Inverse Hyperbolic Funcs. or Trigonometric Substitution?
In summary, integrals that lead to inverse hyperbolics and can be solved with trigonometric substitution can have multiple solutions that look different but are actually equal up to a constant. This is because the solutions vary "up to the constant" and any solution found will be equally valid. In this specific conversation, the two solutions for the integral ∫ dx/sqrt(4+x^2) were arcsinh(x/2) and ln(x/2+sqrt(x^2/4+1)), which can be proven to be the same using a trigonometric substitution.
redq
So, in integrals that lead to inverse hyperbolics and can be solved with trigonometric substitution i just get lost. I know how to use both of them but i don't know which to use.
For the sake of simplicity i'll just go with this one
∫ dx/sqrt(4+x^2)
We know this equals arcsinh(x/2) ,right?
or we can just write x=2tant and find a completely different answer?
Which one of these solutions are "more true" , assuming you are in the final exam?
Or just they aren't true and I'm missing something?
Any solution you find will be equally valid. In fact, you will only find one solution, however, it may happen that the solutions look very, very different. The reason for this is because the solutions vary "up to the constant".
For example, you may find log|2x|+C as solution or log|x|+C. But these two are the same since log|2x|+X=log[x|+log|2|+C. And we just put log|2| in the constant (which is arbitrary anyway).
Thus every solution you find are actually equal (up to a constant). Hence all solutions you find will be equally valid!
Indeed! But even if they look very different, they can be proven to be the same, with different constants added.
At the specific OPs case, the two different results one gets are:
[tex]\int\frac{dx}{\sqrt{4+x^2}}=arcsinh\left(\frac{x}{2}\right)+C_1[/tex]
and (if one uses the trigonometric substituition x=tan(t) ):
[tex]\int\frac{dx}{\sqrt{4+x^2}}=ln\left(\frac{x}{2}+ \sqrt{ x^2/4+1 } \right)+C_2[/tex]
For proving that both are the same, we start as:
[tex]y=arcsinh\left(\frac{x}{2}\right)[/tex]
[tex]sinh(y)=\frac{x}{2}[/tex]
[tex]\frac{e^y-e^{-y}}{2}=\frac{x}{2}[/tex]
[tex]u=e^y[/tex]
[tex]u-\frac{1}{u}=x[/tex]
[tex]u^2-ux-1=0[/tex]
[tex]u=\frac{x\pm\sqrt{x^2+4}}{2}[/tex]
[tex]y=ln(u) = ln\left(\frac{x+\sqrt{x^2+4}}{2}\right)[/tex]
Where we choose the + at the sqrt because the - would lead to a negative argument to the log. So:
[tex]y= ln\left(\frac{x}{2}+\sqrt{x^2/4+1}\right)[/tex]
which is the same result we got when we integrated using ths trigonometric substituition x=tan t. In this specific case, the two solutions were exactly the same, but usually they differ by a constant, as pointed by micromass.
1. What are inverse hyperbolic functions?
Inverse hyperbolic functions, also known as area hyperbolic functions, are mathematical functions that are the inverse of hyperbolic functions. They are used to solve problems involving hyperbolic functions and are denoted by "arc" followed by the name of the hyperbolic function (e.g. arcsine, arccosine, arctangent).
2. What are the applications of inverse hyperbolic functions?
Inverse hyperbolic functions are commonly used in physics, engineering, and other scientific fields. They are particularly useful in solving problems involving exponential growth and decay, as well as in calculating areas under hyperbolic curves.
3. How do you find the inverse hyperbolic function of a given value?
To find the inverse hyperbolic function of a given value, you can use a calculator or a table of values. Alternatively, you can also use the definition of the inverse hyperbolic function, which involves solving a logarithmic or exponential equation.
4. What is trigonometric substitution?
Trigonometric substitution is a technique used in calculus to simplify integrals involving algebraic functions. It involves substituting a trigonometric function for one or more variables in the integrand, in order to transform the integral into a simpler form that can be easily evaluated.
5. When should I use trigonometric substitution?
Trigonometric substitution is typically used when the integrand contains a square root of a quadratic expression, or when the integrand contains a sum or difference of two squares. It is also useful when dealing with integrals involving trigonometric functions and inverse trigonometric functions.
11K
  • Calculus
  • Calculus
