Some questions about solving for critical points
In summary, the equation that represents the change in x when the numerator is set to zero produces the points on the original function where f(x) is undefined.
GreenPrint
1,196
I SOLVED THE MISTAKE WITH MY DERIVATIVE IN POST BELOW
I never understood why we just get rid of the imaginary solutions?
like for example
if f(x) = (5*x)/(9-x^2)
then
df(x)/dx=(5[9+x^2])/(9-x^2)
I've realized that when we set the numerator equal to zero we are doing this?
df(x) = 0 = 5[9+x^2]
what's the significance of this?
we are setting the equation that explains the change in f(x) to be zero makes sense to find critical points
so than what exactly is the meaning of setting the denominator equal to zero?
like I know you can't divide by zero and what have you (for the moment) but I was wondering what would be the meaning of such a thing
dx= 0 = 9-x^2
setting the equation that explains the change in x to be equal to zero? I'm trying to wrap my head around that would even mean if you could do such a thing x_x... just for the hell of it
dx= 0 = 9-x^2
x^2=9
x= +/- 3
so setting the denominator equal to zero, the equation that represents the change in x? produces the points on the original function were f(x) is undefined... interesting... but ya
so
df(x) = 0 = 5[9+x^2]=45+5x^2
-45 =x^2
-9=x^2
+/- 3*i=x
f(+/- 3*i)= (+/-15*i)/(9-(+/- 3*i)^2)=(+/-15*i)/(9-(-9))=(+/-15*i)/(9+9)=(+/-15*i)/18=+/-(5*i)/6
so these so called critical points that aren't really critical points are
(+/- 3*i, +/-(5*i)/6)
how would we go about plotting such points? and what exactly do they mean... I really doubt they are meaningless...
f'(x) ≠ 0 at any value of x means the function has no areas where it is instantaneously not changing. If this function was a function that described the position of an object, then it would mean that it's velocity is never zero. No horizontal slope of zero degrees on the function at any point in other words. I'm not sure what the imaginary numbers would get you though, not very familiar with them.
I think you might have made a mistake when taking the derivative of the function. If you have a function f(x) = g(x)/h(x), then f'(x) = [g'(x)h(x)-h'(x)g(x)]/(h(x))^2
If you set the denominator of f'(x) in the above equation equal to zero, the roots that you will obtain, if any, are of vertical asymptotes in the equation of f'(x). Areas where f'(x) approaches infinity or negative infinity.
Indeed I did. It's suppose to be
df(x)/dx=(5[9+x^2])/(x^2-9)
setting the numerator equal to zero
df(x)=0=5[9+x^2]=45+5x^2
-45=5x^2
-9=x^2
+/- 3*i=x
back into the original equation
these so called meaningless points are then
back to the derivative
dx=0=x^2-9
9=x^2
x=+/-3
back into the original function
f(+/-3)=(5*x)/(9-(+/-3)^2)=(5*x)/(9-9)=(5*x)/0
I always thought that a derivative was more of ratio, hence the notation df(x)/dx, a ratio between an infinitely small changed in f(x), to an infinitely small change in x, and we describe this ratio with a function
If the function is a rational function of the form
df(x)/dx = P(x)/Q(x)
I thought that we could then say from the logic above that
df(x) = P(x) an infinitely small change in f(x) can be described by a function P(x)
dx=Q(x) an infinitely small change in dx can be described by a function Q(x)
then a derivative
and is a ratio in the form of a function that describes an infinitely small change in f(x) to x
I assume that df(x) is not necessarily = P(x)
nor is dx=Q(x)
but sense it's a ratio it's sort of a simplified version of the original functions that described them but can still be said to equal to them
and so I was just thinking if we set the denominator equal to zero of a derivative df(x)/dx
dx = 0
your dividing by zero... but your also set dx = 0 and finding values at which the infinitely small change in x is equal to zero which happen to be were the original function is undefined... when the infinitely small change in x values near the particular point is zero...
Is my logic extremely flawed? Can I think of the derivative as a ratio of an infinitely small change in f(x) to x? It seems to make some sense and explains why we plug the values into the original function that are equal to when dx equals to zero is undefined... because an infinitely small change in x being equal to zero all by itself with reference to nothing else at all of just some random function really makes no sense at all... or does it X_X
and you I wounder what is the meaning of these "nonsense critical points"
-45=5x^2
-9=x^2
+/- 3*i=x
dx=0=x^2-9
9=x^2
x=+/-3
then a derivative
nor is dx=Q(x)
dx = 0
Is my logic extremely flawed? Can I think of the derivative as a ratio of an infinitely small change in f(x) to x? It seems to make some sense and explains why we plug the values into the original function that are equal to when dx equals to zero is undefined... because an infinitely small change in x being equal to zero really makes no sense at all... or does it X_X
You say "It's suppose to be df(x)/dx=(5[9+x^2])/(x^2-9)". That is wrong; it's supposed to be df(x)/dx = 5(9+x^2)/(x^2-9)^2.
You say
"If the function is a rational function of the form
dx=Q(x) an infinitely small change in dx can be described by a function Q(x)"
There is no logic at all here; it is just plain wrong, and makes no more sense than saying that since 1/2 = 75/150, we can think of 1 as 75 and 2 as 150.
RGV
I agree with that logic now that i think about it... I still don't like the notation that implies that there's some kind of ratio or something of the sort...
My other wounder is when we say that function is undefined at a point we are arguing that
the point is of the form (x, undefined)
Could we ever encounter the opposite of such a type of a point...
(undefined, y)
if we wanted to evaluate a function at infinity and negative infinity we could do so... but could would we consider it of the form (undefined, y)? hmmm...
If we were to do so we would find the derivative of the original function and divide both the denominator and numerator by the highest power in the denominator then take the limit as x-> +/- infinity
I don't think I was ever told why we divide the numerator and the denominator by the highest power that occurs in the denominator... nor can find an answer any were when I look online... like i get that your just multiplying by 1 but why this form of it?
1. What are critical points in a mathematical function?
Critical points are the points on a mathematical function where the derivative is either zero or undefined. These points are important in determining the behavior and properties of the function.
2. How do you find critical points of a function?
To find critical points, you must first take the derivative of the function and set it equal to zero. Then, solve for the variable to find the critical points. You may also need to check for points where the derivative is undefined.
3. What is the significance of finding critical points?
Finding critical points allows you to identify important characteristics of the function, such as minimum and maximum values, points of inflection, and intervals of increase or decrease.
4. What is the difference between a local and global critical point?
A local critical point is a point where the derivative is zero, but it is not necessarily the highest or lowest point on the function. A global critical point, also known as an absolute critical point, is the highest or lowest point on the function.
5. Are there any other methods for finding critical points?
Yes, there are other methods such as using the second derivative test or graphing the function to visually identify the critical points. However, taking the derivative and setting it equal to zero is the most common and efficient method.
