Exploring Spherical Conductor Current & Power Density
In summary, the problem involves a spherical conductor surrounded by a conducting shell with an insulating material in between. The current drawn from the voltage source is found to be 4πVab/ρ(b-a) and the power drawn from the voltage source is equivalent to the power dissipated as heat by the insulator, which is 4πσV2(b-a). This is determined by finding the power density and integrating it over the insulator volume, using the expression E=ρJ=ρ(i/A) and treating i as a constant.
WJSwanson
81
A spherical conductor of radius a is surrounded by a spherical conducting shell of radius b, and the gap is filled with an insulating material of resistivity ρ. A thin wire connects the inner surface of the shell to the surface of the conductive sphere, and a potential of V is applied to the outer surface of the conducting shell.
I. Determine the current drawn from the voltage source.
II. Integrate the power density (σE2) over the insulator volume v and compare to the power drawn from the voltage source.
dR = ρ dr / 4πr2
i = V / R
E = ρ J = -[itex]\partial[/itex]V/[itex]\partial[/itex]r
Pdissipative = I2R
P/v = σE2
V = -∫E dot dr
Part I was fairly straightforward. I found R by integrating from b to a (because the current travels inward from b) and got
R = ρ (b - a) / 4πab
which yielded
i = 4πVab / ρ(b - a)
Part II is giving me fits, however. The power drawn from the voltage source is just I*V. To get the power from the power density σE2 I would need to find an expression for E. Since E is in the same direction as the radial displacement vector r,
V = -∫E dr = -Er, evaluated over the limits of integration (from b to a, in this case).
I have a feeling that this is the route I need to take, but I'm not sure where to take it from there. I also considered using
E = ρJ = ρ(i/A)
but am also not sure where to take that... I figure I would need to find a function J(r) since the current density is r-dependent. (Current is constant over an r-dependent geometry.)
Anyone who can help me with this, or give a hint as to the right direction, would be doing me a huge favor.
Bump for the morning crowd.
Okay, so I think I've made some progress, and I'd really appreciate if someone could check my thought process here. Some notes I've made and thoughts I've had since I posted the thread:
  • I'll also use U to represent volume, since V is already taken and there's no potential-energy function at play here.
  • [itex]J = di/dU[/itex]
  • [itex]E = \rho J[/itex]
Since I found earlier that [itex]dR = dr/4\pi r^{2}[/itex], we have
[itex]i = V/R = 4\pi V ab/\rho(b-a)[/itex]
and
[itex]di/dr = 4\pi\sigma Vr[/itex]
So now we can use [itex]J = di/dU = \frac{4\pi\sigma Vr dr}{4\pi r^{2} dr} = \sigma V/r[/itex]
and thus,
[itex]E = J/\sigma = \sigma V/\sigma r = V/r[/itex] [itex]\Rightarrow[/itex] [itex]E^{2} = V^{2}/r^{2}[/itex]
which we sub into the equation
[itex]dP/dU = \sigma E^{2} \Rightarrow dP = \sigma E^{2} dU = V^{2}/r^{2} * \sigma * 4 \pi r^{2} dr = 4 \pi\sigma V^{2} dr[/itex]
Integrating dP with respect to r, we conclude that
[itex] P = \int ^{b}_{a} 4\pi\sigma V^{2} dr = 4\pi\sigma V^{2}r |^{b}_{a}[/itex]
When evaluated, this yields
[itex]P = 4\pi\sigma V^{2}(b - a)[/itex]
as our answer for the integral of the power-density function over the insulator volume.
To compare to the power that is dissipated as heat by the insulator, we simply need to take a straightforward approach:
[itex] dP = V di \Rightarrow P = \int^{b}_{a} V di = \int^{b}_{a} 4\pi\sigma V^{2} dr = 4\pi\sigma Vr |^{b}_{a}[/itex]
demonstrating that the power expenditure is equivalent using either method of calculation.
So what do you folks think? Did I do it right? Any glaring errors I should know about? :)
I agree with your result for i, but disagree with your power result. For starters, the "straightforward result" would simply use P=iV, using the expression you already got for i. (No integration required.)
I think you went awry in coming up with an expression like
[tex]\frac{di}{dr} = 4 \pi \sigma Vr[/tex]
as if i were a function that changes with r. But i is actually a constant expression.
E = ρJ = ρ(i/A)
I like that approach better. A would be the surface area of a sphere of radius r that the current is flowing through. That would make E2=____?, then you can integrate the power density over the entire volume between r=a and r=b.
Oh. Duh. Thanks, I have this habit of assuming everything is supposed to be a screwball and whatnot because my professor has a proclivity for that kind of thing. And so I overcomplicate things sometimes. :(
So for clarity's sake, whatever i is, I treat it as a constant instead of trying to find a differential charge, and set A = the area at an arbitrary radial distance r and just end up dividing i/4pi r^2 to get J?
Yes, correct.
Thanks so much for that. So from there I would just take E (= [itex]\rho[/itex]J), square it, multiply by sigma, and evaluate the integral
P = ∫[itex]\sigma[/itex]E2*4[itex]\pi[/itex]r2dr
leaving the a's and b's in the current function as a's and b's instead of being silly and trying to find them as functions of r.
Right?
What is a spherical conductor?
A spherical conductor is a type of conductor that has a spherical shape and is used to carry electrical current.
How is current density measured in a spherical conductor?
Current density in a spherical conductor is measured using the formula J = I / (4πr²), where J is the current density, I is the current, and r is the radius of the conductor.
What is power density in a spherical conductor?
Power density in a spherical conductor is the amount of power per unit volume that is carried by the conductor. It is calculated using the formula P = I²/(4πr²), where P is the power density, I is the current, and r is the radius of the conductor.
How does the current density change with distance from the center of a spherical conductor?
The current density in a spherical conductor decreases as the distance from the center increases. This is because the current is spread out over a larger surface area as the radius increases.
What is the relationship between current density and power density in a spherical conductor?
There is a direct relationship between current density and power density in a spherical conductor. This means that as the current density increases, so does the power density, and vice versa.
