PTFE / PCTFE / Viton / EPDM characteristics and applications
In summary, PCTFE is a suitable material for use in gas mixture valves due to its resistance to chemicals and heat. However, as it is not fluorinated, it is possible for moisture to accumulate, which can lead to bacteria growth and gas contamination. Viton is a good choice for this application as it is resistant to chemicals and heat, but it is more expensive.
ameeno97
34
Hi all
I want you to give a comparison between PTFE / PCTFE / Viton / EPDM O-ring considering these points :
• nonflammability
• excellent chemical resistance to all inorganic corrosive fluids
• Thermal resistance
• friction
• practically zero moisture absorption
• excellent electrical properties
Does PCTFE has same characteristics as PTFE?
What are the characteristics of Viton (VS. PTFE)?
What are applications for PTFE / PCTFE / Viton / EPDM?
I want to use these items in high-purity pipeline (In-Vitro Fertilization lab) and the last thing I want to happen is gas contamination or chemical reaction
Please advise and give comparison and provide recommendation?
Regards
Basically these are all called fluorinated materials. In other words, fluorine atoms surround carbon atoms and this gives the chemical resistance (since fluorine is inert).
These materials are broken down into what is called fully fluorinated and partially fluorinated. The full ones have all carbon atoms surrounded by fluorine and the partial ones have some besides fluorine.
PTFE is the original DuPont Teflon fully fluorinated material.
PFA is basically also pure Teflon but is injection moldable.
Viton and EPDM are partially fluorinated elastomers but much less expensive than PTFE.
BTW, pure PTFE o-rings are usually sold by the trade names Kalrez (DuPont product) and Chemraz (GreenTweed product).
So if you need the full chemical resistance and Teflon properties, go with PTFE. If not, the Viton or EPDM will be much less expensive.
Another good choice is called TEV which stands for Teflon Encapsulated Viton. It is basically an inner ring of Viton in a Teflon tube. Much cheaper than than PTFE and almost as good in most cases.
Thank you very much edgeflow for you continuous assistance, these info are very helpful
What about PCTFE?
I have to pipelines, One for CO2 and the other is special mix gas (89% nitrogen , 6% CO2 , 5% Oxygen) for (IVF lab) and I use stainless steel for whole installation and PCTFE, but there are Non-return valves that have EPDM or Viton O-Ring. I am afraid using other material other than PTFE would lead to moisture absorption (bacteria) and other gas contamination.So what should I do? The non-return valve manufacturer has only two choices;Viton or EPDM, should I just take one of them (may be Viton) and they will do a good job or should I go and find another manufacturer that has PTFE Or-ring on their non-return valve?
What about PCTFE?
The PCTFE should be fine - it is known for high compressive strength and low deformation.
I think Viton is good for this gas mixture. If it was just oxygen, I would recommend the Teflon o-rings, but if the gas stays mixed in the ratios you mentioned, I think Viton is OK. Double check with some o-ring companies, however.
Among the plastics you cite, only EPDM (which isn't fluorinated) and Viton are elastomers. This should tell you their roles as seal parts.
EPDM has good resistance to chemicals, as a hydrocarbon, but poor resistance to heat. Impossible to sterilize for instance.
PTFE creeps horribly. Permanent worry for seals. Compressive strength says little about a polymer.
Developing seals is a difficult job needing months and years. Very few materials fit, and a seal uses to consist of several parts made of different materials. So if one company doesn't have the product you'd like, you may try a few other companies, but don't hope to obtain good rings from a material nobody uses.
Hi
Thank you all for contribution. Here are more info :
http://fluorotherm.com/Properties-PCTFE.asp"
http://fluorotherm.com/Properties-PTFE.asp"
http://www.wisegeek.com/what-are-elastomers.htm"
http://www.pspglobal.com/sab.html"
http://www.pspglobal.com/viton-properties.html"
Sorry for resume an old post, but google sent me here.
Is this still an issue?
Carlo
What is PTFE and what are its characteristics?
PTFE stands for polytetrafluoroethylene, a synthetic polymer known for its non-stick and chemical resistance properties. It has a very low coefficient of friction and can withstand high temperatures and harsh chemicals without degrading.
What is PCTFE and how is it different from PTFE?
PCTFE stands for polychlorotrifluoroethylene and it is a modified version of PTFE. It has similar characteristics to PTFE but with added flexibility and impact resistance. PCTFE is also more resistant to radiation and has a lower gas permeability compared to PTFE.
What is Viton and what are its applications?
Viton is a brand of fluoroelastomer, a type of synthetic rubber that is highly resistant to chemicals, oils, and extreme temperatures. It is commonly used in industrial and automotive applications such as seals, gaskets, and O-rings.
What are the characteristics of EPDM and where is it commonly used?
EPDM stands for ethylene propylene diene monomer and it is a type of synthetic rubber known for its excellent weathering and ozone resistance. It is commonly used in roofing, automotive parts, and seals due to its durability and flexibility.
Can PTFE, PCTFE, Viton, and EPDM be used together in applications?
Yes, these materials can be used together as they have similar chemical resistance properties. However, it is important to consider the specific application and compatibility with other materials to ensure optimal performance.
