Question on Lorentz contraction and size of pancakes
In summary, the Lorentz contraction causes nucleons to appear as flattened "pancakes" when they collide at high speeds. There are simulations available that demonstrate this effect and the total proton-proton cross section is approximately 40 x 10-27 cm2 at high energies, indicating a 4% probability of collision when 1012 protons are present in each colliding bunch.
zincshow
104
Question on Lorentz contraction and size of "pancakes"
I have read that nucleons (protons in particular) appear to look like flattened "pancakes" hitting each other due to the lorentz contraction when crashed together at high speeds. Do any of the colliders give a hint at the "size" of the pancakes? Ie. At say 99.99% of the speed of light, protons must be within ? picometers of each other to react with each other and create a "crash". This number is confussing as I understand the pancakes can also pass through each other without a collision.
An excellent simulation of the Lorentz contraction (up to β = 0.95) can be seen in the Cal Tech simulation of a moving charge. See http://www.cco.caltech.edu/~phys1/java/phys1/MovingCharge/MovingCharge.html
Use the slider to change β and hit GO. Watch in particular the center (of 7) field lines in the simulation. It always remains perpendicular to the velocity, and the other field lines are beginning to flatten (pancake) against it as β increases.
At high energies, the total proton-proton croass section is about 40 x 10-27 cm2. See top plot on page 12 of http://pdg.lbl.gov/2011/reviews/rpp2011-rev-cross-section-plots.pdf. This means that if you have 1 proton in a 1 cm2 area, and you shoot another proton at it, the probability of hitting it is 40 x 10-27.. But if you put 1012 protons in each of the two colliding bunches, the probability of a collision is 1024 x 40 x 10-27., or 4%..
1. What is Lorentz contraction?
Lorentz contraction is the phenomenon in which an object's length appears to decrease when it is moving at high speeds relative to an observer. This is a consequence of Einstein's theory of special relativity.
2. How does Lorentz contraction affect the size of pancakes?
Lorentz contraction does not have a direct effect on the size of pancakes. It is a relative effect that only becomes noticeable at speeds close to the speed of light. Since pancakes are not typically moving at these speeds, their size will not be affected by Lorentz contraction.
3. Can Lorentz contraction make pancakes appear larger or smaller?
In theory, yes, Lorentz contraction could make pancakes appear larger or smaller depending on the relative speeds between the observer and the pancakes. However, the effects would be so minuscule that they would not be noticeable in everyday situations.
4. Is there a maximum speed at which Lorentz contraction occurs?
Yes, Lorentz contraction only becomes significant at speeds close to the speed of light, which is considered the maximum speed in the universe. At this speed, an object's length will appear to contract by half.
5. How does Lorentz contraction relate to the theory of relativity?
Lorentz contraction is a fundamental aspect of Einstein's theory of special relativity, which explains how the laws of physics are the same for all observers in uniform motion. It is one of the key principles that led to the development of the theory of relativity.
  • Quantum Physics
19K
