to go from (3w-1)/(w+2) to 3-(7/(w+2)), you can add 0 to the numerator and split the rational expression into two parts, or you can divide (3w-1) by (w+2) and rewrite it as the sum of two simpler expressions. For the expression 2x/((x+3)(x+1)), it can be simplified to 3/(x+3) - 1/(x+1) using rational function decomposition. Similarly, for 1/[(u^2)(u-1)(u+1)], the decomposition would be (1/2)/(u-1) - 1/(u^
adelaide87
24
How do you go from
(3w-1)/(w+2)
and get:
3-(7/(w+2))?
adelaide87 said:
How do you go from
(3w-1)/(w+2)
and get:
3-(7/(w+2))?
Add 0 to the numerator like this: 3w - 1 = 3w + 6 - 6 - 1 = 3(w + 2) - 7
Now split the rational expression into two parts.
Another way to do the same thing: divide 3w- 1 by w+ 2. w, alone, divides into 3w 3 times, of course. (3w- 1)/(w+ 2)= 3+ ?. Multiplying both sides by w+ 2, 3w- 1= 3w+ 6- ?(w+2). ?(w+ 2)= (3w+ 6)- (3w- 1)= 7 so that ?= 7/(w+ 2).
(3w- 1)/(w+ 2)= 3+ 7/(w+ 2).
What about this one?
2x/((x+3)(x+1))
Simplified to
3/(x+3) - 1/(x+1)
This is probably one of the harder parts of algebra for me for some reason. I don't understand the steps.
This is an example of rational function decomposition. In this case you need to rewrite the original expression as the sum of two simpler rational expressions.
[tex]\frac{2x}{(x + 3)(x + 1)} = \frac{A}{x + 3} + \frac{B}{x + 1}[/tex]
The equation above needs to be identically true -- true for all reasonable values of x (the ones for which the denominators aren't zero).
Multiply both sides of the equation above by (x + 3)(x + 1) and solve for A and B.
This one is a bit trickier
1/[(u^2)(u-1)(u+1)]
to get
(1/2)/(u-1) - 1/(u^2) - (1/2)/(u+1)
I tried doing it they way you just showed me but I get stuck.
Here you have a repeated factor, so the decomposition has to look like this:
[tex]\frac{1}{u^2(u - 1)(u + 1)} = \frac{A}{u} + \frac{B}{u^2} + \frac{C}{u - 1} + \frac{D}{u + 1} [/tex]
As before, multiply both sides by u2(u - 1)(u + 1) and solve for A, B, C, and D.
There should be some examples of decomposition in your book...
1. How do you simplify the expression (3w-1)/(w+2)?
To simplify this expression, you can use the process of long division. Divide 3w by w to get 3, then multiply 3 by w+2 to get 3w+6. Subtract 3w+6 from 3w-1 to get -7. Bring down the -1 and divide -7 by w+2 to get -7/(w+2). Therefore, the simplified expression is 3-(7/(w+2)).
2. What is the process for converting (3w-1)/(w+2) to 3-(7/(w+2))?
The process for converting this expression involves using the concept of equivalent fractions. To get rid of the fraction in the numerator, you need to multiply both the numerator and denominator by the same number. In this case, we multiply by (w+2)/(w+2). This gives us (3w^2+6w-3)/(w^2+4w+4). Then, using long division, we get 3-(7/(w+2)).
3. Can you explain why the expression (3w-1)/(w+2) is equivalent to 3-(7/(w+2))?
These two expressions are equivalent because they represent the same value. The process of converting from (3w-1)/(w+2) to 3-(7/(w+2)) involves simplifying the expression using long division and equivalent fractions, but the end result is the same. This is because you are essentially breaking down the original expression into smaller, equivalent fractions until you reach the simplified form.
4. How do you know when an expression is fully simplified?
An expression is fully simplified when it can no longer be simplified using any of the common mathematical operations (e.g. addition, subtraction, multiplication, division). In the case of (3w-1)/(w+2), the expression can be simplified to 3-(7/(w+2)), but it cannot be simplified any further using the operations mentioned above. Therefore, 3-(7/(w+2)) is the fully simplified form of the expression.
5. Are there any other methods for simplifying fractions besides long division?
Yes, there are other methods for simplifying fractions, such as using the greatest common factor (GCF) or using the least common multiple (LCM). However, for expressions like (3w-1)/(w+2), long division is the most efficient and straightforward method. The other methods may be more useful for more complex expressions involving variables and exponents.
