How Far Must You Walk to Experience Silence Between Two Phase-Aligned Speakers?
In summary: At locations that are 1/2λ, (3/2)λ, (5/2)λ, etc greater than or less than your distance to the 2nd speaker.
Foxhound101
52
Imagine you are in an open field where two loudspeakers are set up and connected to the same amplifier so that they emit sound waves in phase at 688 Hz. Take the speed of sound in air to be 344 m/s.
What is the shortest distance d you need to walk forward to be at a point where you cannot hear the speakers?
f1= V/2L
lambda1 = 2L
So...this is what I did...
688 = 344/2L
L = .25
lambda1 = 2L
lambda = 2(.25)
lambda = .5
Destructive interference occurs at a distance that is half lambda. I said that the answer was .25 meters, but according to the program that is not the correct answer. So...where is my error? (It is always possible the program is wrong, but normally it is me) Please help me identify my mistake.
Unless I'm supposed to walk beyond one of the speakers...but that doesn't make sense either...
Well, using another formula...
lambda=V/f
lambda=344/688
lambda=.5
So I still believe that lambda is .5.
That is not really true. Review the part of your textbook or lecture notes that discusses interference more carefully. What is the actual condition?
"Destructive interference occurs when the path-length difference is...
r=(m+.5)*lambda
where m = 0, 1, 2, 3, ...
Constructive interference occurs when the path-length is...
r = m*lambda
where m = 0, 1, 2, 3, ..."
So...I still don't really understand. The book does not do a good job explaining this.
r=(m+.5)*lambda
Yes, that's it. The difference in the path lengths from you to each speaker should be a "half-integer" multiple of the wavelength ... i.e., (1/2)λ, (3/2)λ, (5/2)λ, etc. etc. In other words, (m+0.5)λ as the formula says.
You'll have to use some geometry to figure out where you can be, so that the distances from you to the two speakers differ by the minimum amount of λ/2 (= 0.25 m).
By the way, some things are not clear from your original post:
1. How far apart are the speakers?
2. What is your location, when you start to walk forward?
Woops...silly me. That information was in part A, which I had already answered and didn't include in the original post.
*restates problem*
Part A
If you are 3.00 m from speaker A directly to your right and 3.50m from speaker B directly to your left, will the sound that you hear be louder than the sound you would hear if only one speaker were in use?
YES
Part B
Okay, good.
At what locations can you be (in between the 2 speakers) so that your distance to 1 speaker is (1/2)λ, (3/2)λ, (5/2)λ, etc greater than or less than your distance to the 2nd speaker?
1. What are destructive sound waves?
Destructive sound waves are sound waves that cause damage or harm to objects or living beings. They can be produced by various sources such as explosions, earthquakes, or loud music.
2. How are destructive sound waves different from normal sound waves?
Destructive sound waves have a higher intensity and can cause physical damage, whereas normal sound waves are typically harmless and can be perceived by the human ear.
3. How do destructive sound waves affect the environment?
Destructive sound waves can have a negative impact on the environment by causing disruptions to ecosystems and potentially harming wildlife. They can also contribute to noise pollution, which can have adverse effects on human health and well-being.
4. Can destructive sound waves be controlled or prevented?
Yes, destructive sound waves can be controlled or prevented through various methods such as sound insulation, noise cancellation technology, or implementing regulations for noise levels in certain areas.
5. What are some examples of real-life situations where destructive sound waves have been a problem?
Some examples include industrial noise pollution from construction sites or factories, sonic booms from supersonic aircraft, and loud concerts or events that can cause damage to hearing and structures nearby.
